03-11-2006, 08:38 PM | #1 |
Member#: 12281
Vehicle:08 FSXT Tiger's Blood |
STI 1/4 mile registry (stock vf39) < 13.0
after seeing the td04 list by hotrod i thought it would be a good idea to compile a list of the fastest sti's w/ stock turbo. anything goes mods wise as long as the turbo is UNTOUCHED, no porting of any kind. EWG is fine, nitrous is fine, alky/meth injection is fine, c16, any type of race gas, etc. dogbox's allowed too, but please clarify! please post up a mod list if you want but a slip is necessary, **NO SLIP, NO TIME**
click on times for pic of timeslip. --------name----------car------1/4 mile time---------track--------------octane------------
03-11-2006, 08:48 PM | #2 |
Member#: 12281
mods; k&n intake, gruppe-s header, helix up, helix dp, hks catback (catless), txs fmic, txs r34 bov, 11lbs. helper spring, walboro fp, ecutek tuned by mspt, 93 octane, 3405lbs. w/ driver |
03-12-2006, 04:04 PM | #3 |
Member#: 12281
no one? come-on guys lets get this list going...
03-12-2006, 04:11 PM | #4 |
Member#: 32764
Vehicle:2003 WRX with 91K New Motor & Paint WRB |
good luck with this
03-12-2006, 04:24 PM | #5 |
Member#: 12281
ty it looks like im going to need it!
03-12-2006, 04:55 PM | #6 |
Member#: 90921
Vehicle:2004 STi PSM/charcoal BBS |
I'll post up as soon as I go - subscribing
03-12-2006, 07:44 PM | #7 |
Member#: 69689
Vehicle:04 interceptor sti 11.89@118 sz55 pump gas |
12.40@108mph on 110
03-12-2006, 07:53 PM | #8 |
Member#: 87439
SCIC
Vehicle:2009 S2000 '09s2KnEGAtiVeSHifTiNg! |
[email protected] TBE/CAI/ECUtek on 91 at LACR (LA County Raceway).
03-12-2006, 07:56 PM | #9 | |
Member#: 12281
03-12-2006, 08:01 PM | #10 |
Member#: 12281
coming up w/ a slip will be tuff 4 every1. so if you cant find it at least type it out full timeslip. thansk you. dont forget octane and track!
03-13-2006, 12:47 AM | #11 |
Member#: 90436
SCIC
Vehicle:2005 STI Obsidian black pearl |
california dragway (1200ft elevation)
1.753 5.322 8.288 83.89 mph 10.820 12.971 105.12 mph mods: k&N cai, b&b catless dp, perrin crank pulley, stock ecu, wingless. craptastic CA 91. this was before the injen fmic which slowed me down. Last edited by Illusive; 03-13-2006 at 12:53 AM. |
03-13-2006, 12:59 AM | #12 |
Member#: 32636
Vehicle:2004 Impreza STi Silver/Silver |
I won't bother posting the slip for my 13.2 run; as most people could pull that with less mods than I have. However that was before I figured out how to launch the damn car and with good weather coming I plan on being into the 12's solidly. Now I just need to clean up that fourth to fifth shift. Bump to keep a worthwhile thread going.
offset |
03-13-2006, 03:17 AM | #13 |
Member#: 57989
Vehicle:2016 .:R LGM |
Meh I doubt this will stay in the top 20 for long.. but why not.
New England Dragway 60': 1.819 330: 5.309 1/8: 8.225 MPH: 84.22 1000: 10.749 1/4: 12.891 MPH: 105.45 93 Octane mods: UTEC tuned by F1Dyno, Cobb catted downpipe, Borla Hush, Perrin Short ram |
03-13-2006, 03:57 AM | #14 |
Member#: 12281
^^ what gas?
03-13-2006, 08:30 AM | #15 |
Member#: 70197
Back when the car was stockish..i made 3-4 1/4mile passes and quit:
12.55@110 @ Sacramento county raceway. Vishnu xede tuned on c16/Helix turbo back exhuast..no others changes/mods to the car. Last edited by MARKGSTI; 03-13-2006 at 11:27 AM. |
03-13-2006, 11:13 AM | #16 |
Member#: 104591
Vehicle:06 STi WRB |
How about what tire pressure/launch technique/and definately list your mods.
03-13-2006, 02:31 PM | #17 |
Member#: 35277
~1.8 60ft (launching @ 5k)
13.1 @ 104.6 Accessport Stage 2 93 octane map, Helix catless 3" DP, Stock everything else, no weight reduction & 93 octane |
03-13-2006, 02:46 PM | #18 | |
Member#: 31761
Vehicle:2005 sold! STi Aspen White w/ Gold rims |
So let me know when you figure out how to launch the car. I'm still trying to figure it out. Nothing like the smell of burnt clutch all the way down the track. I either bog it down, or rev it too high. |
03-13-2006, 02:51 PM | #19 |
Member#: 12281
OK GUYS. i need the timeslips typed out in entirety or scanned. including 60ft, 330, 1/8, mph, 100, 1/4, mph. i need your 1/4 mile time to look like this...
[email protected] to the thousandth! im sure that a few times will come to hundreths if not thousands, so i need to arrange then accordingly. Last edited by wrxtremeWGN; 04-27-2006 at 01:43 AM. |
03-13-2006, 03:29 PM | #20 |
Member#: 78165
South East
Vehicle:05 STI 35r + e85 |
For the record, here is a copy-paste of my other post in the timeslip thread regarding my 12.48 run.
Mods at the time were: Cobb StreetTuner, Helix Catted DP, Blitz NUR Spec catback, Injen Limited (RS1201) CAI, Perrin EBCS, 9lb wastegate helper spring, Thermotec turbo heat wrap, coated heatshield, Kartboy rear diff crossmember bushings, TiC rear diff bushings, and t-bolt clamps to stop a boost leak I found. LC-1 WB02 and a Greddy EGT gauge. Stock VF39. Boost was 19.5 tapering to 16.3 at 6800. AFR is 11.5 tapering to 11.3. EGT's hit 880c on this run. ~95 octane. I normally launch at 5000-5500, as I recall this launch was at about 6k and felt mushy. I flat-shift 2-3 and 3-4 and lift on the others, and shift around 6200rpms. And since everyone always asks, the other car in the slip below was an old toyota corolla, with slicks, cage, and I dunno what else. He nailed his brakes at the finish line hard enough to lock em up. |
03-19-2006, 08:01 AM | #21 |
Member#: 110273
Vehicle:450 whp 30R STI 10.96@126 |
60' 1.706
330 5.233 1/8 [email protected] 1000 10.4 1/4 [email protected] Mods: Stromung catless TBE, Injen CAI, Ecutek, Perrin FMIC, samco inlet, GFB BOV, 101oct. |
03-19-2006, 04:28 PM | #22 | |
Member#: 69689
03-19-2006, 06:52 PM | #23 |
Member#: 36792
Vehicle: 2018 BMW M2 2016 FRS RS 2.0 #661 |
This is from my '04 STi last year:
Gutted stock downpipe/midpipe, Magnaflow Ti catback and 100 octane #7138 Today with my '06 STI: Cobb DP, Magnaflow Ti catback, APS header, 93 octane, hitting the brakes... #7650 I think it's finally time for some engine management. |
03-19-2006, 07:30 PM | #24 |
Member#: 56203
Vehicle:00 RSTI Coupe Twin Scroll 2.5XTR EJ207 |
nice run.
03-19-2006, 09:07 PM | #25 |
Member#: 44809
W. Canada
Vehicle:2008 BMW M3 SATURDAY!!!!!!!!!!!!!!! |
Cobb Stage 2. 94 Octane. 2,700 ft ASL and a fat man drivin'! Not sure about the 60' time...I've seen 1.690 before www.ncmp.ca
[IMG][/IMG] |
Similar Threads | ||||
Stock Turbo STi 1/4 Mile Registry (USDM) | downsti | Proven Power Bragging | 279 | 07-31-2012 01:44 PM |
VF43 2.5 STI 1/4 Mile Registry | gabedude | Proven Power Bragging | 55 | 07-03-2009 02:32 AM |
('93-'01) Subaru 1/4 Mile Registry | Kevin Thomas | Impreza Forum | 31 | 03-04-2007 12:58 PM |
1/4 Mile Registry Dead? Can I-club create a new one? | dug-e-fresh | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 15 | 03-13-2002 11:02 AM |
1/4 mile registry | SKiDaZZLe | Technical Forum Archive | 7 | 06-15-2000 05:48 AM |
