Welcome to the North American Subaru Impreza Owners Club Wednesday March 20, 2019
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine Management
Old 02-01-2017, 01:34 PM   #1
iWire
Vendor Sales Rating: (0)
Member#: 433327
1998 2.5RS
Default iWire Intercooler Splitters, AVCS Kits, and Speed Density Adapters For Sale!
iWire Intercooler Splitters are here!!
ORIGINAL POST
In our pursuit to build parts that bridge the gap between new and old, we are looking at doing an Intercooler Splitter with a Water Spray Nozzle for 98-01 hoods. The splitter will be designed to work with 2.0 WRX intercoolers, 04-07 STi intercoolers, and an option for a block off plate for front mount intercoolers.
Once you swap your GC, it’s critical to make sure the air is forced through the intercooler to maximize its effectiveness which translates to the engine making more power because of the colder air.
The base will be standard and the gaskets (WRX, STi, or block off) interchangeable so if you start with a WRX intercooler and upgrade to an STi or front mount you will only need to purchase one piece instead of the entire splitter which will save you money.
BUY YOURS TODAY!
AVCS Kits
Unleash the full potential of your 01-05 JDM WRX or STi engine in your 02-05 USDM WRX using one of our AVCS Wiring Kits.
All of our AVCS Wiring Kits are built with Tefzel wire to create the best connection possible and sleeved in Raychem DR-25 that can withstand the heat of the engine bay. Our AVCS harness is smaller, lighter, more flexible, and tougher than any other on the market.
Which AVCS Kit is right for me?
We have three versions available. Click on the kit name below to check out more details on our website.
iWire Bulkhead AVCS Kit: This kit is designed for use with a complete JDM engine with wiring attached. - $149.99
iWire Bulkhead AVCS Kit with Engine Adapters: This version of our Bulkhead AVCS Kit includes our prewired engine adapters which make the AVCS installation practiacally plug and play. All you will do is pin the ECU and just plug in the rest! - $249.99
iWire Full AVCS Kit: Recommended for those with just an AVCS equipped long block or heads and no matching intake manifold with wiring harness. It includes wiring for both the bulkhead harness and engine harness. - $384.99
SPEED DENSITY ADAPTERS
For those of you that have already swapped your car and are looking to switch to speed density our Plug and Play Speed Density Adapter is for you! No longer cut out the stock Mass Air Flow (MAF) plug to convert to Speed Density (SD). We have two versions - one for models 2002-2007 and another for models 2008-2014.
Our harness is built to last with Milspec grade materials like flame retardant, corrosion, and abrasion resisitant Tefzel wire. We've also wrapped it in Raychem DR-25 heat shrink tube that can withstand the harsh environment of the engine bay. The Intake Air Temerature (IAT) sensor plug is booted and the MAF sensor connector is potted to ensure a true weatherproof seal and secure wire connections.
Optional AEM Manifold Absolute Pressure (MAP) sensor adapter for upgrading when the stock MAP reaches its limit. Built to the same specifications as the MAF harness for a high quality connection that will resist the high temperature engine bay location on the intake manifold.
To Purchase 2002-2007 Speed Density Kit for $69.99 Click Here Speed Density 2002-2007
To Purchase 2008-2014 Speed Density Kit for $69.99 Click Here Speed Density 2008-2014
Take a look at all of our product offerings in our online store - iWire Online Store
__________________
iWire Subaru Wiring Services, LLC
www.iwireservices.com
iWire is offline   Reply With Quote
Old 03-10-2017, 03:10 PM   #2
iWire
Member#: 433327
1998 2.5RS
UPDATE as of 3/9/17
Intercooler Splitter with Water Spray Nozzle for 98-01 Hoods
We just wanted to remind everyone that the IC Splitter Pre-Order ends tomorrow 3/10/17 at 9 PST so get in now to save 15%! ORDER HERE
We also have updated drawings with the changes for the GR splitter. The opening is much wider so we had to adjust the logo and vent design to accommodate, but everything is progressing nicely!
Upper is the setup for 04-07 STi and lower is 08-16 STi.
__________________
