Welcome to the North American Subaru Impreza Owners Club Friday March 23, 2018
Old 10-15-2001, 04:12 PM   #1
Member#: 7006
2007 SpecB
Default BRAKE light ON
I've now got a BRAKE light that usually comes on in the morning. Usually disappears when I use my car during the day. I've got a manual. I just spoke to a coworker who's got an automatic and she's been having the same problem during the last week? How weird? She's got no mods, so that makes me feel better.
Brake fluid is good, so I dunno.
Any Ideas
Jan Skrlj (Squirrel)
rallysquirrel is offline   Reply With Quote
Old 10-15-2001, 07:02 PM   #2
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
Try removing the top of the Brake Fluid resevoir. Inside the cap there is a rubber diaphram, make sure the diaphram is collapsed inside the cap. If this is distended it can trigger the "Brake" light for low fluid.
If this is OK, make sure the handbrake is fully released
SubyTechMaster is offline   Reply With Quote
Old 10-15-2001, 07:35 PM   #3
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Also make sure that the fluid level is well above the min line. If it's boderline, it can trip the warning light when the fluid is cold. That would explain why it goes away, with use. I had mine drive me nuts, for about a week.
gavin is offline   Reply With Quote
Old 10-15-2001, 10:39 PM   #4
Member#: 9919
1995 Legacy
Default float could be stuck
check that the float inside the resevoir is moving freely. Mine got stuck to the inside of the resevoir and wouldn't float up. When the float is up, the light is off, when fluid is low the float comes down and triggers the light. Good luck...
BLZ2DWL: is offline   Reply With Quote
Old 10-15-2001, 11:27 PM   #5
Member#: 8666
2005 STi
Crystal Gray
Default Antilock?
Dunno about the 97's but there seem to be a LOT of things that will turn on the brake warning light in my 00. One of them is the anti-lock system. It has a hydraulic pump and until the pressure is high enough the brake light is on - so is the antilock light. My last car was a Peugeot and it had antilocks too; the only way I knew that had enough pressure built up was by the brake warning light, and in winter that car used to take a few extra seconds to build pressure. It could be that on a Subie that's a few years old the same thing is happening.
Good luck,
francophile is offline   Reply With Quote
Old 10-16-2001, 10:32 PM   #6
Member#: 3388
1992 E34
Mauritius Blue
I had same problem with my 94 Legacy Turbo...... in the mornings only the brake light would come on and won't go off even after handbrake is released... once the car is warmed up.. say around 15 minutes of driving. If i shut off the car and start it again.. it will go off. If i just keep driving it will stay on the whole time. My brake fluids were fine but pads are low....... and it doesn't seem to happen in warmer days.... Some have suggested that my handbrake cable has to be relubed and there was moisture in it, so it won't fully release, however i don't think that was the case for mine becoz even if i left my handbrake off for the whole nite, the brake light came back on once i reversed out of my driveway and hit the brakes.
after brake flush and new pads, it still happend on the next morning. but then after that it never happend again..! weird, but if it really worries u, brake flush will probalby work. worked for me.
Prostho is offline   Reply With Quote
Old 04-18-2008, 09:15 AM   #7
Member#: 94024
95 YJ Flat black
alright bumping an old thread here....but my brake light stays on when its cold outside....problem is Im putting a turbo timer on and its going to mess w/ it im sure (since technically it could be put down and the car seems to think its still up) any ideas on how to solve this problem?
legacy1907 is offline   Reply With Quote
Brake light on on the dash but brakes are good? Mikey52 Legacy Forum 8 01-19-2009 01:02 PM
no power steering? brake light on? battery light on? love2puck14 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-02-2008 09:12 PM
brake light on uder heavy braking? prometheum Brakes, Steering & Suspension 0 06-15-2007 06:19 AM
Question: brake light on, clock light out, daytime running light out PhoKingWRX Electrical & Lighting 2 05-22-2005 07:29 AM
e-brake light on when installing JDM lights WRX_NC Engine Management & Tuning 3 09-22-2004 10:05 AM
