Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
Old 04-25-2005, 12:35 AM   #1
97subGT
Member#: 41323
Sedona
Default which plugs to use STI or WRX
I have a wrx with a Sti 2.5L short block using the stock 2.0L heads. Now here is the problem the plugs that i have been using (which are the stock wrx ngks) the ceramic will completly disconnect itself from the metal. so you are able to hold the metal nut and spin the ceramic from where the coil over connects to the plug and the tip that is inside of the combustion camber will also spin. so should i use the sti plug which is longer or stick with a colder wrx plug?
97subGT is offline   Reply With Quote
what to look for when buy used sti or wrx ? slys13 Newbies & FAQs 7 12-04-2008 08:35 PM
Which Subaru to buy sti or wrx? innovativejr33 Newbies & FAQs 26 09-20-2007 03:20 PM
What colder spark plugs to use on 06 wrx bl0wnb0xerbabiE Newbies & FAQs 9 09-04-2006 08:53 PM
