10-15-2002, 02:01 PM | #1 |
Member#: 16854
Vehicle:2003 WRX Sedan White |
Which downpipes work with the SR turbo?
I want to try an SR turbo, but I think I need a special downpipe, anyone know for sure?
10-15-2002, 02:06 PM | #2 |
Member#: 19221
South East
Vehicle:2005 Legacy GT (STi) UR35R/Rotated Intake Mani |
No you do not need a special downpipe for the SR series turbos.
10-15-2002, 02:36 PM | #3 |
Member#: 15329
NESIC
Vehicle:2015 WRX WRB Ltd 2002 WRX PSM (sold) |
No I think Sordid is correct, I believe you need a dp with a bellmouth design.
10-15-2002, 05:12 PM | #4 |
Member#: 16738
Vehicle:2015 WRX Limited CWP |
I'm pretty sure I read somewhere that someone was using the TurboXS downpipe with no problems on a SR-30, I think it's the biggest mass produced one out a 4". I'm not sure if it would work but the scoobysport is also a Bellmouth but not quite as big.-James
10-15-2002, 05:33 PM | #5 |
Member#: 8829
VIC
Vehicle:GRB STI SWP |
The wastegate valve extends past the flange. Probably any bell-mouth type downpipe will work.
I'm guessing APS's own exhaust system should work too. Last edited by j y; 10-15-2002 at 05:38 PM. |
10-15-2002, 07:19 PM | #6 |
Member#: 11381
Vehicle:2008 sti aw |
I was wondering the same thing... I have the sr40 sitting on my desk at home.. and I have a godspeed jdm downpipe... I'll have to see if it fits when i bolt the turbo on.
cheers, Victor |
10-16-2002, 12:11 PM | #7 | |
Member#: 16854
Let me know if it does fit. |
10-16-2002, 02:47 PM | #8 |
Member#: 3389
Vehicle:07 STImpreza Satin |
A nice twin dump with the seperator tongue cut off should work nicely.
K2 |
10-16-2002, 11:57 PM | #9 |
Member#: 16854
Okay, let me try again - Does anyone know which up pipe works with the SR turbo that has an EGT bung?
Thanks - |
10-17-2002, 12:55 AM | #10 |
Member#: 10739
My m2 performance uppipe worked fine with an egt bung. I had to file down my BPM down pipe though. The divider was hitting the turbo.
sam |
10-17-2002, 01:52 AM | #11 | |
Member#: 2916
SCIC
Vehicle:02 duburu arr exu |
you might have fitment issues with the godspeed downpipe cause the flange might not clear the uppipe bolts (has nothing to do with the turbo). this was the case with mine and i had to grind off about a cm off the bottom of the flange. however, dan (godspeed) has said that this problem was taken care of and shouldn't be an issue anymore. since the sr series turbos are bolt ons, they should fit any uppipe and downpipe that will fit the stock turbo, though you may run into downpipe fitment issues if the downpipe has a wastegate divider that extends out too much like wrxxer had experienced. depending on how far the wastegate opens on the sr turbo during operation, you may be able to get away with using the stock downpipe, though i highly recommend you get one that flows a lot better, more specifically a full bellmouth design (godspeed's bellmouth doesnt extend across the entire flange opening like turboxs') or one with a separated wastegate flowpath (bpm, syms, cusco, zerosports, flatt racing, etc) |
Which downpipe works best with an Accessport, and bolts to stock piping? | plunk10 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 12 | 05-27-2004 01:56 AM |
Will the HKS wire harness work with the Apexi turbo timer for the 04 Wagon? | othon | Electrical & Lighting | 6 | 02-12-2004 12:32 AM |
Anyone have experience with the SR series of turbos? | Corn-Picker | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 10-14-2002 05:53 PM |
Anyone have experience with the SR series of turbos? | Corn-Picker | Proven Power Bragging | 12 | 10-10-2002 09:30 AM |
Anyone have experience with the SR series of turbos? | Corn-Picker | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 10-03-2002 01:05 PM |
