10-26-2020, 06:04 PM | #1 |
Member#: 387374
NWIC
Vehicle:96 IMP +LEG OBs Dk Blue , Green/grey |
Sheared bolt
1996 impreza ej22.Developed knocking from front area ,tracked it down to timing belt area.Further investigation finds tensioner retaiing bolt sheared leaving 1/2 inch +/- in the hole.Anyone have any ideas on rempval bearing in mind not enough room to get regular drill between it and ac rad.
10-26-2020, 07:44 PM | #2 |
Member#: 459287
VIC
Vehicle:1998 JDM Impreza STi V4 GF8 White |
10-27-2020, 12:30 PM | #3 |
Member#: 21145
NESIC
Vehicle:2002 Enemy of Aku |
You are going to have to pull the radiator to remove the bolt. There is just not enough room to do it otherwise.
Find the correct size drill bit. Find the correct size easy-out. I'd soak the broken bolt first with PB Blaster to give you a head start. |
10-27-2020, 07:49 PM | #4 |
Member#: 132643
South East
Vehicle:02 wrx wagon white |
broke bolt
If I remember correctly you can remove the entire bracket. A couple bolts to the passengers side of the tensioner.
10-28-2020, 08:03 PM | #5 |
Member#: 283429
South East
Vehicle:2016 Fuji Sunfire 03 Silver |
11-02-2020, 01:44 PM | #6 |
Member#: 387374
NWIC
That's not a problem,tensioner bracket is removed and broken bolt extracted but have another problem now. After installing timing belt,all marks properly lined up did the usual start engine test to make sure every thing right but apart from a little cough engine declined to start.Went back to beginning and reset everything,same result so thinking problem elsewhere. Checking on cam pulleys and discovered retaining bolt driver side was loose.so suspected sheared key.On removal found keyway on shaft and on pulley but also a pin driven through the pulley and apparently engaging the keyway on the shaft.Is this the correct setup?
11-02-2020, 09:10 PM | #7 | |
Member#: 283429
South East
11-03-2020, 07:07 PM | #8 |
Member#: 132643
South East
no start
Is everything hooked back up/ plugged in etc?
Check engine light on/ codes etc ? |
11-05-2020, 03:54 PM | #9 |
Member#: 387374
NWIC
Every thing hooked up as per normal,Just cant get her to fire,pretty sure it's a timing issue but not sure what to do next. Do you know at what serial # ej22s became interference motors? I ask because this is not the original engine but was bought as a 96 so should not be.
11-05-2020, 08:24 PM | #10 |
Member#: 132643
South East
From what I remember the single port exhaust are interference and the dual port are not.
11-05-2020, 08:29 PM | #11 |
Member#: 132643
South East
Have you checked for spark and sure its getting fuel ?
11-05-2020, 09:33 PM | #12 |
Member#: 387374
NWIC
Hi Stroker. Absolutely no reason why either would apply but I did check anyway and have spark and fuel.
11-08-2020, 07:53 PM | #13 |
Member#: 132643
South East
No fuel or no spark = no run
fuel,spark and in time usually = run of course there is compression but was trying to be simple |
