07-21-2010, 02:30 PM | #1 |
Member#: 248747
Vehicle:04' SG XT Blk |
Advice for future 4 Gen Full STI Swap
I am in the beginning stage of planning for a full sti swap into a 4 gen legacy/outback wagon 05-06. Looking at salvage outbacks wagons and legacy wagons. I was wondering if I will run into any issues swapping if i decide to go with the outback wagon,. I know they are heavier due to the additional options. Any other issues? Originally i planned to do the swap on my 2000 but i realized it was not worth it.
07-21-2010, 03:39 PM | #2 |
Member#: 177674
You going to just do the motor swap or you buying a wreaked STi so you get everything. If you going for a whole Sti get a 08-09. It will cost more but then you can use all the suspension goodies because they share the same setup.
There shouldn't be an issue with an outback over any other legacy model. If you are doing the tranny swap find a car that's a manual too unless you are swapping the harnesses as well. Converting a Automatic Harness to work correctly with a manual is a PITA. Buy one with an h6 in it and all buy your motor and crap haha. Johann @ Girodisc |
07-21-2010, 06:02 PM | #3 |
Member#: 71875
No, just buy a turbo legacy or outback. Then all you really need is the 6-speed stuff and a bigger turbo
Also the rear suspenion between the 4th gen legacy and an 08+ impreza is not the same. |
07-22-2010, 01:47 AM | #4 |
Member#: 248747
yeah i though 05 on legacy would be a direct swap 06 07impreza
07-26-2010, 05:43 AM | #5 |
Member#: 140444
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
The 05/06 LGT already has the STI shortblock.
If you're going to swap turbos, do something bigger than a VF39. |
07-26-2010, 09:54 AM | #6 |
Member#: 103665
+1 to ^
i know a guy with an 05 LGT, he swapped on STi heads and an STi intake manifold and that's all he needed because the rest (engine wise) is the same. as far as Outback vs Legacy, the only real difference is the height of the suspension. everything else should be very similar. |
07-26-2010, 12:27 PM | #7 |
Member#: 161832
Vehicle:2000 Outback Limited Black |
y not swap in a 2000? i will be doing close to that soon.
08-02-2010, 04:45 PM | #8 |
Member#: 248747
rear suspension is different, i blew the head gasket today, so i will change it and move on to something else
08-03-2010, 09:05 AM | #9 |
Member#: 161832
what does suspension have to do with which generation you swap to?
08-03-2010, 10:36 AM | #10 |
Member#: 115154
Vehicle:2005 Outback XT White on grey |
If you think it's not worth it in an older, cheaper model, then its certainly not worth it in one thats more expensive, newer, and already came available with an STI-block from the factory
Similar Threads | ||||
01 2.5RS ANY IDEAS FOR A FULL STi SWAP?? | RyanBec | Newbies & FAQs | 14 | 10-27-2009 12:08 AM |
Advice for future fobbit in Iraq | aggie113 | Texas Impreza Club Forum -- TXIC | 9 | 07-20-2009 04:31 AM |
Arcadia Green 2.5rs with FULL STi swap. For real this time! :( | MattD87 | Private 'Wanted' Classifieds | 113 | 06-25-2009 07:16 PM |
FS: 2002/2005 WRX/STI - Full STI Swap w/ FAT 30R Turbo Kit | dcheyne55 | SWIC Private Classifieds | 6 | 05-17-2009 11:11 PM |
Anyone looking for a full sti swap? | snowcrzy | SCIC Private Classifieds | 14 | 02-25-2008 02:13 AM |
