Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Old 11-17-2010, 03:41 PM   #126
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Post them up if you have them. I don't mind helping those who have already made an attempt to learn/research, as it looks you have. It's the posts like "Y0, I got a WRX an I am swapping a 6 speed. Wat do I need?" that get annoying and tiring.
Something something help those who help themselves comes to mind.
Old 11-29-2010, 12:50 PM   #127
bushman95
Member#: 248738
2004 wrx
red
how to the gear ratios compare to the 5 speed on an 04 wrx
bushman95 is offline   Reply With Quote
Old 12-19-2010, 12:11 PM   #128
BluedemonWRX
Member#: 248678
I'm still confused about kiyanichenko's question on page 4. Im doing this swap right after Christmas so I want to make sure I have everything ready. For a 04 sti speed swap into a bugeye Wrx I just have to get what kiyanichenko listed
04 sti 6speed
04 r180 diff
04 sti driveshaft
04 sti axles
aftermarket dccd
clutch fork,disc,pressure plate, flywheel, and slave cylinder
plus 04 sti rear hubs/knuckles right? Im getting the brembos and rotors front and rear off a 04 sti. I've been told that for the front I could just put the brembo calipers and rotors on but the rear is the reason I need the hubs and knuckles. Is this right? and wouldn't I just also need the rear sti axles if that's the case or would I have to get the fronts too.
BluedemonWRX is offline   Reply With Quote
Old 12-22-2010, 11:17 AM   #129
Shadysubie
Member#: 240984
02 WRX 89 240sx
04 sti 6speed
04 r180 diff
04 sti driveshaft
04 sti axles
aftermarket dccd
wondering about this too, im heavily thinking about doing the swap as well to get rid of the glass 02 tranny next month
Shadysubie is offline   Reply With Quote
Old 12-28-2010, 06:52 PM   #130
Pinned
Member#: 152707
If I wanted to swap an 04 transmission into my 2000 RS, and didn't want to deal with swapping hubs, is there any way I can use the R180? Or do I need to find an auto drive shaft and R160?
Pinned is offline   Reply With Quote
Old 01-10-2011, 03:01 PM   #131
delarryous
Member#: 207589
03 wrx
wrb
i am swapping an 06 sti transmission into my 03 wrx. i was wondering if the slave cylinders are the same? or do i have to buy an sti one
delarryous is offline   Reply With Quote
Old 01-14-2011, 04:59 AM   #132
samo22
Member#: 119693
1995 L w/ ej205
I think I got this right, but someone correct me if I'm wrong.
When swapping 05+ STI drivetrain into a gc8 with sti sway bars, I need:
Front: STI lower control arm, STI front endlinks, and STI sway bar.
Rear: STI adjustable lateral links (because stock sti links are too long and give crazy cambers, i think?), STI rear endlinks, and STI rear sway bar. Also STI rear subframe but you need it either way with STI rear diff, I believe.
With STI sway bars, do the front or rear become wider? If so, how much?
Can gc8 with 05+ STI drivetrain swap and stock gc8 lateral links use GD WRX rear sway bars?
samo22 is offline   Reply With Quote
Old 01-27-2011, 03:13 PM   #133
twrx64
Member#: 271855
2004 wrx
black java pearl
hey i got a 2004 wrx automatic and i'm looking to swap it for a 6 speed. what all would i need to do this right
twrx64 is offline   Reply With Quote
Old 02-13-2011, 12:18 AM   #134
dnorton
Member#: 218997
07 WRX Mikey Tuned
JE/FSR built,35r 1300c
JDM STI V7 and V8 6 speed DCCD trannys up for sale clutch assembly
slave cylinder
STI Differential
Rear Axles
Rear Hubs and Knuckles (5x100)
Drive Shaft
Hey Guys, I don't want to piss anyone off but I've been reading all day trying to figure out what I have to do to fix my problem. Today I blew 3rd gear in my 07 WRX Limited Wagon. I talked to a lot of guys today and decided to go to the 6 speed swap. I bought the above parts from the vendor for sale form and asked the vendor will this bolt up to my WRX and I keep my rims and brakes. He said yes but after reading thru these threads and reading so much about numbers matching or different parts from different years working that I"m confused. I didn't ask the vendor what year the Ver.7 tranny is just ask will it work with what I have. So do you think I can make these parts work with what I have. Thanks for your help and I have been reading post trying to figure out what I need to do.
dnorton is offline   Reply With Quote
Old 02-24-2011, 12:25 PM   #135
scoobie_snacks
Member#: 212744
2005 Ver8 EJ207 VF37
6 speed
slave cylinder
STI Differential
Rear Axles
Drive Shaft
well.. i'll tell you what. you have a V7 sti trans? so that would be a 2003 2004. so what you need to make this work is the rear hubs from a 2004 sti(5x100). a R180 rear diff from a 03(jdm V7 or V8) or 04 - 05 usdm. rear axles from any Sti. some are longer but it doesn't really affect anything. and an Sti driveshaft or automatic (4eat) driveshaft. rear 2 pot brakes that you probably already have..(lucky #$%^#$%) you can reuse your 5speed clutch if you use the 6 speed clutch fork. good luck with your swap. V7 don;t have dccd if i recall but if yours has one get a DCCDpro.com controller they are the bomb.. apparently.
scoobie_snacks is offline   Reply With Quote
Old 02-24-2011, 02:41 PM   #136
Xenri
Member#: 166777
2011 WRX Wagon
^ I agree with all of this except the driveshaft point. If You were using an r160 with the right ratio (for instance, the 02-03 usdm r160 matches the 06-07 sti transmission) you would need the 4eat because the transmission is longer than the 5 speed, but if you are swapping both the transmission and the rear diff, you need the sti driveshaft, as the yolk on the r180 is different than the one used for the r160, which is on the 4eats and the 5speed driveshafts.
Xenri is offline   Reply With Quote
Old 02-25-2011, 02:32 PM   #137
scoobie_snacks
Member#: 212744
6 speed
^True^. everything has been covered goodluck dude!
Old 03-18-2011, 03:56 PM   #138
lesterwrx7
Member#: 232129
What kind of axles can I use I heard the legacy 07 spec b axles works with The wrx huds and the Sti r180 rear diff any body know about this ? Or there's another way I jus dont wanna change splints and huds .
lesterwrx7 is offline   Reply With Quote
Old 04-01-2011, 12:46 PM   #139
SentinelSison
Member#: 112727
subscribed
SentinelSison is offline   Reply With Quote
Old 04-25-2011, 03:32 AM   #140
Joelo_00
Member#: 175095
Chapter/Region: PRSIC
2000 RS
PLEASE MORE INFO ON THIS!!!
Joelo_00 is offline   Reply With Quote
Old 04-25-2011, 11:12 AM   #141
Xenri
Member#: 166777
2011 WRX Wagon
In regards to the differential matching game that comes with the 6speed swap, heres the nitty gritty: The gear ratio in your rear diff needs to be compatible with the gear ratio in the other diffs. This is important for everything to mesh correctly.
Now, there are a couple of ways to accomplish this. The easiest is to do a full swap, and get an r180 from the same year STi, thus eliminating the problem. This, however, is expensive. There is a cheaper way. Subaru, in their infinite knowledge, decided that the STi and the WRX should always have different ratios, but in doing this, when they changed to the 06-07 models, they actually made the STi's ratio the SAME as the 02-03 (possibly 04-05 as well, but I can not seem to verify those years) WRXs. This means the r160s in those cars are set to compatible ratios with the 06-07 6 speeds.
If you still want to keep your r160 in the later WRXs, you can either swap it with an 02-03 (possibly 04-05) OR you can change out the gearing inside the diff to match whatever transmission you can get your hands on. That gets tricky, but allows you to do things like make your car have a final drive of 4.44 or something crazy like they do in Australia.
Here is a site that lists some of the ratios available (note the 3.54 in the Ver. 7+ STis matches the 3.54 listed in the r160 list. That is the magic number for the 02-03 diffs. It is a shame he does list the MY or ver number for all the ratios though.)
http://www.gotitrex.com.au/home/Blog...onversion.html
Old 04-25-2011, 07:43 PM   #142
JdMS13
Member#: 207299
2002 MBP Bugeye
Out Of Commision
For the 6 speed out of an 06 swap into a 02 you need the following.
Slave cylinder out of what year STi?
STi driveshaft out of what year STi?
Axle stubs from an 04 Sti with correct circlip and seal
DCCD controller, Apparently you need the ECU from what year STi to make it functional?
Shifter linkage and boot from what year STi?
I'm literally doing this next week hopefully so any help is appreciated
- Dave
JdMS13 is offline   Reply With Quote
Old 04-25-2011, 09:05 PM   #143
Xenri
Member#: 166777
2011 WRX Wagon
You do not need a slave cylinder unless you want one. The WRX one works just fine. You need either a 4eat driveshaft out of any impreza/WRX 01-07 or an sti driveshaft that has the correct yolk on it (you can purchase a yolk at your dealership, but the 4eat one has the correct one on it). For the controller you do not need an ECU swap unless you are swapping the entire wiring harness (which is ridiculous), just get a Spyder controller or a neetronics one or something. The piggyback onto your stock stuff and have a similar amount of control. YOu can actually skip the controller all together if you want, it'll make the DCCD completely open at a 60/40 read/front split and won't hurt anything. The shifter linkages are all the same but you will obviously need a 6 speed shifter to accommodate the reverse lock out ring. The boot has to come out of an 04 sti as that is the only model that has the same interior as the 02-03 wrxs
Old 04-25-2011, 09:33 PM   #144
JdMS13
Member#: 207299
2002 MBP Bugeye
Out Of Commision
What about the pressure plate, flywheel, clutch, throw out bearing? That should cover everything
Old 04-25-2011, 09:38 PM   #145
Xenri
Member#: 166777
2011 WRX Wagon
All the stuff you listed can come straight off your WRX. The only difference between the WRX clutch/flywheel and the sti is the fact that the sti has a bigger diameter. If you havnt purchased a new one already get the sti spec bc in this case bigger is better, but not necessary. Just make sure you have the sti clutch fork, or it won't work.
Old 04-25-2011, 09:47 PM   #146
JdMS13
Member#: 207299
2002 MBP Bugeye
Out Of Commision
Thanks man, The fine details just seem to get skipped sometimes.
-Dave
Old 04-26-2011, 05:56 PM   #147
JdMS13
Member#: 207299
2002 MBP Bugeye
Out Of Commision
Would the 06 STi clutch/pressure plate fit on my 02 wrx flywheel if not what year STi do you need a clutch out of if you want to do it? And what axle seals do you use with the STi stubs. Part numbers would be appreciated.
Old 04-26-2011, 06:27 PM   #148
Xenri
Member#: 166777
2011 WRX Wagon
No it won't fit. The flywheel is a larger diameter in the STi as well to accommodate the larger clutch. All STi's are this way. I do remember now that the 02-05 WRX set ups will work with the 6 speed, something to do with being a push (or pull) setup while the 06-07 is a pull (or push) setup, I can't remember which is which, jut that they are opposite, and all STi's (07 or earlier of course) match the 02-05 WRX style.
Anyway, to answer your question again, you need either an all 02-05 WRX clutch/pressure plate/flywheel or all 04-07 STi clutch/Pressure plate/flywheel. Besides, if you are buying a new clutch you should buy a new flywheel. The clutch plate and the flywheel have to mold into each other so it's much better to have new surfaces on both items instead of a machined surface on the flywheel. Gruppe-S makes nice lightweight flywheels at reasonable prices, along with exedy clutch kits. Go there.
Old 05-10-2011, 11:14 PM   #149
lafonzo271
Member#: 269278
2003 Subaru WRX
black
Default very generous
Those prices are very generous. I just did the swap and its pricey
lafonzo271 is offline   Reply With Quote
Old 05-28-2011, 06:05 PM   #150
BIGMANDAN
Member#: 13040
2002 IMPREZA WRX
WORLD RALLY BLUE
Yea thats my question, Were those average prices on finding used parts on the forum? Or do you have some hidden gem of a vendor that i would love to know about lol jk Im thinking about piecing together the swap on my 02 Wrx now I can get a rebuild Sti tranny with 200 miles on it for 3700 shipped so if you have any good advice to find all the supporting mods cheap pm me please... Thank you for the sweet thread!!
BIGMANDAN is offline   Reply With Quote
Master swap list for 04-07 Sti 6 speed into WRX crashtke Transmission (AT/MT) & Driveline 812 03-26-2018 09:06 AM
Feeler: 06 wrx sti 6-speed drivetrain swap... 06TRDude Drivetrain 8 02-23-2009 08:50 PM
Cost estimates for 6-speed swap into an 02 WRX? aasim_a Transmission (AT/MT) & Driveline 24 05-31-2008 05:37 PM
Parts needed for an STI drivetrain swap into an 01 RS SubeSTIle Subaru Conversions 15 11-04-2006 02:11 PM
Parts needed for an STI drivetrain swap into an 01 RS SubeSTIle South West Impreza Club Forum -- SWIC 2 10-31-2006 05:15 PM
