Welcome to the North American Subaru Impreza Owners Club Tuesday December 18, 2018
Old 07-15-2018, 10:55 AM   #1
ampb5rider
Member#: 401387
2005 Impreza Outback
Light blue
Question Valves Singing
My 05 Impreza valves sing under low power low rpm. When I rebuilt the engine I adjusted to spec. Checked them some time after, but they still sing. Are they to tight?
ampb5rider is offline   Reply With Quote
Old 07-15-2018, 10:42 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
I would like to hear an audio file, not quite sure what you mean by singing. It may just be a choice of words, that's all.
Old 07-19-2018, 03:59 PM   #3
ampb5rider
Member#: 401387
Light blue
Default Singing
At 35 - 40 MPH 1500 rpm or less,I hear what i believe to be the valves chattering. Put a little gas to it and the noise goes away (perhaps diminished) . Audio file, bit of a challenge, I'll see what I can do.
Old 07-22-2018, 03:56 PM   #4
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
What most people consider "valve chatter" is actually pre-ignition (spark knock) but that usually happens under load, no moderate throttle - unless you have deleted or disabled your EGR system.
One thing that does make that type of sound under the conditions you described is a timing belt tensioner that has a "dead" or "weak" spot and allows the belt to oscillate. Did you replace the tensioner during your build?
