Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
View Poll Results: would you ride it around town?
yes 30 60.00%
no 10 20.00%
wat 10 20.00%
Voters: 50. You may not vote on this poll
Old 05-09-2008, 02:08 PM   #1
shikataganai
Member#: 92634
OMGHi2U my electric bike
August 24, 2012 update reflecting its v2.0 rebuild with a 9C 2806 hub motor and a 48V 35A regen-enabled Infineon controller:
Maiden ride has been accomplished in grand fashion: 8.2 miles, 4.6 Ah, 27.8 Wh/mi. Max speed without pedaling, wide open throttle was around 27 mph on flat ground. With me pedaling along I could get it up to 30 mph. Comfortable cruising speed was more in the range of 23-25 mph while pedaling along, throttle part of the way open. Max indicated power from the battery to the controller (so less at the wheel due to motor inefficiency) was about 1600W at 27 mph. Max regen coming down from 25 mph was around 550W, decreasing as speed decreases. Overall I regened 6% of power input on my errand run today.
Original post below:
i built myself an electric bike. why, pray tell, given that i'm still sound of mind and body, at least by most accounts? the answers are speed and convenience. the added power lets me add things that are useful but which i wouldn't put on a road bike, such as full fenders, a solid rear rack for panniers, and a heavy internally geared hub.
electric assist is the difference between a) cruising up a decent grade at 18 mph in street clothes and shoes with cargo, contributing moderate pedaling effort and b) busting one's butt in clipless pedals to ride a road bike up the same hill at 8-10 mph. top speed on the flat with me tucking like a goon and not pedaling is right around 25 mph.
it's really quite fun, and, with the racks and such, useful.
technical details (again from the original build):
Novara Transfer bike from REI with a Nexus 7 rear hub
Crystalyte 407 front hub motor in a 26" wheel
36V-72V 20A pedal-first controller mated to a Crystalyte twist throttle
Cycle Analyst - Direct Plugin model
48V 12Ah LiFePO4 battery with battery management system (BMS)
Tubus Cargo tubular steel rear rack rated for 80 lbs iirc
Novara Safari waterproof panniers
the electric bits were all sourced from http://ebikes.ca/ . they ran about $1600 including shipping, with the majority of the cost ($900) being that fancy lithium battery. lithium isn't cheap! true story. the bike itself ran $510 on sale at REI, and came stock with the fenders, rack, and even a front wheel generator/light setup that i sold for $100, for a net cost of ~$2100.
i don't anticipate this being a financial windfall - i have a bus pass already, and previously was commuting the vast majority of the time on my road bike, the bus, or some combination thereof. however, i do think this will allow me to reduce gasoline usage even more, and it will allow me to make my commute to the hospital at all hours quicker and with less effort if i'm tired, and that's worth it to me. also note that my electricity is 100% renewable thanks to an opt-in program through seattle city light...
on the other hand, if you're hard core enough (or your city is flat enough!) to get by on a fixie, cross bike, or regular roadie without electricity, then bully for you.
shikataganai is offline   Reply With Quote
Old 05-09-2008, 02:12 PM   #2
PDT166
Member#: 53787
2006 Mazdaspeed6
Black Cherry Mica
You spent $2110 on that?!?!
PDT166 is offline   Reply With Quote
Old 05-09-2008, 02:14 PM   #3
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
boat, dirt bikes, bobcat
moar pics... where is the drive??
STR8OUT is offline   Reply With Quote
Old 05-09-2008, 02:15 PM   #4
dmpi
Member#: 49987
04 STI
BLUE/SILVER
Man that is so cool! The way the motor is packed on the hub, suggests that it must have some pretty high torque. How long does the batteries last before it need to be recharged? How much weight do you think you added to the bike?
dmpi is offline   Reply With Quote
Old 05-09-2008, 02:16 PM   #5
shikataganai
Member#: 92634
the battery alone was $900, as you no doubt read. decent bikes aren't cheap. decent electric stuff isn't cheap either.
of course, if you don't mind total crap (both on the bike and electric sides) that you'll no doubt leave in your garage once it dies, then walmart has an electric bike for $350. for that you get 1/3 the usable battery capacity, about 1/6 the power, and none of the niceties of a non-dept store bike.
http://www.walmart.com/catalog/produ...uct_id=8467096
Old 05-09-2008, 02:18 PM   #6
mannac
Member#: 161038
2014 FiST
get a scooter/motorcycle if you're going to spend that kind of cash. That's just a waste.
mannac is offline   Reply With Quote
Old 05-09-2008, 02:18 PM   #7
hkerekes
Member#: 66310
2015 korean muscle
Is it AWD?
Will it do a burnout?
hkerekes is offline   Reply With Quote
Old 05-09-2008, 02:19 PM   #8
alacrity024
Review Crew
Member#: 49476
lucky..
you take it off any sweet jumps?
alacrity024 is offline   Reply With Quote
Old 05-09-2008, 02:25 PM   #9
shikataganai
Member#: 92634
that's all i have at the moment. real camera is up north with the girl, and cell phone camera doesn't take good pics up close (doesn't really take good pics from afar, either ). the motor is within the front wheel's hub.
yeah, the torque is quite high, as is power: i've seen 1300W peak so far on a steep hill. 1 hp = 750W for reference.. i have a home made torque arm in place: a 6" 10mm crescent wrench secured to the front axle flats and the fork using a cunning assortment of 2 hose clamps and a ziptie...
i use about 15-20 Watt-hours (Wh) per mile the way i ride, which includes pedaling, of course! the battery is a 48V 12Ah lithium. Wh = V * Ah, so the battery theoretically has 576 Wh. in reality i'll probably get 500 Wh out of it, so 20-25 miles is the range before recharging.
added weight is a lot, on the order of 35 extra lbs. you don't want to do this to a bike you like for being a bike, if that makes sense.
here's the power and torque curves for the motor in question (Crystalyte 407) hooked up to a 48V battery with a 35A controller:
that i'm seeing peaks higher than the graph indicates that i'm going over 35A, i think.
how to interpret the graph: to push a typical rider and bike along at 25 mph on flat ground takes 500W more or less, with aerodynamics (tucking), tire choice and pressure, and other factors making this a very ballpark figure. notice that this motor is just above 500W at that speed. this is why top speed on flat in a tuck is right around there.
Old 05-09-2008, 02:31 PM   #10
shikataganai
Member#: 92634
there are several reasons why i didn't get a scooter or motorcycle:
- no license requirements or registration fees
- less riding gear
- can park legally anywhere a bike can
- can stash the bike on the bus bike racks to take advantage of seattle's good public transit system
- no gas bill! (high up front cost, but cost per mile is miniscule if you don't count battery costs: $0.001/mile so far by my calculations)
and, very important to me personally:
- not spewing out emissions. motorcycles and mopeds, especially 2-stroke ones, are horrible in this regard. sure, they might have low CO2, but all the smog-forming (and asthma causing) pollutants are an order of magnitude higher than a car, let alone an electric vehicle. i'm in the NW, remember, so my power is largely hydroelectric.
Originally Posted by O2wrx View Post
Is it AWD?
it is technically AWD. my legs power the back, electricity up front.
Old 05-09-2008, 02:31 PM   #11
PDT166
Member#: 53787
2006 Mazdaspeed6
Black Cherry Mica
I would get one of these and pocket $500.
Portland
Tricross
XRs
Old 05-09-2008, 02:36 PM   #12
shikataganai
Member#: 92634
Portland
Tricross
XRs
you're missing the point. i already have a nice road bike that i have been commuting on for the last 7 years (see below). this electric bike is a whole different ballgame, a vehicle in between a bike and anything powered by gas.
Old 05-09-2008, 02:44 PM   #13
2K1 Carbon Blue
Member#: 70903
so how does that battery recharge? please excuse my noob question.
2K1 Carbon Blue is offline   Reply With Quote
Old 05-09-2008, 02:49 PM   #14
shikataganai
Member#: 92634
not a bad question. i turn the controller off, unplug the battery, and then bring it inside with me to steal electricity from any free outlet (or non-free if at my house ). the charger is about as big as a laptop's power brick.
the battery is a big brick inside the rack trunk, btw, not the black thing on the downtube. that's the motor controller on the downtube. if you look closely in front of the rack trunk you can see the red Anderson Powerpole connector of the battery sticking out into the air...
Old 05-09-2008, 02:52 PM   #15
Calamity Jesus
Member#: 44501
that 's, like, your
alternate facts, man.
So, what happens when you roll over something slick (manhole, paint, greasy puddle) while trying to put 1300W of power to the ground with a wrong-wheel-drive bicycle?
Old 05-09-2008, 02:56 PM   #16
2K1 Carbon Blue
Member#: 70903
picture the Iraqi Drift Team video clip
Old 05-09-2008, 02:58 PM   #17
shikataganai
Member#: 92634
the tire slips, duh. bicyclists and motorcyclists have to be wary of the road surface just as part of riding. it's not a big deal, especially since i'm typically only drawing 100-400W of power.
Old 05-09-2008, 03:00 PM   #18
Matt A
This space for rent
Administrator
Member#: 15382
. 2005 OBXT LTD
2017 Chevy Bolt EV
Matt A is offline   Reply With Quote
Old 05-09-2008, 03:04 PM   #19
hkerekes
Member#: 66310
2015 korean muscle
Default hahahaha
Originally Posted by Satan View Post
I thought of that at first but was too lazy to find some pictures.
Old 05-09-2008, 03:15 PM   #20
jasonallenross
Member#: 125978
2002 WRX Wagon
That is a really neat project, it's very obvious that you really got the details down. Good work, awesome tinkering. Have you considered submitting details to something like MAKE magazine?
As for the naysayers, $2K isn't really all that money in bike-land, and this one provides a hell of a lot of functionality for daily use. Not to mention the electric motor and battery likely require minimal amounts of maintenance and upkeep compared to an internal combustion engine.
jasonallenross is offline   Reply With Quote
Old 05-09-2008, 03:29 PM   #21
shikataganai
Member#: 92634
thanks. someone gets it!
there are actually a lot of similar rides by users on endless-sphere.com/forums . mine is one of the cleaner ones since i actually have decent taste in bikes to begin with, and because i started out with LiFePO4 instead of mucking around with SLA junk.
Old 05-09-2008, 04:35 PM   #22
Shoobie
Member#: 84585
2002 WRX Sedan
That's pretty cool! I wouldn't personally spend that kind of money on something like that, but I'm not in to bikes (I'd rather ride a Ruckus). Good work!
Shoobie is offline   Reply With Quote
Old 05-10-2008, 11:00 AM   #23
shikataganai
Member#: 92634
i thought about this last night and realized my error. although i'm seeing 1300W (1400W yesterday even) drawn off the battery, that's not the power i'm getting on the road. this occurred on a steep hill where i was under 10 mph even with full assist and me pedaling like a maniac.
at those speeds my non-geared hub motor (some have internal gearing and behave differently) is about 40% efficient. thus i was getting maybe 600W to the ground, and was dissipating 800W as heat.
i'll still gladly take 600W up hills, though, not to mention the peak of ~850W to the ground around 17 mph. it's a kick.
ok, time to ride it some more: heading off across town to the hardware store to get metal. going to try to fabricate a holder for the battery that'll mount along the downtube, to get the 18 lbs of lithium more central and much lower than on the rear rack...
Old 05-10-2008, 11:08 AM   #24
Brad Pittiful
Member#: 34931
. Super bowl LII
Champions!
cool fabrication...congrats to you...good luck with it
Brad Pittiful is offline   Reply With Quote
Old 05-10-2008, 11:14 AM   #25
Rally Medic
Member#: 28249
1998 Outback Sport
Dirty with some mud flaps
thats awesome keep it up. im far to fat for such action 6'5 320
Rally Medic is offline   Reply With Quote
Electric bike goes 0-60 in 1.5 sec, sets new record George71 Off-Topic 10 04-11-2007 09:44 PM
My new bike has more wheel travel than my car. biggreen96 Off-Topic 18 05-02-2005 09:02 AM
New Pix. My friends' bikes. My car. 56k perish. xfactor834 Off-Topic 15 12-01-2003 03:21 PM
Pics. My friends' bikes. My car. 56k suck it. xfactor834 Off-Topic 7 11-29-2003 04:48 AM
Help! My woman found my electric guitar and amp! ! Rich L Tri-State Area Forum 18 03-20-2001 04:08 AM
