View Poll Results: would you ride it around town? | |||
yes | 30 | 60.00% | |
no | 10 | 20.00% | |
wat | 10 | 20.00% | |
Voters: 50. You may not vote on this poll |
05-10-2008, 11:54 AM | #26 |
Member#: 1925
RMIC
Vehicle:01 A4 89 944s2 13 Speed 3R 99 Sprint |
I think scooters are sooooper gay, but I'd rather have a scooter in this case
05-10-2008, 12:20 PM | #27 |
Member#: 14611
I think that is pretty sick.... and seems to be well engineered.
You mentioned that the batteries are in the 'trunk' looking thing in the back... is the whole thing one big battery? I would think that makes the bike very top-heavy. They couldn't be set lower in the bike? Possibly even using a couple of smaller batteries instead of one big one? I am especially impressed by how 'stock' the bike looks from afar (minus the trunk of course). |
05-10-2008, 03:28 PM | #28 | |||
Member#: 92634
RMIC
i already outlined practical reasons above why i didn't want a scooter, but an additional one was that it'd be no better for my health (and worse for the environment) than driving a car. i'd rather drive an early 90s civic hx and get 35+ mpg and be warm and dry in rainstorms than putter along in the wet on a 50cc scooter at 80 mpg. this gives me a third option, and that's its whole point. Quote:
with this new bracket, Hazdaz, the battery will live in the main triangle where it rightly belongs. weight that's low and central is much better. as it is now the bike is a pain to move about by hand in the garage, as it wants to fall over and flip at the slightest provocation with all that weight up high. some people do use smaller batteries, and the truly inventive will do things like fill their fork and frame tubes with batteries. i don't trust my ability to not electrocute myself through the frame enough to try something like that. |
05-10-2008, 04:09 PM | #29 |
Member#: 94524
So how does the motor work, something spins inside that metal thing at the hub and the inertia spins the wheel to??
05-10-2008, 07:13 PM | #30 | |
Member#: 92634
RMIC
i ended up trying a few battery mounting options today. above is the second version. steel plate with angle brackets and side supports. secured to the water bottle holder bolt bosses. was met with immediate failure: water bottle holder bolts were too flimsy to torsional stresses, the battery itself barely fit in the triangle, and the whole assembly was too wide, causing the cranks and my legs to hit it every revolution. came off after only 5 feet of riding... the third version was also short lived: the third version, used only for one ride, from home to REI. the battery itself is huge! here it is strapped directly onto the rear rack, with a super-strong (too strong, actually!) bungee cord on top for good measure. note the waterproofing job on the motor controller, now bolted with plates to the rack. bit more theft resistant this way. at REI i bought a Ortleib Bike Shopper waterproof pannier. the zipper is the same kind on my old drysuit. sweet. the battery itself fits inside nicely, and seems happy to be in its new home. mounted up to the right side of the rack. the cord from the controller on the left to the bag just reaches. [part 1 of 2, too many images] |
05-10-2008, 07:14 PM | #31 |
Member#: 92634
RMIC
[part 2 of 2, too many images]
a view from the rear. you can see the cord snaking from the left, under the rack, and into the bag, where it attaches with the battery. yes, the bike now has more weight on the right than the left. it's not that big of a deal when you're riding. i think we have a winner: |
05-10-2008, 07:26 PM | #32 |
Member#: 92634
RMIC
in other news, over 57 miles (21.5 of them today alone!) i'm averaging just under 14 Wh/mile. what does this mean? it means i've used about 0.78 kWh to recharge the battery. keep in mind that i recharged it at the hospital, too, stealing their electricity... it's not a big deal, however, since the total amount of electricity is about 5 cents here in the pac nw.
that'd make cost per mile about $0.0009.* (* if you conveniently ignore up front costs and battery replacement down the line. ) |
05-10-2008, 08:06 PM | #33 |
Member#: 14611
If only you could recharge the battery while slowing down / coasting, you could get away with a much smaller battery.
Still interesting setup, but I think this is where multiple smaller batteries would come into play... to at least equalize the weight left-to-right on the bike. BTW, where is the accelerator? Is it like a motorcycle in which you twist your wrist? (can't tell from the photos) |
05-10-2008, 08:22 PM | #34 | |
Member#: 92634
RMIC
regenerative braking isn't that effective on small vehicles such as bikes+riders. the majority of energy is spent fighting wind resistance, and there's not much kinetic energy to recover because the bike+rider system's mass is an order of magnitude (if not more) lower than that of a car. it's possible, but only reduces consumption by maybe 10%. (my setup does regeneration but only if you're coasting down a hill at over 30 mph . i can confirm that it works fine and is a negligible energy saver.) you're right, however, in that i could have gotten away with a smaller battery. right now i'm doing 14 Wh/mile at around 17.5 mph average speed, that's both up and downhill. going by the theoretical capacity of my pack that's a 41 mile range. (more like 35 in reality, and it'd take all night to recharge after such an affair.) when i regear the bike i'll probably increase my cruising speed to 20 if not closer to 25 and thus my energy consumption, but i'll still probably have 30+ miles. i don't see myself doing 30 miles every day... oh well. light/partial discharges will probably help my expensive lithium battery pack last longer. |
05-10-2008, 09:26 PM | #35 |
Member#: 135173
SCIC
Vehicle:2014 Audi SQ5 White |
It's FWD.
05-11-2008, 01:28 AM | #36 |
Member#: 92634
RMIC
05-11-2008, 01:50 AM | #37 |
Member#: 94524
what if it gets stolen and/or stripped??? What anti theft devices are on it?
05-11-2008, 01:56 AM | #38 |
Member#: 95459
Vehicle:the activity level of AutoX is > than F1 |
05-11-2008, 02:04 AM | #39 |
Member#: 92634
RMIC
the motor controller is bolted to the rack with metal backing plates. the battery (in "the big chrome purse") comes with me. if someone wants to steal my $12 LED flasher up front then bully for them. otherwise it gets locked up like my other bikes, with a cable run through one wheel and a u-lock securing the other wheel to the frame.
05-12-2008, 12:21 AM | #40 |
Member#: 162636
SWIC
I like the concept but the thing looks rigged and does not seem cost effective.
05-12-2008, 12:33 AM | #41 |
Member#: 121092
International
Vehicle:LOOK OUT BELOW! Re-entry is a &!^%# |
Do you ride it in the rain?
05-12-2008, 12:57 AM | #42 |
Member#: 45392
What a hideous looking mess. I dig the "dyno chart" though.
05-12-2008, 01:08 AM | #43 |
Member#: 90539
South East
Vehicle:My BOV goes COVFEFE! |
Is there a dccd option, lol? Would be nice to use in town, free outlets wouldn't last long though. Businesses would catch on quickly and try to prevent us from sponging energy. Solar charging would be a good supplement though.
05-12-2008, 01:20 AM | #44 | ||
Member#: 92634
RMIC
actually, now that i think of it, i may well recoup the money: parking costs $4.25/day at the hospitals i'll be working at next year, and i'll be there 6 out of 7 days per week, 50 weeks out of 52. that's 300 days, so $1275 if i did my math correctly. it's quite conceivable that this saving + less depreciation on the car through less miles + less gas in its own right could come close to my initial purchase cost. Quote:
with regard to stealing power, no one should really care when it's on an individual scale: so far i've used just over 1 kWh to ride 70 miles on this thing. that's about 6 cents of electricity here in the pac NW. yes, i do -- logged 12.66 miles in seattle's finest rain today, for example, all between 18-30 mph, pedaling from a stop to ~10 mph then only intermittently pedaling afterwards when necessary on steep hills (7% grade requires some help). i waterproofed the controller (note the plastic bag on the rear shot ), electrical taped all the connections, and the battery itself lives inside that waterproof Ortlieb pannier. while i'm a decent cyclist -- i've done a century, used to race cross, dh, and trials, etc. -- there's absolutely no way i could zip up a 4% grade at 20 mph as i did today _without pedaling_. i'm not a cat 1 racer, and chances are, neither is anyone else reading this thread. Last edited by shikataganai; 05-12-2008 at 01:26 AM. |
05-12-2008, 01:26 AM | #45 |
Member#: 121092
International
Can you put another battery pack on the opposit side and double your power output?
05-12-2008, 01:32 AM | #46 | |
Member#: 92634
RMIC
electrical primer 101: hook two 48V 12Ah batteries as i have in series and you'd have a 96V 12Ah pack. that'd be a huge bitch. it'd make more sense to split a pack like mine into two and run each 48V 6Ah segment in series, yielding 96V 6Ah. (the metric for a pack's capacity is Wh, watt-hours, which you get by multiplying the voltage by the amp-hour rating. thus 96V 6Ah is the same Wh as 48V 12Ah.) |
05-12-2008, 11:11 AM | #47 |
Member#: 90539
South East
parallel two batteries for higher current and change your gearing to extract more wattage for the same speed?
05-12-2008, 11:22 AM | #48 | |
Member#: 92634
RMIC
regearing is not an option with hub motors... that said, some people use chain or belt drives so as to be able to regear for this purpose, and also because you have the potential of using motors and controllers from the R/C world. (R/C plane motors, for example, can't be used without such a reduction system since they spin at, say, 10,000 rpm. you want 300 rpm or so at the wheel.) anyway, here are two additional power charts depicting the changes with different current along with my current 48V 35A setup: 407 motor (my motor) at 20A 407 motor, 35A (my setup) 407 motor, 50A Cliffs Notes: 48V and 35A is a good compromise between torque, power, and efficiency for my setup, and my LiFePO4 battery will gladly flow 40A all day long (until it is discharged, that is) |
05-12-2008, 12:04 PM | #49 |
Member#: 23131
Vehicle:2023 Mazda3 AWDTurbo Metallic Gray |
But can you make a computer survive aquatic conditions? (Flobots)
05-12-2008, 03:54 PM | #50 |
Member#: 132408
Vehicle:2009 Lamborghini Gallardo Supperleggera |
...wat.?
Electric bike goes 0-60 in 1.5 sec, sets new record | George71 | Off-Topic | 10 | 04-11-2007 09:44 PM |
My new bike has more wheel travel than my car. | biggreen96 | Off-Topic | 18 | 05-02-2005 09:02 AM |
New Pix. My friends' bikes. My car. 56k perish. | xfactor834 | Off-Topic | 15 | 12-01-2003 03:21 PM |
Pics. My friends' bikes. My car. 56k suck it. | xfactor834 | Off-Topic | 7 | 11-29-2003 04:48 AM |
Help! My woman found my electric guitar and amp! ! | Rich L | Tri-State Area Forum | 18 | 03-20-2001 04:08 AM |
