12-01-2020, 11:47 AM | #1 |
Member#: 273267
RMIC
Vehicle:2011 STi / 98 LSTi |
2011 Blurple STi Garrett G30-900 .83AR
Event: EmTron install this summer - Location: MoFab in Parker, Colorado Weather: - Ambient Temp: -°F Elevation: 5869 feet above sea level Tuner: Nick at MoFab in Parker, Colorado Dyno Info: Dynojet Car: 2011 STI Transmission: Stock 6 speed Gear: 4th Target Boost: 34.0psi Target AFR: Unknown Fuel: Pump E85, recorded at 83% Ethanol Peak HP at RPM: 672.14whp 694.54whp @ ~6300 rpm Peak Torque at RPM: 613.06wtq 629.98wtq @ ~5200rpm Baseline hp/tq for a stock on same dyno: ~260whp/280wtq Graph shows before and after GSC S2 Cams and bowl porting on head... Brushless fuel pump seems maxed at oem 13.8v Voltage upped to 14.8 Radium Dual Pump hanger & 2 Walbro 450's in now. Engine/Power Modifications: MoFab Super Low Rotated Kit (V-band up/down) Garrett G30-900.61AR .83AR + Turbo Blanket Tial 38mm Wastegate IAG Stage 2.5 Block Outfront V4 Ultra Block GSC Beehive Valvespring + Ti retainers GSC S2 Camshafts. ARP 625+ Headstuds Outfront 1/2" Headstuds Mild Bowl Porting on head Inconel Exhaust Valves ETS 3.5" FMIC Delicious Tuning Flex Fuel Mk. II Delicious Tuning Stumble fix TGV Deletes Secondary Airpump Delete KillerB Holy Header (V-Band) iWire Speed Density Cobb 3 port EBCS Grimmspeed 3 Port EBCS Tomei Expreme Ti Cat back IAG AOS GetADomTune Cyl4 Cooling KillerB Oilpan + Pickup + Windage Tray Radium Fuel Rails + FPR + Fuel Lines DW Brushless Fuel Pump (Hardwired) Radium Dual Pump Hanger & 2 Walbro 450's DW1500CC ID 1700X Injectors COBB Accessport V3 Driveline Modifications: Perrin Pitch Stop Competition Clutch Organic Twin Disc XClutch Sprung Ceramic Twin Disc CC Ceramic Twin STi GroupN Motor/Trans Mounts IAG Comp. Engine Mounts & Torque Solutions Solid Trans Mount TiC Shifter Bushing Kit Suspension Modifications: Fortune Auto 510 Coilovers 10k F 12k R Swiftsprings 2015+ STi Steering Rack Power Steering Cooler Whiteline Swaybars Whiteline Bumpsteer kit Perrin 20mm Wheel Spacers Wheels/Tires: Sparco 2015+ STi BBS Vredestein 235/45/17 Hankook Ventus RS4 245/45/18 Bridgestone RE71RS 255/40/18
Last edited by PotatoFlakeSTi; 03-15-2024 at 10:57 PM. Reason: Adding the list of mods |
12-01-2020, 02:26 PM | #2 |
Member#: 508105
Vehicle:Link G4X flex tuned 02' EJ205 20G 6MT wagon |
I bet this car is wacko when you get into full boost which seems to come on nice and quick. Lovely build.
12-01-2020, 02:43 PM | #3 |
Member#: 130990
Vehicle:06 Red Ltd.Wagon Dom 1.5xtr JJ tuned |
I have an IAG Stage 2 block with a Dom 1.5 and a flex fuel build. Recently my heads flat wore out, and when I had the new heads I thought "what the heck" and installed some Kelford 199-b's along with stronger springs and valves.
With the stock cams it would just touch 355whp/370wtq (this is on a Mainline dyno where a new STI reads 200whp/tq) and then drop right off. What a difference with the cams: the car gets to 370/370 now and just holds all the way to the 7400rpm limit. I'm still getting used to shifting near redline, whereas before there was really no point in revving it past 6600rpm. Additionally, it's making this increased powerband with a significant boost taper up top. The factory cams needed 24 psi boost the entire way, where the Kelfords start at 24 psi but only need 20psi up top. Way more efficient when the revs are up. You want 7800rpm? No problem! Of course this is just an example; many would prefer a different brand of camshaft, but so far I'm happy with mine. Last edited by Dave D.; 12-01-2020 at 02:52 PM. |
12-01-2020, 09:02 PM | #4 |
Member#: 420458
Vehicle:07 WRX STI Urban Grey |
Amazing the turbo can make power to almost 7000rpm with such a small rear housing! Shows an efficient turbine wheel design! Be interesting to see the results if you put cams in it
12-01-2020, 10:19 PM | #5 | ||
Member#: 273267
RMIC
Going back and forth between the S1's at .266 and S2's .272... But there's a whole lot more to it than that, most of which is beyond my understanding... I'll ask my tuner about Kelfords as well. |
12-14-2020, 05:04 PM | #6 |
Member#: 170306
Looks awesome man, excited to get mine done here soon. I have a similar setup with GSC S2s (272)s and a G30-900 w/.83ar. Should be getting dyno tuned here in January and can have some results for you as you make your decision.
-Alex |
12-18-2020, 12:38 AM | #7 |
Member#: 508105
This kinda me want to consider a G series over an EFR..... Hmm.....
12-19-2020, 01:13 PM | #8 |
Member#: 338128
Vehicle:2013 WRX SBP |
Very nice, terrific power for a street car. Gotta love the power e85 has to offer.
Either set of cams will be a nice upgrade over stock, just have to decide how much you're willing to accept moving the curve to the right. More cam, more (potential) power, more lag. Looks like you were at Bandimere, any time slips? |
12-23-2020, 10:38 AM | #9 |
Member#: 369934
Vehicle:2018 STI Limited Heritage Blue |
That dyno chart looks unreal. Incredible power.
12-25-2020, 02:32 PM | #10 | |
Member#: 273267
RMIC
60ft was around 1.68, on Goodyear Eagle F1 Assymetric 2 tires with about 35k miles on them. Edit: 124mph Last edited by PotatoFlakeSTi; 12-25-2020 at 02:58 PM. Reason: mph |
01-05-2021, 12:03 PM | #11 |
Member#: 247823
BAIC
Vehicle:2007 STi limited SWP |
I'd like to see a dyno graph from Cryotune.
01-06-2021, 11:53 AM | #12 |
Member#: 273267
RMIC
01-06-2021, 11:57 AM | #13 |
Member#: 395275
RMIC
Vehicle:2012 STi SWP |
wow thats a tiny hotside for our altitude.
01-06-2021, 12:07 PM | #14 |
Member#: 273267
RMIC
We'll see how she flows at higher RPM with Cams... Might move to a .82AR but that'll really depend on how the curve looks.
Not building for Drag Racing in particular, so as long as it's still 'usable' power past 7000 (say 400wtq'ish) I'll be happy |
01-06-2021, 12:15 PM | #15 |
Member#: 395275
RMIC
Yeah that dyno graph looks really nice for street driving as well. I think I'd prefer the 1.01 with this size turbo, but you'd likely lose some spool.
01-06-2021, 06:17 PM | #16 | |
Member#: 247823
BAIC
I should have done it myself but I decided to change up my setup before making my way over to Mofab. |
01-07-2021, 05:27 PM | #17 | |
Member#: 395275
RMIC
I got dyno tuned at Edge Autosport and its a dynomite dyno(which Alan says stock Sti's usualy baseline around 200 whp on these), and my car put down 461 whp 461 wtq at 29 psi on an EFR 7163. Curious what lulz mine would put down on a dynojet. |
01-07-2021, 06:15 PM | #18 |
Member#: 273267
RMIC
Right, well... if you want to pay for a baseline at Cryotune I'm game.
01-07-2021, 06:30 PM | #19 | |
Member#: 130990
Easy 5's. |
01-07-2021, 11:33 PM | #20 |
Member#: 366241
South East
Vehicle:2009 09 wrx delivery Dgm |
Id go .82 in a heartbeat. You wont lose much spool as you think, 250-500 rpms at most. And you'd make more power up top and hold it longer. Still looks insane boss, enjoy it!
01-09-2021, 12:10 AM | #21 | |
Member#: 247823
BAIC
Nah, come do a baseline when I wrap up my new mods/retune and we'll compare! Should be March/April timeframe. |
01-12-2021, 12:37 PM | #22 |
Member#: 395275
RMIC
[quote=pigboat_2;46495020]Cryotune's dyno hurts! 5250 keeps adjusting their calibration so it hasn't been consistent for me, but it's been over 4 years since I've had a car on their dyno and it was new to Mike at the time.
Yeah my old 60lb a min turbo put down 270/280 at 21 psi on 5250's dyno I was like oof, time to sell haha |
01-13-2021, 10:08 AM | #23 | |
Member#: 247823
BAIC
The green (61 lb/min) on my friend's STi at 20-21 psi on E85 at Cryotune made 365, but will take down pretty much anything that makes up to 430. Same w/my car, love it when people say their 30r makes 550 and they don't understand why they can't keep up haha. Numbers are all relative. |
01-14-2021, 03:53 PM | #24 | |
Member#: 395275
RMIC
Yes, it was pump gas 91 |
01-17-2021, 01:33 PM | #25 |
Member#: 472984
What a gorgeous build... haven't seen that front bumper. Is it custom? Over the shelf?
Incredible work |
