01-16-2009, 01:06 AM | #1 |
Member#: 132301
Vehicle:07 WRX Limited 6MT 20G - SWP - SOLD |
Bypass Oil Filter setup on your Subie
I'm exploring the option of installing a Bypass Oil Filter setup on my 07 WRX.
I searched here, BITOG, & Google, trying to find someone else with a turbo Impreza, Legacy, FXT, etc that is running a Bypass setup. No Luck. So - any of you guys running one yourself? Or know of anyone who's running one? Also, Should I be concerned that my stock oil pump might not be up to the task? And please dont start with "why do you want a Bypass..." Because Bypass = Straight Ballin
01-16-2009, 01:56 AM | #2 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
go dry sump or go home
01-16-2009, 02:22 AM | #3 |
Member#: 132301
Not exactly the response I was looking for, but thank you Uncle Scotty.
01-16-2009, 04:19 AM | #4 |
Member#: 132301
bluesubie - I'm expecting some good information out of you!
01-16-2009, 10:26 AM | #5 |
Member#: 2133
Vehicle:2005 STi WRB/Gold 2005 S4 Avant |
01-16-2009, 11:16 AM | #6 |
ForumWars Winner!
Member#: 196948
TXIC
Vehicle:2003 Forester Silver |
nah, he's just the loudest
-James, 7 year BITOG member |
01-16-2009, 11:57 AM | #7 |
Member#: 141672
All your doing is adding unnecessary weight to your vehicle
Ron, what you need to do is use some ingenuity buying the correct parts and install it yourself in a professional manner. Using the correct viscosity imo has the biggest impact on an oil pump's lifespan. Using a straight 30 weight when it's three degrees out would torture it while an 0 or 5W whatever would have no impact.
Still a complete waste unless you want to go forever on the same oil and/or want to put a ridiculous amount of miles on the engine. Your exhaust valves of something else will kill it before you realize a benefit other then extended oil changes. If someone makes a larger capacity oil pan for our car, I would rather go that route. |
01-16-2009, 02:14 PM | #8 |
Member#: 767
Vehicle:04 FXT 20 OB Onyx XT |
I've had such great luck with OEM filters that I haven't really looked into anything else. Other than using Purolator filters maybe two or three times in a 97 OBS and a 99 OB I've always stuck with OEM. Like you, I'm currently running an Amsoil oil filter and I think that Dyson recommends them to his customers. I've seen a few posts about bypass filters, but I don't think anyone ever followed through because of the hassle of trying to find a mounting spot. Andy - I just mentioned you in a bitog thread because a WRX owner is switching to PP 5W-30 in a WRX at 1,000 miles. -Dennis |
01-16-2009, 06:15 PM | #9 | ||
Member#: 132301
I figured that you would chime in too. I havent been into the BITOG / oil thing for too long, so I still have alot to learn. Whats your thoughts on a bypass setup for my WRX?
I really like the idea of the Bypass because I drive ALOT and really want to try getting a TON of miles on my engine, with a conservative stage 4 setup. So I figured that a bypass setup along with Amsoil SSO will help me get there. If I do, I'll pick up an Amsoil (23) bypass and be all said & done for under $300. Quote:
I'm sure my car is doing fine running SSO & Amsoil Oil filters... Bypass would just allow me to run cleaner oil, longer. Probably not necessary, but maybe I'll be the Subaru Bypass pioneer. |
01-17-2009, 12:42 AM | #10 |
ForumWars Winner!
Member#: 196948
TXIC
Bypass has always been a good thing for over the road truckers and long drains, so it can't be that bad. Cost is a little high, but nothing compared to the useless crap people put on their cars You will also add 1-2 qts of capacity depending on filter size, length of oil lines, etc. which is a good thing for longer OCI's and keeping oil temp down.
I actually want to do a bypass setup on my Legacy, but with almost 200K I am not sure this engine will stay in it much longer (rebuild, rebuilt longblock, or something crazy...). Let me know what you come up with. I was just thinking the AMSOIL route because it's there and fairly well put-together. I'm sure you could save a few pennies making your own lines and fittings and just buy their filter block. |
01-17-2009, 01:19 AM | #11 |
Member#: 132301
Thanks JamesWilson!
I agree, for the money, its probably almost more beneficial than some of the other things I've done... I'm gonna get the car up on the lift soon to check out possible mounting locations. I'll keep you updated. |
01-17-2009, 04:50 PM | #13 |
Member#: 147776
NWIC
Vehicle:2001 Forester 2013 Scion FR-S |
What's a by-pass oil filter setup? Oil filter relocater?
01-17-2009, 05:06 PM | #14 |
Member#: 79222
W. Canada
Vehicle:'09 STi 297.5 WHP Blue |
If you are going to put on 100,000 Miles each year go for it... Other than that, I don't see any benefits per cost. JMO
01-17-2009, 05:55 PM | #15 |
Member#: 147776
NWIC
01-17-2009, 06:47 PM | #16 |
Member#: 132301
Here is a pretty good explanation.
If you google for "bypass oil filter" and other variations of that, I'm sure you'll find other explanations as well. Last edited by RonJitsu; 01-18-2009 at 09:00 AM. Reason: I was mean, I'm sorry. |
01-17-2009, 06:52 PM | #17 | |
Member#: 132301
I know its not needed, but I like the idea of having clean oil in my engine at all times. Might help me get some extra miles out of my WRX, since I'm on track to have 200k within a few more years. |
01-17-2009, 07:04 PM | #18 |
Big Ron
Super Moderator Member#: 18062
Good idea, I've been here for years and never seen a Subaru person run a bypass though I've recommend it to hundreds of people. It's usually the annoying people that want to nit-pick oil brand/weight/type for hours and when I suggest they get off the wallet for a bypass set-up, they shut their pie-holes. Good for you! Please post a detailed pics thread when it's all done.
01-17-2009, 11:14 PM | #19 | |
Member#: 132301
You can count on a pics thread when its all done! |
01-17-2009, 11:27 PM | #20 |
Member#: 16200
dunno if it is possible but what if you hacked the stock 'oil cooler'...you may be able to use it or parts of it to make a bypass???
01-18-2009, 02:52 AM | #21 | |
Member#: 132301
I wonder how much it flows. Sofar I'm thinking of ordering up one of these: |
01-18-2009, 07:33 AM | #22 |
Member#: 89757
International
Vehicle:2004 Impreza STI Black & dirty |
01-18-2009, 08:47 AM | #23 |
Member#: 132301
- Nah, been off the meds for a while now.
Its not like me to be like that at all. But he asked the same question twice in this thread just one hour apart. (post #13 & #15) Edit: I edited my other post & gave a good answer. Last edited by RonJitsu; 01-18-2009 at 09:02 AM. |
01-18-2009, 09:12 AM | #24 | |
Member#: 89757
International
Interesting idea, but I guess only benefits high mileage drivers. |
01-18-2009, 10:45 AM | #25 | |
Member#: 132301
But the main reason I like bypass: I really like the idea of having the cleanest possible oil in my engine at all times. Regular full-flow filters can only remove contaminants that are 15-20 microns or larger. Bypass filtering removes contaminants as small as <1 micron. I know that contaminants that small (below ~15 microns) probably dont cause that much wear... But I'm hoping that (almost) contaminant free oil will help me get a huge amount of miles out of my engine... (assuming I dont blow it by driving like an asshat) |
anybody here mess with a bypass oil filter? | sky44 | Service & Maintenance | 4 | 06-28-2008 03:08 PM |
bypass oil filters | zentrickster | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 0 | 05-07-2008 11:43 PM |
Bypass oil filters | zentrickster | Service & Maintenance | 2 | 05-07-2008 11:41 PM |
ByPass Oil Filtering System- Mounting Location? | IN YOUR MOUTH | Service & Maintenance | 6 | 05-25-2003 08:30 PM |
any using bypass oil filters/filtration? | bigpaulo | Normally Aspirated Powertrain | 2 | 06-20-2002 12:58 PM |
