Welcome to the North American Subaru Impreza Owners Club Friday February 23, 2018
Old 03-10-2016, 07:06 PM   #26
binny
Member#: 198108
MY98 WRX
I'm considering doing this - anyone running decent rubber with this mod ?
I have 255's at the moment with 7 degrees of castor in a GC8 turning when stationary (car off) is "quite" difficult how much difference without the fluid in the system ??
binny is offline   Reply With Quote
Old 03-11-2016, 04:31 PM   #27
RavensFan7
Member#: 346388
2001 Ej205 Impreza L
SRP
The widest I had were 215's that ran a bit wide (think star specs)....but nothing as wide as a 255.
There is quite a difference without the fluid, lines, and pump. Definitely noticeable. Being 100% stationary will always suck with no p/s, but parking lot speeds are very tolerable if the delete is done right.
How much does your car weigh?
Any weight reduction off the front end helps.
RavensFan7 is offline   Reply With Quote
Old 03-14-2016, 01:11 AM   #28
binny
Member#: 198108
MY98 WRX
It's about 1240kg (not sure how that converts) no real weight reduction (just the battery moved, aircon deleted and random brackets) I will most likely ditch the brake vacuum assist at the same time while the engine is out so a couple of kilos there as well
Old 06-30-2016, 01:45 PM   #29
kyleburlish
Member#: 227047
1999 RSTI
Rally Red (Evo Color)
I have an STI swapped RS so I have the 06 STI rack. Super sticky toyo proxies 245. I have been running just the belt bypass. Its sweet at highway speeds and like 20-30 mph and higher. But slow speeds suck. Parallel parking isnt even worth the effort. This weekend I am looping the lines and greasing the system. We will see how that goes.
kyleburlish is offline   Reply With Quote
Old 06-30-2016, 09:42 PM   #30
binny
Member#: 198108
MY98 WRX
Cheers for the update, I'm going for it anyway (have the engine out now and will drop the rack and delete the power steering) I will drop a few tyre sizes though probably go for 235's
Old 07-09-2016, 12:49 AM   #31
2.5itim
Member#: 449745
I'm glad I found this thread, thank you all for the advice. Got my rack dropped today and tomorrow will get the loop done, greased up and reinstalled.
I won't be able to drive it till I get my engine build finished but at least it'll be done and waiting.
2.5itim is offline   Reply With Quote
Old 07-12-2016, 03:39 AM   #32
binny
Member#: 198108
MY98 WRX
Default Power Steering delete thread -- Depower your rack!
How do you get the quill out ? I thought it would just slip out after taking the housing off the rack (the two 6mm Allen head bolts)
(1998 WRX rack)
Old 09-19-2016, 12:21 AM   #33
rdrz14
Member#: 199004
04 WRX BuiltHybrid
Black & Gold
I'm pumped to try this! I have the engine out and may as well drop the rack while it's all apart. It's a weekend car that's parked on the street in the city... anyone think it's a bad idea since I have to parallel park it at home?
rdrz14 is offline   Reply With Quote
Old 02-12-2017, 03:02 AM   #34
scubieroo32
Member#: 407705
1997 Legacy Outback
So I have a 2nd gen legacy. I want to swap a 1st gen steering rack on it in the future.
Do you think it would be a good idea to do the PS delete when i get the new steering rack since i would be buying it new and it probably will not come with any fluid in it?
I would assume that it would screw the new rack up but im not too sure
scubieroo32 is offline   Reply With Quote
Old 02-14-2017, 10:32 AM   #35
RavensFan7
Member#: 346388
SRP
Slightly confused on what you're asking.
Are you concerned that the rack will be essentially dry, and just tossing in some grease won't be enough?
I can't speak for a brand new OEM rack....but I did buy a new reman unit from rockauto, and it already had some PS fluid inside when it arrived. Or some type of oil, because it was leaking out into the box.
I think you'd be fine just globbing in some grease, spinning the pinion gear by hand a bunch of times, then add some more grease. Rinse and repeat until you feel comfortable.
Old 02-16-2017, 04:03 AM   #36
binny
Member#: 198108
MY98 WRX
well I've done it - with the engine out and 255's it's not as bad as I thought (stationary obviously)
I guess I'll see how much harder it is with the engine in
Old 02-16-2017, 09:12 PM   #37
theleveler2600
Member#: 417541
OK Stupid question...
If I do the simple, bypass the pump with the smaller belt method (RavensFan7's "option 2") and decide it's any improvement and/or I like the feel for spirited driving, would it be bad for my car/rack, if I switch back and forth for several track days? (ie: Use the PS length belt and have PS for every day driving, and then switch to the short no-PS belt for track days, and then back again)
theleveler2600 is offline   Reply With Quote
Old 02-17-2017, 05:41 AM   #38
binny
Member#: 198108
MY98 WRX
You won't damage anything - however as the system (Rack & Pump) is still full of fluid you have to move the fluid + steer the car so won't "feel" what it will actually be like
probably the best way without draining would be on some winding roads that don't need any lock to lock kind of steering inputs (as you wont be pushing the fluid through the rack as fast)
Old 02-17-2017, 11:03 AM   #39
RavensFan7
Member#: 346388
SRP
Binny said it well. Just swapping to the belt will be more effort than the full delete. I can't imagine there would be any issues changing back and forth between the belts though.
What kind of "track days"?
...because I always figured autox would be incredibly hard with no PS. The lower speeds and quick tighter turns would be exhausting. Going lock to lock quickly would be difficult.
Road course track days would probably be easier to manage.
Awesome! Definitely update how it feels once it's driving.
I'm getting ready to do this to a second car. Picked up a '98 L a few months ago and it's time to start shedding some weight.
Old 02-17-2017, 11:24 AM   #40
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
swapping the belt is only meant to be a quick test for a day or two to see if you can manage without power steering before comitting to a full delete since a proper delete is a one-way street.
Titter is offline   Reply With Quote
Old 02-17-2017, 11:59 AM   #41
theleveler2600
Member#: 417541
Thanks for the advice guys!! This would be for road course tracks for me, but it sounds like it's not worth it and/or too much steering effort without doing it right
Old 04-14-2017, 04:56 PM   #42
junior1023
Member#: 223393
2015 WRX
Dark Grey Metallic
For option 3, would it be better to turn the wheel several times after removing the lines, to let fluid out before looping them or loop then to keep all the fluid in?
junior1023 is offline   Reply With Quote
Old 04-17-2017, 09:47 PM   #43
RavensFan7
Member#: 346388
SRP
If you're just looping the lines, it's best to keep some/most of the fluid in....obviously you don't want it to get too dry. Not that you would get every drop out of fluid out anyway, but the oil already has a harder time clinging to the gears inside....so the more fluid there, the less chance of metal to metal.
Even fully drained it would likely take a while to fully seize up (if ever), but could still cause more wear than normal. Either keep the fluid, or do the full thing and stuff it with wheel bearing grease.
Old 07-26-2017, 02:42 AM   #44
bjm
Member#: 87090
Is there any way to get the photos from this thread? All I get is a Photobucket message saying "please upgrade your account"
bjm is offline   Reply With Quote
Old 07-26-2017, 12:07 PM   #45
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
photobucket recently toasted all 3rd party links. users have to pay to be able to link pics to forums.
Old 07-26-2017, 09:00 PM   #46
bjm
Member#: 87090
I found if you right click and hit open in new window I can see all the images.
Old 07-27-2017, 10:54 AM   #47
RavensFan7
Member#: 346388
SRP
It's been a long time since I used Photobucket, so I figured these pics would still be good. I'll re-host them on my Flickr soon. Might be a week or 2 because my laptop's hard drive died the other day as well.
