Welcome to the North American Subaru Impreza Owners Club Wednesday July 18, 2018
Old 01-16-2017, 01:35 PM   #26
justanotherday
Member#: 461384
Default jdm ej205 swap into wrx
Originally Posted by jackassofalltrades View Post
I'm in Ohio, No emissions. Swapped JDM AVCS ej205 with the tranny and JDM matching ECU, repinned the IAperformance wiring kit - took 30 mins. (http://www.iaperformance.com/product...oducts_id=2580)
Started right up, no check engine light. The JDM engine does not have TGV's or a EGT sensor for the uppipe. Leave it unplugged, I have been running this setup for the last few months and couldn't be happier with the results.
Using the USDM ECU is a chore, just swap out the entire engine with the JDM engine harness included(not the body harness) and JDM ecu and repin the ecu and original wrx body harness with the IAperformance kit and you're good to go.
When it comes to tuning; you will need an opensource tune (tactrix cable) from a reputable company since the Cobb AP is not functional with the JDM ecu.
I got an 04 engine and tranny for 2k out the door with the ecu. Everything matted up with no trouble.
If you have any questions, let me know.
Im new here. Holping for some help? Swapped usdm ej205 to jdm ej205 with avcs ,installed i.a performance wiring kit, was under the asumption that I received a ver7 avcs jdm ecu with motor.problem car starts and runs with stock ecu, but not with the jdm ver8 ecu. When turning key , don't hear any power going to the fuel pump
justanotherday is offline   Reply With Quote
Old 01-24-2017, 08:57 AM   #27
bmodrak
Member#: 456491
Originally Posted by livid_wrx View Post
Need to wire up for AVCS, I don't think there's a port for the front 02 sensor so you'll need headers. So, new headers and wiring and tune for the tgv deletes if you're running it with usdm ecu.
Would I need the tgv delete if I don't have emission laws?
bmodrak is offline   Reply With Quote
Old 02-21-2017, 11:50 PM   #28
Spiresbuilt
Member#: 436462
2002 WRX Wagon
Jackassofalltrades. What ECU are you running? As in part#? I am sorry to be hijacking this thread. I am new here and I don't have a post count high enough to start one. I am have been searching however, I cannot find a post with the same scenario as mine. I have an '02 WRX wagon. One of my timing belt idler pulleys decided to remove itself from the engine and crashed the valves. I bought a JDM ej205 with AVCS and ECU. Once I got the motor on the stand I noticed it was "fly by wire". I am guessing that I can't use this ECU and that I will need to use my intake manifold. I want to utilize the AVCS system though. So, my question is what ECU do I need to use a throttle cable and AVCS? Do I need to swap the entire intake manifold or could I just swap throttle bodies? Again sorry for the hijack. Hoping another Ohioan, among others could help me.
Spiresbuilt is offline   Reply With Quote
Old 07-06-2017, 07:23 PM   #29
Asianjimmy
Member#: 295386
2003 Impreza wrx
Rally blue
Did the ej205 avcs swap into my 03 wrx all i did was threw my td04l, headers, accessories, and top part of intake manifold and my usdm wireharness, dropped in and it fired right up. Of course i have tgv codes but they dont effect engine performance. But you can easily use the cobb ap and get an etune to get it shut off.
Asianjimmy is offline   Reply With Quote
Old 07-09-2017, 03:51 PM   #30
Asianjimmy
Member#: 295386
2003 Impreza wrx
Rally blue
Originally Posted by Myis300 View Post
Just finished this swap you need to swap over your USDM intake manifold with harness also the exhaust manifold and the driver side cam gear and the crankshaft gear that's it. Get the motor without the avcs
Only Had to swap intake manifold and exhaust. And accessories.
Old 07-17-2017, 12:18 PM   #31
Goosenyc
Member#: 468437
Did u do anything with the coolant crossover thing under the intake manifold.
Goosenyc is offline   Reply With Quote
Old 08-07-2017, 03:21 PM   #32
Goosenyc
Member#: 468437
Just finished my swap. Only had to change intake manifold and accessories. Thanks for the help guys.
Old 08-12-2017, 03:21 PM   #33
robmobile1970
Member#: 384907
Default help on swap JDM ej205 into 06' baja turbo
The 2.5 turbo ended up with burned valves due to TD05 swap without getting a tune to balance for increased boost. Cheapest route for a swap by far seemed to be a JDM EJ205. Most of the information I got from forums and the engine importer said: Us your USDM intake manifold and up-pipe with sensors on the JDM engine and it will run fine with no codes......
I ordered and received a AVCS EJ205. When swapping over I found the JDM Camshaft position sensors (on top of the head rear of the engine) are a 2 wire sensor with 2 wire plug. I pulled these sensors and installed the USDM sensors utilizing a larger O ring as the hole is larger than on the 2.5 block.......
The engine started and it runs, but it misses and surges at part throttle and I get CPS error codes...... It also is nowhere close to the power I got with the 2.5 when it does pull clean.
Another person has explained on another forum that the JDM CPS sensor is magnetic and the USDM sensor is hall effect. He swapped in the USDM camshaft in order to make it work with the USDM sensor.
Is there another way to make it run right?
What about unplugging AVCS and CPS alltogether, will it run ok without codes?
I really don't want to pull this engine again to swap the cams. Really I want to sell this car and don't want to spend alot of time money on it. I have been told $500+ for a tune locally. I live about 1 hour south of Raleigh, NC.
Please if you have advice make sure you know. There are a lot of people on line posting what they heard from a friend say may work as if it's a fact they are sure of. If you don't know for sure please offer it as a suggestion that may work and not something definate.
All help appreciated
robmobile1970 is offline   Reply With Quote
Old 08-17-2017, 03:38 PM   #34
Andrew wrx
Member#: 473030
So if I did this swap I would have to put 2.0 heads on?
Andrew wrx is offline   Reply With Quote
Old 12-01-2017, 10:02 PM   #35
Subie4Life0117
Member#: 477639
Default Jdm ej205 into 02 wrx
Hey guys so me and my mechanic are in the middle of doing a USDM 2003 Impreza 2.5 R.S (w/ automatic trans) to a JDM 03 WRX 2.0 Liter swap (w/ automatic trans)...Iím about to purchase the JDM Wiring harness on EBay for the ECU....any thoughts, comments, or opinions that anyone would like to share? Anything major that has to be done to make sure the installation goes well and works right?
Note: The 03 JDM wrx engine is already in the chassis of the 2.5 RS....we didnít even have to get a new cross brace or anything....We cut the R.Sís crossbrace for the exact customization fit for the 03í JDM EJ205 engine. The transmission is in and everything. Just finishing up hose and wiring installation.
Subie4Life0117 is offline   Reply With Quote
Old 12-22-2017, 04:58 AM   #36
Urabaas05
Member#: 324554
2005 92x Aero
Arctic Grey
I swapped a 2001-2005 JDM EJ205 w/AVCS into a 2005 WRX. I also purchased a JDM ECU and wire harness. I did not swap the intake manifold or can gears (jdmracingmotors said I did not need to) I'm going to have my tuner install the wire harness for AVCS, because I'm not comfortable with the pinning process. My question is, do I gently drive it to him on the USDM or JDM ECU?
Urabaas05 is offline   Reply With Quote
Old 07-10-2018, 10:58 PM   #37
indyprez02
Member#: 487824
2002 Impreza WRX
Originally Posted by ToneWrx02 View Post
Stop commenting if you havnt actually done the swap.
I have actually swapped in a jdm ej205 with avcs into my 02 wrx.
I didnt plug the cams, i didnt change wires, i didnt change sprockets. Its a direct bolt on IF you get the right one.
Will you lose power because you didnt plug the avcs cams? Almost none to nothing.
How do i know? Because ive done it.
There is some jdm ej205 that do require changing parts but thats if you get older stuff and or get ome that requires new intake manifold for throttle.
Non avcs the best? God no requires more work tbh, amd the best part is you can wire up avcs super easy for 200$ if you want and get even more low end torq.
The avcs ej205 has higher compression for more low end torq.
I am trying to find a jdm 205, and i cant decide whether to get non avcs, or avcs, and with my jdm engine if i get a tune does that mean i have to run premium gas? or can i get it tuned and not have to. or if i dont tune it what will happen and will i have to run premium without a tune on a jdm 205?
Im new to knowing anything about jdm so please let me know!
indyprez02 is offline   Reply With Quote
Old 07-11-2018, 08:04 AM   #38
snow_bound26
Member#: 395793
2005 92x Aero
Are you coming from a WRX platform to begin with? If so, you should've been using premium fuel since day one as these cars are tuned for it from the factory.
As for tuning, yes you can get it tuned for a lower octane but why? You will lose power, increase chance for knock/detonation and have to be much more careful with the car as whole. Turboed cars run hotter intake temps because more air is being compressed. Higher octane runs cooler reducing the chance of knock/det events. If you want to run lower octane get an NA and you won't have to worry about it.
snow_bound26 is offline   Reply With Quote
