Welcome to the North American Subaru Impreza Owners Club Wednesday July 18, 2018
Old 08-11-2017, 09:57 AM   #1
Dieselman88
Member#: 440519
2004 Wrx
Rally blue
Default New tires but different tread front and rear cause issue?
I have a 04 WRX. I know Subarus are very sensitive to tire size and all having to match on all 4 corners. My question is do the tread patterns have to match front and rear? I bought some wheels for my car, has 4 brand new tires on it 214 45 17, tread depth is identical. The front 2 are cooper zeon rs3-a tires and the rear 2 are sumitomo tour plus lsw . Both non directional tires. The car seems very jittery now, especially on highway. Almost like it's really windy outside, idk if it's the car just following the grooves on highway or what. Didn't really seem to notice it with my other stock wheels, might just be in my head lol. Called local dealer and they said it shouldn't matter. I was just thinking with different tread pattern/grip front and rear of it would make a difference The wheels I put on are 17" stock brz wheels. Taking it into subaru today for air bag recall and alignment check.
Dieselman88 is offline   Reply With Quote
Old 08-11-2017, 10:42 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
New tires have tall tread blocks, which means lots more tread squirm than old tires. Add in that the tires you've got are on the soft/comfort side of the performance spectrum (particularly the Sumitomos) and the car will feel like it's moving around more than you're used to.
Personally, I would want 4 matching tires.
Old 08-11-2017, 10:44 AM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
While not ideal due to potential handling differences, you should be fine as long as they wear evenly and are the same size.
They could be slightly different diameters though.
Try swapping front to rear.
Check tire pressures, low pressure may allow following road grooves more.
Charlie-III is online now   Reply With Quote
Old 08-11-2017, 06:00 PM   #4
Dieselman88
Member#: 440519
2004 Wrx
Rally blue
Had alignment done at dealer and really no change. Going to try another set of wheels with all matching tires in the morning.
Old 08-12-2017, 12:05 PM   #5
Dieselman88
Member#: 440519
2004 Wrx
Rally blue
Put a different set of wheels with all 4 matching tires and it fixed it. I'm assuming ones in front where a softer compound, following grooves in road more then the back tires. Doesn't feel like I'm driving through a wind storm now
Old 08-12-2017, 11:57 PM   #6
krzyss
Member#: 8365
2013 Ford Focus SE
The tire size is nominal, the circumference difference may be above the limit indicated by Subaru (is it 2"?).
Take tape measure and check.
The ideal situation: 4 identical tires.
Krzys
krzyss is offline   Reply With Quote
