Welcome to the North American Subaru Impreza Owners Club Monday July 23, 2018
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 07-13-2017, 07:38 AM   #126
tyler37075
Member#: 398361
2015 wrx
ice silver,wr blue
Originally Posted by simpleJ View Post
you'll blow your rods out, kid.
what????
tyler37075 is offline   Reply With Quote
Old 07-14-2017, 02:03 PM   #127
ryanpk17
Member#: 425088
2015 Wrx
Originally Posted by tyler37075 View Post
what????
Yeah Ralphy, listen to simpleJ
ryanpk17 is offline   Reply With Quote
Old 08-03-2017, 02:06 AM   #128
dvazriel
Member#: 434489
2017 WRX Premium
can you reach the solenoid connector without removing the intercooler? imma do it this weekend.
Also there is an EGR actual / commanded param in the AP. I had it side by side with the intake manifold temp.
EGR actual would be at 0 under medium -hard acceleration / idle. It was at 0 when you let off the pedal as well. It would go up under very light accel / cruise control. Everytime EGR actual went up, the intake manifold temps rised pretty quickly by 20-30 degree. They would drop wheb EGR was 0.
tldr EGR Actual 0 = Valve closed.
You can verify it stays closed after been uplugged by looking at your intake manifold temps.
dvazriel is offline   Reply With Quote
Old 08-03-2017, 08:13 AM   #129
emiliobadillio
Member#: 376596
2017 WRX Premium 6MT
CWP
Yes you can do it without removing the intercooler! It is an extremely tight fit, but you can reach it through a gap in the intake manifold. I used one finger and a screw driver to position it just right to remove it. It took me a bit of straining as I have big hands, but was able to get it after about 10 minutes.
emiliobadillio is offline   Reply With Quote
Old 08-03-2017, 12:44 PM   #130
IndecisiveS12
Member#: 463349
2017 WRX Sport
World Rally Blue
I actually just did this earlier this week.
if you look in from the front you can see the plug. use a long flat head screw driver so you can depress the release button and give it a small push to unseat it and ensure it doens't lock back in. Then reposition the screw driver closer to the end of the plug(there's a small block you can push against) and the plug pops right off.
You can get this done in a few minutes.
IndecisiveS12 is offline   Reply With Quote
Old 08-13-2017, 12:21 AM   #131
darkvader0
Member#: 457370
2017 WRX Limited
WR Blue
Within a few days of unplugging my EGR solenoid I got a P2270 OBD-II Trouble Code: O2 Sensor Signal Stuck Lean Bank 1 Sensor 2. This happen to anyone else? Any insight on how/if they can be related at all?
darkvader0 is offline   Reply With Quote
Old 08-13-2017, 11:16 AM   #132
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Are you tuned for an unplugged EGR?
gn4rwhals is offline   Reply With Quote
Old 08-13-2017, 07:12 PM   #133
darkvader0
Member#: 457370
2017 WRX Limited
WR Blue
Yeah I unchecked the nine trouble codes relating to EGR operation. The P2270 Second O2 stuck lean code was not one of them.
Old 08-13-2017, 11:47 PM   #134
That_Boosted_Life
Member#: 422693
2016 WRX Premium
Lapis Blue Pearl
I believe you have to zero out a few tables (4 I believe) which adjust fuel mixture depending on EGR position. The ECU adjusts fuel mixture based on what it commands the EGR to do, even though it's unplugged. Since exhaust gases have some un-burnt fuel in them, the ECU removes some fuel when the valve is open. Since the valve isn't connected and closed all the time, the engine is sometimes running lean since these gases are no longer entering the combustion chamber. By zeroing out the tables it doesn't adjust fueling which should prevent the lean condition.
That_Boosted_Life is offline   Reply With Quote
Old 02-26-2018, 09:00 AM   #135
open1your1eyes0
Member#: 479997
2016 Impreza Limited
Crystal White Pearl
Bumping this for any updates, how have you guys felt after all the testing. Do we have a general consensus that unplugging the EGR connector and tuning out the code is enough for it to be effective as a delete?
My major concern is warranty support as it's basically confirmed that a tune would deny any warranty claim and even if I flash back to stock with EGR deleted it will throw the Check Engine light so dealer would see that as well. If I can just plug in the connector when it comes warranty support time and flash back to stock map and bring it that would be much preferred.
Thoughts or experiences with the same?
open1your1eyes0 is offline   Reply With Quote
Old 02-26-2018, 12:22 PM   #136
WRXLVR82
Member#: 448320
2015 WRX Limited
Dark Grey Metallic
Confirmed by who? I've never been denied a warranty claim and I've got a few mods installed. It's all dependent on your local service department. Some are more mod friendly than others.
WRXLVR82 is offline   Reply With Quote
Old 02-26-2018, 12:46 PM   #137
open1your1eyes0
Member#: 479997
Crystal White Pearl
Officially it has been confirmed by multiple Subaru dealerships that any modification to ECU will deny your warranty without question. The keyword here is "officially", of course there will be dealerships here and there that may "overlook" your modifications in hopes of continuing business with you but you will really have to shop around to find that out. Officially every time it's been asked by many folks to most dealerships and SoA themselves they mention that yes, a tune will most definitely deny your warranty claim if they find out that you have one.
In fact there was a video by one owner done as an experiment recently regarding the same topic
Old 02-26-2018, 01:01 PM   #138
ayau
Member#: 332408
I unplugged mine and have been running for a few weeks. I'm currently tuned for it. Intake manifold temp is generally 10-20 degrees higher than ambient temperature (per the car's built in temperature reading).
No issues. No CEL.
ayau is offline   Reply With Quote
Old 04-03-2018, 01:36 PM   #139
sacul
Member#: 460370
i'm trying to figure out whether to delete or just unplug, my tuner said he has seen the valves leak if you just unplug. the delete kit is so cheap i'll probably just do it
sacul is offline   Reply With Quote
Old 04-03-2018, 02:46 PM   #140
simpleJ
Member#: 391748
2015 WRX
CWP
Is your tuner selling you the parts or labor by chance?
If it leaks, what difference does it make? It was leaking the whole time it was on the care and supposedly closed.
simpleJ is offline   Reply With Quote
Old 04-03-2018, 04:14 PM   #141
sacul
Member#: 460370
haha he offered to, but if i do buy it i'll do the install myself. it's cheap anyway
he just said he has seen them leak before in the past with just the disconnect
Old 04-05-2018, 04:15 PM   #142
sk8boarder22a
Member#: 453241
2017 WRX
Crystal White Pearl
I just asked my Snail Performance in Auburn, CA what would be best, full delete or unplug. He told me delete would be best as it leaks. So tonight I will be doing a full delete along with EBCS and TGV's.
sk8boarder22a is offline   Reply With Quote
Old 04-05-2018, 04:51 PM   #143
simpleJ
Member#: 391748
2015 WRX
CWP
EGR DELETES ARE A WASTE OF MONEY
CHANGE MY MIND
The EGR valve closes during wide open throttle, low temperatures, and moderate load cruise situations and when the manifold is pressurize, exhaust can't enter the manifold.
Let's say it leaks, just a little. Is there any detriment caused by the leakage in these situations on the factory car or any other car that retains the valve? No. Why would it be detrimental when it's unplugged 24/7?
How does anyone even know they leak? Did they stick a camera in the manifold during a dyno pull? Or are they just making a sale.
Old 04-05-2018, 05:53 PM   #144
mishapopa
Member#: 393629
2015 WRX
CHANGE MY MIND
Honestly I just did it for the weight savings (lol) and clean up the engine bay. It's $50. Unplugging it achieves the same thing.
mishapopa is offline   Reply With Quote
Old 04-05-2018, 09:25 PM   #145
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
CHANGE MY MIND
I literally lol'd
Seriously though, I'm having a hard time justifying the 10-15whp of the TGV/EGR delete combo too, let alone the EGR delete by itself.
Flex Fuel, 3-port, J-Pipe, and TMIC seem to be the best mods so far to do to this car.
Old 04-05-2018, 10:02 PM   #146
simpleJ
Member#: 391748
2015 WRX
CWP
Originally Posted by gn4rwhals View Post
I literally lol'd
Iím just leaving it.
Deleting them doesnít save you carbon cleaning anyways
Old 04-05-2018, 10:09 PM   #147
open1your1eyes0
Member#: 479997
Crystal White Pearl
I’m just leaving it.
Deleting them doesn’t save you carbon cleaning anyways
EGR deletes alone definitely not enough for significant carbon build-up avoidance. However them paired with an AOS or catch-can setup is a vast improvement. Highly recommend looking into them.
Both are going to be one of the first mods I install when I order my WRX this year.
Old 04-06-2018, 06:30 AM   #148
simpleJ
Member#: 391748
2015 WRX
CWP
No they wonít.
Catch cans are also a waste on a show room new motor. That thing is already tight, if youíre having blow by problems at sub like 100k miles youíve got a bigger problem than blow by.
At 77k, 50k of those tuned, my intercooler has barely a thin film of oil on the inlet side.
The carbon comes primarily from the sulfated ash in the oil trickling down the valve stem paste the seals and baking/caking onto the valve.
EGR and catch can might buy a few thousand miles more between carbon cleaning but thereís only one thing that will stop it: Water Meth Injection.
Old 04-06-2018, 07:52 AM   #149
IronmanDaremo
Member#: 461956
2017 WRX Premium
I just did mine over the weekend (TGV and EGR deletes). Waiting for a new O2 sensor to go out and finalize the tune.
But man ....... taking off the EGR system was sure a pain in the azz for me! I'm pretty mechanically inclined, but for some reason, the EGR delete took way too much time for me. What should have been a 20 minute operation (I was already doing a bunch of other stuff to the car) took me about an hour and got radiator fluid everywhere. Felt like an amateur doing it ......
IronmanDaremo is offline   Reply With Quote
Old 04-06-2018, 09:41 AM   #150
open1your1eyes0
Member#: 479997
Crystal White Pearl
No they won’t.
Catch cans are also a waste on a show room new motor. That thing is already tight, if you’re having blow by problems at sub like 100k miles you’ve got a bigger problem than blow by.
EGR and catch can might buy a few thousand miles more between carbon cleaning but there’s only one thing that will stop it: Water Meth Injection.
FYI, blow-by isn't specifically a problem but a natural expected occurrence as part of the combustion process in both port-injected and direct-injected engines due to pressure build-up in the crankcase needing to be ventilated out through the PCV and CCV. It's just that, unlike port-injected engines, DI engines don't happen to wash over the valve stems with fresh fuel to clean it up (hence the carbon build-up). Of course EGR systems with their effect of exhaust being put back into the intake (where only fresh air should go) definitely doesn't help either. It may or may not be a lot but never-the-less it's there and has been proven to significantly add to carbon-build in DI engines due to the lack of fuel flowing over the valve stems.
Savagegeese goes over DI engines and talks about all this on his YT channel and specifically mentions catch-cans and air-oil separators as one of the methods of avoidance for carbon build-up (along with checking NOACK levels of your oil and other things). Definitely recommend a view as it is very informative.
Sidenote: Also Phatbotti tuning (a very well-respected tuner in the scene) specifically recommend these parts (AOS + EGR deletes) for the WRX 2015+ and talks about how they both help eliminate carbon build-up levels.
https://phatbottituning.com/2015%2B-wrx-suggested-parts
