Welcome to the North American Subaru Impreza Owners Club Monday February 19, 2018
Old 06-14-2017, 12:18 PM   #201
jaythekay
Member#: 468078
2014 WRX S4
white
Originally Posted by Big-E View Post
To resolve this and not use the additional new resistor, i simply cut-off the ground-end of the trigger and installed an eyelet. I then grounded the eyelet directly to the body where the OEM resistor was held in place. No need for a new resistor and no need for any other wire-taps or other items tha can potentially expose the wiring to the elements.
looks neat. thanks for the advice! should try it too
jaythekay is offline   Reply With Quote
Old 07-09-2017, 11:26 PM   #202
Aroks
Member#: 462039
Anyone have updated pictures for doing this on 2015+ wrx? The pictures on the first post don't work anymore.
Aroks is offline   Reply With Quote
Old 08-06-2017, 11:52 AM   #203
Sp00l_up
Member#: 413221
2009 Wrx STi
I just found this thread and want to do this but same, pictures are no longer available to view. Help!!
Sp00l_up is offline   Reply With Quote
Old 08-09-2017, 11:59 AM   #204
GTEASER
Member#: 410767
2012 Legacy GT
2009 Forester XT
I have pictures around Post #30 in my build thread for my '09 Forester XT over on www.subaruforester.org. Gonna be the same as your car.
http://www.subaruforester.org/vbulle...teaser-533601/
GTEASER is offline   Reply With Quote
Old 08-09-2017, 06:21 PM   #205
Sp00l_up
Member#: 413221
2009 Wrx STi
Thank! Appreciate it
Old 08-10-2017, 03:40 AM   #206
ab0815
Member#: 464530
2017 Impreza
Ice Silver
Thanks for the link and write up.
If I am seeing your setup right...you relocated the relay and then ran wires to it from the relay socket. Then ran a single wire from the fog relay itself to the DRL harness.
Right??
ab0815 is offline   Reply With Quote
Old 08-10-2017, 10:57 AM   #207
GTEASER
Member#: 410767
2012 Legacy GT
2009 Forester XT
I didn't do anything with any DRL harness. Did you see the diagram?
Old 08-12-2017, 02:41 AM   #208
ab0815
Member#: 464530
2017 Impreza
Ice Silver
I saw that and the pictures...I just was not clear where that yellow wire went
Old 08-12-2017, 03:12 AM   #209
GTEASER
Member#: 410767
2012 Legacy GT
2009 Forester XT
IIRC it goes to the wire that normally powers the stalk fog switch when the headlights get turned on. That way it has constant power from the fuse tap even when the headlights are off or the high beam are on. It is what makes the fogs independent of the other lights and the stalk switch work at all times.
Old 08-13-2017, 03:59 AM   #210
ab0815
Member#: 464530
2017 Impreza
Ice Silver
And that overrides the DRL function of the other light?
Old 08-14-2017, 01:34 AM   #211
GTEASER
Member#: 410767
2012 Legacy GT
2009 Forester XT
DRL and fog light circuits are 2 separate circuits. I disabled the stock DRL circuit by unplugging the DRL resistor.
