09-11-2007, 11:23 AM | #1 |
Member#: 95789
Vehicle:2002 WRX PTE 6262, hydra, 1100 FIC |
BLEW MY AXIS STAGE 2 lol
Well guyts it was fun for about 6k miles. But now I must be moving on and nputting a better engine in my car. THe engine took quite a bit of abuse before then rings went out. But i just cant help but think that the piston that the rings went out on was already bad. As soon as the engine went in the piston that went bad wouldnt fire from day 1 properly but did have good compression. in the initial tuning the was some harsh detonation But I had gotten it where there was no detronation. Well not a bad engine just couldve been better.
09-11-2007, 11:53 AM | #2 |
Member#: 33782
MAIC
Vehicle:96 3MI Racing search FIRST, then PM!!! |
what do you mean the piston wouldn't fire?...sounds like an electrical or plug issue to me.
09-11-2007, 12:19 PM | #3 |
Member#: 95789
Well on a REALLY cold satrt that piston would not fire until the engine temp came up!
09-11-2007, 12:57 PM | #4 |
Member#: 155256
International
Vehicle:2000 sti ra multi colour |
axis engine
sounds like the detonation could of damaged the engine not a bad engine its not normally the engines fault it detonates ,its the tuning.
If there was enough oil in the cylinder to cause det and misfire from cold it would of smoked like a train . |
09-11-2007, 01:24 PM | #5 |
Member#: 95789
yeah well nit did smoke like crazy on a cold startup. once warmed up all was well. I sure detonation had a lot to do wiht it too but the last 3k miles of the motors life was detonation free.
09-11-2007, 01:40 PM | #6 | |
Member#: 41561
MWSOC
Vehicle:04 GT3076 2.1 Stroker = Broken 3rd |
I remember your tuning posts. How much boost were u running? |
09-11-2007, 01:53 PM | #7 |
Moderator Member#: 922
MWSOC
Vehicle:16 WRX (white) 04 FXT (red) |
Heh, 3k of detonation on a built motor and you expect it to last?
IMO, you need to fix other problems before putting another built motor in there. |
09-11-2007, 02:01 PM | #8 |
Member#: 33782
MAIC
I'm going to say the motor was killed in the initial 3k miles due to detonation...poor rings never had a chance...
what did you do for your break in period?...please be complete and precise with the answer. |
09-11-2007, 07:40 PM | #9 |
Member#: 95840
NWIC
Vehicle:sold to a good bud awaiting next car |
atleast the OP can make a "lol" at his mistakes!
09-11-2007, 09:03 PM | #10 |
Member#: 78165
South East
Vehicle:05 STI 35r + e85 |
How could you ever blame the engine?!?
http://forums.nasioc.com/forums/show....php?t=1214410 I have never seen so many knock counts in a datalog. |
09-11-2007, 09:05 PM | #11 | |
Member#: 95789
I dont remember putting a post blaming the engine for the detonation? I blamed it for not firing on the cylinder that died!
09-11-2007, 09:18 PM | #12 | |
Member#: 33782
MAIC
I personally think it was your plug gap/temp range...either that or a short. |
09-12-2007, 01:23 AM | #13 | |
Member#: 95840
NWIC
09-12-2007, 09:39 AM | #14 |
Member#: 95789
09-12-2007, 10:19 AM | #15 |
Member#: 60794
MAIC
Vehicle:2007 Solstice GXP |
What do you mean a cylinder didn't fire? Were you able to verify the cylinder was not getting spark? I would assume that if you were getting good compression numbers, the rings seated fine.
Also, the detonation you experienced could have been caused by a number of variables, and a few I could suggest just based on the info in this thread include: 1.) Gas quality/octane 2.) Poor intercooling 3.) Tuning These three variables lead to detonation which killed your motor. Live and learn. So what are your plans now? Rebuild? |
09-12-2007, 11:04 AM | #16 |
MWSOC
09-12-2007, 09:08 PM | #17 |
Member#: 95789
Definitely gonna do a rebuild. This time with a hx40 holset and prolly better rods and pistons on a ej257. Hell its just a motor. mr complex moderator FYI my post is very informative due to the fact of sharing my experiences of the axis stage 2 motor with what mods and tuning i had. so piss off
09-11-2007, 09:04 PM | #18 |
Member#: 95789
it very well could been killed die to detonation. The problem was is that the inter cooler sucked major balls for the turbo i was running. just got too hot and liked to detonate. I dont have any smokey videos either. either way the ring wasnt set up right anyways. I am not knocking axis motors either! i think they are pretty fair quality. at least the stage 2 is. My motor detonated under light boost since i started tuning it. I dont know why either. I wanted to run 15psi on pump at about 17 degrees timing and it would detonate. i had to back it down to 14 degrees before the detonation went away. I am pretty sure the egts were just too hot and the intercooler had A LOT to do with the destruction of the engine. I am not mad about either you dont hear me blasting on anything just sharing my experience.
09-11-2007, 09:06 PM | #19 |
Member#: 9960
Vehicle:2002 Impreza WRX WRBlue Perl |
were you sure of your gas quality? And did you check your entire setup to ensure that there were no othe probles that were causing you strife in the tuning department?
09-11-2007, 09:10 PM | #20 |
Member#: 95789
i tried a bunch of sifferent gas brands and the only thing that cured detonation is alchohol or race gas
09-11-2007, 09:12 PM | #21 |
Member#: 9960
what intercooler were you using again??
09-11-2007, 09:18 PM | #22 |
Member#: 95789
ebay top mount
09-12-2007, 11:00 AM | #23 |
Member#: 33293
Tri-State
Vehicle:2011 4-door STi Plasma Blue |
Well when you buy a nice short block then go buy a cheezy ebay tmic what do you expect.
Go big or go home. |
09-12-2007, 10:46 PM | #24 | ||
MWSOC
Perhaps someone will complain about me "getting in the last word and closing the post" but frankly, this post is going nowhere and has nothing to give to the community other then to make sure to get your car professionally tuned. |
Similar Threads | ||||
Upstate NY: 1998 2.5RS-T with Axis stage 2 shortblock and PPGs | Keith | Private Vehicle 'For Sale' Classifieds | 9 | 10-30-2009 06:22 PM |
gauging interest: 1998 2.5RS-t with Axis stage 2 motor (new)... | Keith | Private Vehicle 'For Sale' Classifieds | 28 | 02-18-2009 02:40 PM |
Keith's, "I can't get my car inspected" sale. RS-t with Axis stage 2 STi block | Keith | NESIC Private Classifieds | 31 | 03-22-2008 07:33 PM |
2.5 Axis Stage 2 bottom end.... any good?? | frayz | Built Motor Discussion | 6 | 08-23-2007 03:38 PM |
Axis Stage 2 vs. USDM STi 2.5 | Chad W | Built Motor Discussion | 14 | 04-29-2007 11:40 PM |
