Welcome to the North American Subaru Impreza Owners Club Sunday August 19, 2018
Old 01-08-2013, 10:15 AM   #1
KornShaDoW097
Member#: 313618
2004 WRX
Default SD tune issues
I just did a stock retune on my 04 wrx. It's the Cobb tuning SD with full MAF mode enabled. So in essence it's a stock tune.
It idles at 1k rather than 750 and at cold start it sputters unevenly and within 40 seconds revs up to 3k.. Until i tap the throttle and get it working normally... Why does it do this?
KornShaDoW097 is offline   Reply With Quote
Old 01-08-2013, 11:00 AM   #2
Cobb Tuning
Member#: 4803
Post up your map at the cobbforums (start a post and click on "Go Advanced" and "Manage Attachments") and we can take a look. Did you make any hardware changes to the car (additional mods or other changes) since you last ran on a MAF map? What were you running previously?
Bill
Old 01-08-2013, 08:01 PM   #3
KornShaDoW097
Member#: 313618
2004 WRX
Bill
Will do.
I haven't changed anything except the clutch that went bad and then threw on a SD tune. I even cleaned the iacv which barely made a difference if any.
It's in full MAF mode currently. Haven't even gotten into hybrid
Old 01-09-2013, 09:28 AM   #4
Cobb Tuning
Member#: 4803
Will do.
Also get a memory snapshot (via troubleshooting menu on AccessPORT) when the idle is unusually high. You can post this up at the cobbforums (rename the extension to .rom so it will allow you to post it).
Bill
Old 01-11-2013, 08:43 PM   #5
KornShaDoW097
Member#: 313618
2004 WRX
Bill
It's pretty much always unusually high on idle. Did you want the cold start 3k idle or a snapshot once it's warmed up and at 1.2k(after I kick the throttle)?
Ill try for both if you'd like
