Welcome to the North American Subaru Impreza Owners Club Tuesday November 13, 2018
Old 05-15-2008, 08:36 PM   #1
FQ_22b
Member#: 123195
2005 STi
Silver with Goldies
Default Is my turbo blown? ...or something worse?
My car blows smoke ONLY when i let off the gas and then get back on it.
Thought it might be the head gasket but i checked the oil and it's fine.
Any thoughts? (besides me being a newb)
The car is a 01 RS with a 04 WRX engine if that means anything...
FQ_22b is offline   Reply With Quote
Old 05-16-2008, 01:01 AM   #2
SurfWagon
Member#: 156861
2005 LGT Wagon 5MT
swp, 16g
Smoke on engine breaking is usually a sign of ring problems. The vacuum accelerates blow-by. My suggestion is do a compression check. Hey, at least there are only 4 cylinders to check!
SurfWagon is offline   Reply With Quote
Old 05-16-2008, 01:44 AM   #3
ccook
Member#: 12716
2002 impreza wrx
sedona red
Default I'm doubting it's a turbo
From experience, I've had a blown turbo and you'd feel significant degradation in acceleration and overall performance. Sounds like an engine problem....
I also had a blown gasket on an aftermarket up pipe and it hesitated and backfired badly. No smoke though. Prior to that my turbo (TD04) did blow and still no smoke, just a bad noise and poor power.
I think it might be necessary to have someone look at the engine, do a leak down, etc.
ccook is offline   Reply With Quote
Old 05-16-2008, 03:29 AM   #4
FQ_22b
Member#: 123195
2005 STi
Silver with Goldies
So basiclly i'm going to have to replace a piston?
Old 05-16-2008, 03:56 AM   #5
austinramage
Member#: 178367
2002 WRX-WRB-309AWHP
2007 Ninja 250-Flatblack
Well do a compression test before you start thinking you have to replace parts, but that does sound like possibly a blown piston or ring(s).
austinramage is offline   Reply With Quote
Old 05-16-2008, 04:05 AM   #6
FQ_22b
Member#: 123195
2005 STi
Silver with Goldies
Well, that's not too bad of thing. Just gives me an excuse to finally build my spare STi RA block that's been doing nothing but collecting dust.
Compression check coming soon!
More details later!
Old 05-16-2008, 12:55 PM   #7
samb
Member#: 177235
2016 Focus RS
2002 WRX Wagon
The smoke is blue yes?
samb is offline   Reply With Quote
Old 05-16-2008, 05:10 PM   #8
FQ_22b
Member#: 123195
2005 STi
Silver with Goldies
yeah, it was blue. I changed my oil though and now it hasn't been smoking. I had really thin oil in it before and i switched back to 1030.
I still haven't done the compression check yet though.
Could it just have been me using too thin of an oil so it was getting past the seals?
Old 05-16-2008, 08:49 PM   #9
notsosimple
Member#: 179937
Did you by chance 'accidently' put conventional instead of synthetic, or vice versa?
notsosimple is offline   Reply With Quote
Old 05-16-2008, 10:38 PM   #10
GeneralTJI
Member#: 152680
Just in case... not saying this is the case because I don't want to assume... but-
If you were talking about running a thin oil as in 5w30, and then you went to 10w30 and are considering it thicker, I just wanted to give you the heads up that 10w30 is only thicker while the oil is cold.. which is harder on your motor during cold starts... and once the oil reaches operating temp, they are the same... what kind of oil are you running BTW??
GeneralTJI is offline   Reply With Quote
Old 05-16-2008, 11:37 PM   #11
FQ_22b
Member#: 123195
2005 STi
Silver with Goldies
I don't think conventional oil was put in. I honestly don't even remember what we put in. My friend had a case of it in his garage and i was short on cash so instead of having my oil changed by a professional(which i normally do because changing oil sucks and i'm lazy) i just let him change it.
I normally run Mobil 1, which is what is in there now.
Old 05-17-2008, 06:51 AM   #12
Lexington
Member#: 50221
I'm on internets
Racin on ur bandwidth!
"basically" is not the word you're looking for.
There is nothing "basic" about engine damage.
Ever.
Lexington is offline   Reply With Quote
Old 05-17-2008, 03:52 PM   #13
FQ_22b
Member#: 123195
2005 STi
Silver with Goldies
I realize that. haha.
That's also why i happened to have a spare EJ20k block laying around.
Now i have good reason to "build" my engine.
So is my turbo blown? Sypher Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 11-18-2009 10:51 PM
Is my clutch slipping? or something else? Jncominco2 Rocky Mountains Impreza Club Forum -- RMIC 37 04-29-2009 04:10 PM
Is my turbo Blown????? PLEASE HELP seanec327 North West Impreza Club Forum -- NWIC 14 10-02-2008 11:35 PM
Is my turbo dead or dying? 02L Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 12-21-2006 03:51 PM
Audio Geeks: Is my Sub blown or something else? fourseasonsandles Off-Topic 12 12-29-2005 04:40 PM
