Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 09-24-2013, 08:18 AM   #1
winkster2005
Member#: 322973
2009 WRX
black obsidian pearl
Default stiff power steering and squeaky belt/ replacing stretch belt?
Hi everyone,
for the last few days my car has made a squeal when i first start it up in the morning. definitely sounds like a belt. but today the power steering was really tight and i smelled something burnt. the squeal and stiff ps went away after a few seconds. has anyone had a stretch belt go bad on them yet and if so can you change it without the install tool?
thanks,
will
winkster2005 is offline   Reply With Quote
Old 09-24-2013, 01:37 PM   #2
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info
The stretch belt goes to the A/C side...PS side is not a stretch. Either belt is bad and slipping or loose and needs tensioned.
darkstarmoto is offline   Reply With Quote
Old 09-24-2013, 08:30 PM   #3
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
As mentioned the stretch is on the A/C.
Tighten the Alternator - P/S belt, it is loose. It doesn't take much slack for the P/S pump to start slipping making the noise and the hard steer. Look at the belt to make sure it is not shredded. If shredded replace.
Old 09-26-2013, 10:24 AM   #4
Jdeck
Member#: 322267
2002 Impreza OBS
I get the same thing in the winter. Sounds like I need to tighten up the PS belt.
Jdeck is offline   Reply With Quote
Old 09-30-2013, 12:41 AM   #5
jdmjack
Member#: 248430
2003 PSM Bugeye
I've been having a similar issue. I think my belt may be done. Also the below pulley stops spinning when the nose happens. I hope its only the belt. How difficult is it to change the belt?
jdmjack is offline   Reply With Quote
