Welcome to the North American Subaru Impreza Owners Club Monday December 2, 2024
Old 07-29-2002, 03:04 AM   #1
Gypsum2
Member#: 8350
Default Help: Cant figuire out how to install headlight blub and harness back into headlight
i just cant get it to click... is there any special trick?> what am i doing wrong?
help
gypsum2 <-- dummy
Gypsum2 is offline   Reply With Quote
Old 07-29-2002, 12:56 PM   #2
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
you arent doing anything wrong...unlike the old schools that require about 3 secs to change bulbs...the WRX is bizatch......after removing the headlight housings, and the bulbs...the replacement is pretty confusing, it doesnt neccessarily go in reverse....the bulbs has got "markers" oin the sides to guide you ...first slide in the guides to the corresponding wedges on the housing, make sure its a tight fit....then twist the clip ring to a snug fit....then replace the rubber boot, then replug the bulbs...
ATX25RS is offline   Reply With Quote
Old 07-29-2002, 01:25 PM   #3
chewby
Member#: 22043
its easy to do the driver side light but the pasenger side is tricky, just take the two blots off the airbox in the front and it should give you more room to work with. when i replaced mt bulbs, all u do is turn the cap that surrounds the harness, then press down on the clip and pull, it should come right off. good luck!
chewby is offline   Reply With Quote
Just bough Eclipse Navi and can't figure out how to install speed sensor JASWRX Car Audio, Video & Security 3 09-29-2010 04:24 PM
I can't figure out how to remove my viscous coupling mk2jettavr6 Transmission (AT/MT) & Driveline 3 01-15-2008 10:58 AM
Can't figure out how to install clutch clips noitseuq Transmission (AT/MT) & Driveline 1 02-25-2007 02:50 PM
Can't figure out how to calibrate tps ?? L80Killa87 UTEC 2 01-02-2007 09:12 AM
I Can't Figure Out How To....(n00b ? inside) binky Off-Topic 19 08-07-2004 07:01 PM
