Welcome to the North American Subaru Impreza Owners Club Wednesday June 20, 2018
Old 12-15-2017, 10:52 AM   #51
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by shook187 View Post
It's for a 2016 premium with a 6.2 starlink.
Talking about this harness
https://uploads.tapatalk-cdn.com/201...1382df197d.jpg
Since you already have the Metra AX-SUB28SWC-6V, you don't need that other 28-pin harness (from autoharnesshouse).
The AX-SUB28SWC-6V has the correct rear camera wiring for cars with the OEM 6.2" HUs. You'll need to cut off the integrated 12-pin plug intended for an ASWC-1, and connect the 3 SWC wires from the 28-pin to the Maestro's harness. The Maestro will also need 12V power and ground from the 70-1761.
However, since you got the Maestro RR, you won't need the 6V power converter in the AX-SUB28SWC-6V either. If you can return that, there is an alternate 28-pin harness without the ASWC portion or 6V converter, and which doesn't have the problem with the terminals being too long (that many people have complained about -- search for the numerous posts on NASIOC about that).
SVXdc is offline   Reply With Quote
Old 12-15-2017, 12:56 PM   #52
shook187
Member#: 418049
Where can I get this alternative harness without the PIN issue?
shook187 is offline   Reply With Quote
Old 01-01-2018, 02:22 AM   #53
nz suby 1996
Member#: 479939
There is an alternate AM/FM+XM antenna "feeder cord" you can use to retain the factory rooftop XM antenna, to use with an aftermarket SiriusXM tuner box. See my post in the huge 2016 WRX thread.
hey SVXdc, ive looked on your thread as ive installed a new jvc headunit, i have a 96 wrx wagon, ive cut the factory plug off to install the radio into it now, but since then the keyless entry doesn't work, does it need a certain wire to remain powered?
nz suby 1996 is offline   Reply With Quote
Old 01-05-2018, 08:07 PM   #54
sacricide
Member#: 480180
2015 WRX
black
im looking for something like this, my stock nav unit has too many bluetooth compatibility issues on android 8.1. ive never done an install trying to retain steering controls, daunting isnt a encouraging word lol
sacricide is offline   Reply With Quote
Old 01-24-2018, 12:19 PM   #55
shook187
Member#: 418049
Originally Posted by phd12v View Post
just an update: i finally got to see our RR harness for the new platform. It needed one little revision and we are looking at possibly early february for availability.
Any new info?
Old 01-25-2018, 11:03 AM   #56
phd12v
Member#: 432497
18 Sti
ISM
should be within a week or two
phd12v is offline   Reply With Quote
Old 01-25-2018, 03:04 PM   #57
knstyl
Member#: 479979
2016 STi
Can't wait!
knstyl is offline   Reply With Quote
Old 01-25-2018, 08:18 PM   #58
shook187
Member#: 418049
What's going to be the benefit compared to what we have now? I'm debating if I should just wait for this harness or go ahead and install what I have
Old 02-12-2018, 03:33 AM   #59
jonizzzle
Member#: 457782
2016 WRX Limited
Ice Silver Metallic
Any updates? Iím really interested in utilizing the RR!
jonizzzle is offline   Reply With Quote
Old 02-13-2018, 11:04 PM   #60
CXVninja84
Member#: 438216
Originally Posted by ZsmithWrx View Post
That looks fantastic! I want to confirm that the diagram you made is for the pioneer 4200 nex correct
It looks like the diagram is generic for any radio. Normally the wires for speakers/+12V/ground on the Metra 70-1761 will match the colors on the harness of the unit you're installing (I'm sure this is the case for Pioneer)
I will note that this harness is handy if you're installing a Pioneer. It has the Pioneer connector already wired in for you:
https://www.amazon.com/dp/B078GBDRVX
(It worked great for my Pioneer AVIC-5200NEX)
CXVninja84 is offline   Reply With Quote
Old 02-14-2018, 10:30 AM   #61
knstyl
Member#: 479979
2016 STi
What other connector did you use for the backup camera? I assume backup cam and aux inputs are the only connectors missing from this harness.
Old 02-14-2018, 11:56 PM   #62
CXVninja84
Member#: 438216
I used the AutoHarnessHouse.com 28-pin harness which includes wires for the steering wheel buttons, the backup camera setup, and a couple other things. You'll also need a separate USB adapter and AM/FM adapter.
You can connect the Maestro SW directly to the wires on the 28-pin harness and to the power wires on the harness from my link above.
Old 04-22-2018, 06:37 AM   #63
Chemguy34
Member#: 484988
Great information here. I just got a 2016 OB and the Starlink is just terrible. Appreciate you posting this.
Chemguy34 is offline   Reply With Quote
Old 05-27-2018, 01:55 AM   #64
traiviet
Member#: 486466
Possibly. What car year and model do you have? (please add that to your profile here). What is the model number printed on the front of the factory HU?
If you have one of the 7" OEM HUs, you'll need a separate 5-pin harness to retain your OEM rear camera.
I don't know where you heard anything about a 32-pin connector, but none of the recent Subaru models have anything for the HU with that many pins.
In any case, you can remove the blue wire from that Metra antenna adapter (your car does not use that pin). You can also remove the short blue loop wire on the 70-1761 (be careful to not damage the longer blue wire that it's crimped onto).
Hi SVXdc,
I have a 2018 Forester Premium with 7" screen with Starlink, Model of HU is FF679UM. My replacement unit is Pioneer AVIC 8200NEX . I tried to install the Maestro SW with all the parts that shook187 has, and it came up with 2 issues:
1 - There is no backup camera signal (OEM Camera)
2 - No front speakers sound
You mentioned "If you have one of the 7" OEM HUs, you'll need a separate 5-pin harness to retain your OEM rear camera." Where does this harness connect to? Do you think AutoHarnessHouse has it?
Regarding the sound issue, Do you think the harness is defective? Is the Blue loop wire the culprit?
Please advise. Thank you so much.
traiviet is offline   Reply With Quote
Old 05-29-2018, 11:04 PM   #65
Furlybird
Member#: 459433
This is an amazing post,
I did the Apex V2 Headunit, and juiced it up with an Alpine Power Pack 445u.
Polk Audio DB Components front,
JBL GTO Rears
JL Audio 10 inch ported sub.
Furlybird is offline   Reply With Quote
Old 05-30-2018, 11:30 AM   #66
Altitude909
Member#: 481712
Check the voltage requirements for the camera, the harness i got from autoharnesshouse had a voltage converter for the camera built in
Altitude909 is offline   Reply With Quote
