Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 05-19-2017, 09:44 AM   #1026
Marcel Triska
Member#: 467098
Salvi, on the trip knob, press it quickly twice, then it will show ILL.5 on the right LCD. Use the control knob, twisting it to the left to dimm the cluster illumination. After setting, standby a few seconds, and the setting will be confirmed, and the cluster will turn back to full brightness.
Once that is set, everytime you turn on the car, it will come up with full brightness, and when you turn on the lights, the cluster will dimm to your illumination settings.
Let me know if that works for you, otherwise, I'll post some pictures or even a video.
Marcel Triska is offline   Reply With Quote
Old 05-19-2017, 12:29 PM   #1027
salvi
Member#: 188132
Marcel, I've tried that as well, but it doesn't work. Which year STI cluster do you have?
salvi is offline   Reply With Quote
Old 05-19-2017, 12:34 PM   #1028
Marcel Triska
Member#: 467098
My cluster comes from a 2004 jdm sti. I'll try to record a video later to show.
Old 05-19-2017, 01:06 PM   #1029
salvi
Member#: 188132
I'm wondering if the JDM STI is different then the usdm one. Anyone here have a USDM 04 STI cluster that has the manual dimmer setting working? If so, how did you achieve this?
Old 05-20-2017, 11:11 AM   #1030
Marcel Triska
Member#: 467098
There you go, check if that match for you
Old 05-22-2017, 12:40 PM   #1031
salvi
Member#: 188132
Yeah, mine doesn't do that. It just goes from A to B and that's it. I wondering if the other people mentioning that it worked for them had an 05+ STI cluster instead.
Old 05-23-2017, 12:37 PM   #1032
salvi
Member#: 188132
Can anyone explain the below post? I understand that he's connecting the dimmer lever cables directly to the cluster. Someone asked why he didn't just spliced the wires from the cluster instead of cutting them and he mentions that one wire carries 5v. Where is it getting the 5v that he had to cut the wires? Does anyone have the wiring diagrams for just the dimmer?
first thing you want to do is gather parts your going to need.
2 pins w/ wire to put into the b20 and b22 in your cluster.
2 blade connectors (optional, you could solder)
optional steps
you will have to choose if you want the center consol contols to dim or not. you can either wire them to be their brightest, dimmest, or use a switch to contoll them seperate.
so choose if you want to grab a switch or solder them
1st.
take the cluster out, then grab the B clip and plug in the 2 pins one in b22 and one in b20. run those down to the steering colum.
now take the bottom of you steering colum apart(there is one screw on the under side of the plastic. unscrew it then pull it away from the colum.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768.
next look for the plug that goes into the headlight switch
now flip the plug over. and you should see where it says 17 on one cornner and 9 on the other. this are the marking the wires in the plug. so start at 9 and move over to the number 11 an 12.
clip them and leave room for a wire connector to go on them. then connect 12 to b22 and 11 to b20
great job with that part now the dimmer works!!! if you turn it to max bright and it dimms then your wires are backwards, fix it.
now for the other side of the wires you clipped. this is where you can use a switch or not.
1st option: dont connect just tape both side then your done. the center consol will be at the lowest setting but its still very visible.
2nd option: connect them, now the're at the brightest setting which isnt all that bright in a subaru.
3rd option connect a switch between the two wires and then you can choose when its bright or not.
i did the 2nd choise
agin with the video of this sweet hotness in action....
http://media.putfile.com/sti-cluster...dimmer-working
Old 05-23-2017, 02:28 PM   #1033
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
Hi guys and gals. I have a 2004 usdm sti cluster and the wiring harness the connects to the dash harness.
I would like to install it into my 2004 usdm forester xt manual "6spd"
I need to find the wiring diagrams for both ends of the harnesses of both car to decide what my best option is for the swap.
Any input would be great.
Im going to do some more research on things for myself as I have some free time.
Thanks in advance.
rexworx is offline   Reply With Quote
Old 05-25-2017, 12:50 PM   #1034
rexworx
Member#: 103232
GTX 3071R'd 11WRX
Some good info here, I wanted to bring this back from the dead as a read through...
Im on page 23 now. lol Now I just need to find the diagram for a 2004 usdm forester xt manual.
I also have the cluster harness that connects to the dash harness. Not sure if it would be easier to use for my swap. I need to find diagrams for both the 2004 usdm sti and my 04 usdm fxt manual. "Both ends of the cluster harnesses would be amazing.
Post # 207 on page 9
Originally Posted by Micky View Post
^^^ What he said. Here is 2004 ~ 2006 comparison for the 3 plugs, B + C are the same.
Old 05-29-2017, 08:29 AM   #1035
one more chance
Member#: 468434
I'm wondering this too. As far as I know, the only difference I can think of is the 180KM speedo on the JDM. Everything is should be the same i.e. sweep ceremony, beeper etc. I've gone through the whole thread to double check but can't get a definite answer. Don't really want to fork out the extra $$$ for a JDM.
If anyone knows any other difference between the USDM and JDM V8 STI cluster, please let us know.
one more chance is offline   Reply With Quote
Old 06-01-2017, 07:30 PM   #1036
AndysRex
Member#: 434475
05 VF39 Swap WRX
Obsidian Black Pearl
I just put in a 05 STI cluster into my 05 WRX and all the info I have collected isn't the same.
When I put it in there was no constant buzzing, the DCCD light was off, the rear diff light was on, and my OTS was reading 122 degrees. I grounded B4 for the rear diff and it didn't do anything so I just taped the back of the cluster. My OTS still reads 122 degrees. I have auto HVAC so do you guys thing the cluster I got is busted?
AndysRex is offline   Reply With Quote
Old 06-01-2017, 08:36 PM   #1037
Gramps
Member#: 421394
Thank you for the valuable information on this thread (a bit messy). I swapped a 2002 STI TYPE RA JDM cluster to a 2007 EDM WRX, everything worked except for the abs warning light which was solved with the relay to invert signal polarity.
Gramps is offline   Reply With Quote
Old 07-01-2017, 01:21 AM   #1038
CorsairN7
Member#: 448913
2005 Impreza WRX STi
Hi Guys a quick question.. does anyone has experiences with EDM to JDM cluster swaps? wich one is best compatible? JDM 04, JDM 05, USDM 04 or 05 etc...
I have an EDM 2005 STI with this cluster
and i want to swap it for a red defi tyle STI cluster
any thoughts, before I decide wich cluster to buy?
CorsairN7 is offline   Reply With Quote
Old 07-24-2017, 07:41 PM   #1039
KeatonHo
Member#: 463653
2003 WRX Wagon
@vader.wrx
To build on that last post, which clusters are red and defi style? Really liking the idea of red and the sweep, just having a hard time finding real pictures of these gauges as photobucket just committed suicide. I'm about halfway through the whole thread but it seems people dont explain how their clusters look.
KeatonHo is offline   Reply With Quote
Old 08-04-2017, 03:31 PM   #1040
jens12987
Member#: 472265
Anyone any experiance with swapping an 06 jdm sti cluster in a 2004 edm sti?
jens12987 is offline   Reply With Quote
Old 12-05-2017, 12:31 PM   #1041
brum_harr
Member#: 465429
2007 Subaru WRX
Does anyone know how a V9 cluster would work in my 07 wrx with drivetrain swap? or any tips?
brum_harr is offline   Reply With Quote
Old 12-12-2017, 05:25 AM   #1042
Marcel Triska
Member#: 467098
If your drivetrain swap means a 6mt sti swap, thats great news. Your speedometer will work just fine, because the 6mt gear box uses a different pinion, which gives you different speed display between wrx x sti
Old 01-07-2018, 02:04 PM   #1043
Claude Punkslayer
Member#: 454601
Default 2006 Wrx with V9 sti cluster swap
My RPM suddenly got dark, the arrow that points at your RPM still works as well as the STI symbol below. But the RPM Tac is no longer illuminated. Any suggestions? I already checked the connections of the 3 green plugs, they all fit in. I will pull again just to double check that all the wires are in the pin connectors as they should be. Also, it seems like a circuit might have gone bad because all 7 or so of the smd lights that illuminate this section of the cluster are just not turning on. But all the other lights do. Any help would be great! Thanks
Claude Punkslayer is offline   Reply With Quote
Old 01-08-2018, 04:31 PM   #1044
Claude Punkslayer
Member#: 454601
Everything looks okay. So I have no idea why my cluster is not illuminating in the middle.
Old 01-23-2018, 05:53 PM   #1045
AIDRIIAN
Member#: 350104
2007 WRX
Just swapped in a cluster from an 06 STI into my 07 WRX TR. Everything works (shift light, sweep, etc) and I followed the same steps as most of the guys did:
-Trimmed left connector
- Ground B4 pin ( I removed C9 for the buzzer from the connector and installed in B4)
-moved B28 to B16 for cruise light
Pretty straightforward, the temp is only off by a few degrees and the car doesn't even have the auto HVAC so considering it isn't stuck at a certain temp like I have seen, I can't complain. Didn't install a potentiometer for the dimmer because it's really not bad.
Couldn't really find any results for this swap on the WRX TR so I thought I'd give my 0.02
AIDRIIAN is offline   Reply With Quote
Old 07-29-2018, 09:18 PM   #1046
Valarius Starchaser
Member#: 459312
2004 WRX Wagon
Hybrid 6MT Swapped WRB
Default STi cluster swap FAQ - can we get one started?
Anyone else still doing this?
I have an 04 USDM Sti cluster in my 04 USDM WRX wagon and have installed the rear diff temp sensor wiring along with DCCD from iWire for my 6 speed now Im stuck on the ambient temp sensor
I wired a 5v regulator and 2.2k resistor but when I got to the B plug on the cluster thereís no pin in B28 like I expected there to be and a pin in B8 which I didnít expect to find ugh whatís happening here am I reading wrong
I found a good write up from 04 on scooby mods but I donít have a B28 yellow and green tracer wire?
I believe the top row third column over from the right to be B28 but thereís nothing there and seeing as I need 12v power from the dash side of this Iím a little stuck here
Maybe the wagons are different?
Valarius Starchaser is offline   Reply With Quote
Old 07-29-2018, 09:44 PM   #1047
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
You have to add three wires to the b connector and take power from the a connector.
I build a harness that makes it almost PNP.
Here's the diy I did.
https://forums.nasioc.com/forums/showthread.php?t=2704637&styleid=1
AFBeefcake is offline   Reply With Quote
Old 07-29-2018, 11:48 PM   #1048
Valarius Starchaser
Member#: 459312
2004 WRX Wagon
Beefcake man I just didnít use the right search terms cheers should be able wire it up tomorrow
Old 09-22-2018, 01:20 AM   #1049
02WRXGinger18
Member#: 491767
Default Help!!!!
So I am having problems with my 02 Wrx cluster gauge in general. But my speedometer is bouncing up and down as Iím driving above 45mph. I thought maybe speedometer sensor but my buddy is telling me itís he whole cluster. I think heís right bc my gas gauge does not work right after I fill her up it drops dramatically even tho I get the same mpt. My thermostat gauge also bounces from my sub going off same for my speedometer. Well Iíve been driving without music just to make sure I have everything reading right and now my speedometer is bouncing just while driving same with my thermostat(Iíve checked the head gaskets with a pressure test done by Subaru) The thermostat will also bob up and down not like a lot but just a little bit almost like a tiny wobble barely can tell itís even doing that. Do you guys think itís a cluster or the speedometer and some other stuff. I really donít have money to play with since college just started up and Iím kinda looking for a job. If the cluster is the issue Iím just going to buy my buddyís sti v7 cluster for 180.
02WRXGinger18 is offline   Reply With Quote
can we get some mods to start deleting duplicate threads? [27] Political Playground 2 11-05-2008 03:01 AM
STi hare emblem? where can i get one... evoeater8 Interior & Exterior Modification 13 07-12-2006 09:53 PM
can we get something started in RDU???(nc) imprezivSTi04 Mid Atlantic Impreza Club -- MAIC 3 04-04-2006 07:47 PM
02 sti hood scoop?? where can i get one? slaterdrew Private 'Wanted' Classifieds 2 02-06-2004 12:37 PM
lighted keyhole ring, can we get one? makanouchi Interior & Exterior Modification 12 11-22-2002 09:38 PM
