Welcome to the North American Subaru Impreza Owners Club Saturday December 15, 2018
Mid Atlantic Impreza Club
Old 11-03-2006, 02:51 PM   #1
Mach V Dan
Member#: 12029
Default Tuning by Mach V Dan: Case #249 (graphs inside)
Second in an ongoing series. My goal is to share some of the Subarus we tune and discuss them a little bit, hopefully educating. Maybe learning some, too.
This customer has an '06 STI with a turbo-back exhaust (with cat) and an SPT intake. Engine management is Cobb AccessPort. The downpipe is a style that has a wastegate tube that bypasses the downpipe cat.
The first odd thing about this car was the surprisingly low power level with the off-the-shelf Stage 2 map. It was off by about 20 hp compared to the last Stage 2 STI we tuned. Then I looked at the air/fuel trace -- completely rich, past 10.0:1! It appears that the SPT intake is throwing the MAF calibration out of whack. (I think there's a thread about this that the Cobb guys wrote. My experience matches with at least some of that.)
The customer mentioned that he'd been getting terrible mileage; I guess that explains it. I spent some time recalibrating the MAF transfer function, then proceeded dialing in the fuel/boost/timing.
The car ended up making very good power, almost 307 at the wheels. Very impressive for a car with a cat on it. The injector duty cycle was showing completely pegged out at anything past 5000 rpms, though. Any further power mods will require larger fuel injectors (and, from experience, a fuel pump).
Horsepower and torque:
Horsepower vs. wheel speed:
Notice how the power level actually goes down and then back up in the lower trace! Definitely not optimal.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 11-03-2006, 03:02 PM   #2
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
You got to love how that 2.5l can spin a VF39 so quickly, looks like full torque by 3200 RPM!
What’s with the unusual hump in the torque curve?
xcntrk75 is offline   Reply With Quote
Old 11-03-2006, 03:20 PM   #3
TurbojonLS
Member#: 38772
2 Cars, No Bling
Wow - that car should really tear up the course now!
What AFR did you target? Can you post it up?
TurbojonLS is offline   Reply With Quote
Old 11-03-2006, 04:09 PM   #4
Mach V Dan
Member#: 12029
The turbo was basically overshooting its target by a bit when the boost first came on. It wasn't that dramatic on some of the other runs.
Mid-11 tapering down towards 11.0:1 near redline. Here's the graph.
Note the blue curve is all the way to the floor, as rich as it can read. It goes up at the end because the probe kept blowing out of the tailpipe. We had to double-up the safety wire holding it in.
--Dan
Mach V
FastWRX.com
Old 11-03-2006, 05:05 PM   #5
Butt Dyno
Street's closed, pizza boy
Member#: 17301
2016 FoST ST3
2006 Evo #17 STU
Ahh the SPT intake. 4 years too late and apparently kind of a disaster.
WTG, SOA.
john
Old 11-03-2006, 06:09 PM   #6
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
This graph explains the hesitation I was feeling on the straights.
--Dan
Mach V
FastWRX.com
Old 11-03-2006, 06:11 PM   #7
mav1c
Hoodbridge!
Member#: 560
Yeah. I got suckered in. I figured SOA knew what they were doing. IT sure looks and sounds good, but obviously doesn't work so well, at least not on the STI. Now that the car is tuned for it, it will stay on.
WTG, SOA.
john
Old 11-03-2006, 06:47 PM   #8
AcquaCow
Member#: 36838
2001 B50 RSTi
2011 DGM WRX hatch
I'll be by Mach V for a tune shortly I hope.
Wanna get this AP 2.0 =)
-- Dave
AcquaCow is offline   Reply With Quote
Old 11-03-2006, 08:01 PM   #9
Imprezive_04
Member#: 104591
06 STi
I'd like to see if the typhoon has similar results
Imprezive_04 is offline   Reply With Quote
Old 11-03-2006, 08:39 PM   #10
spazegun2213
Member#: 91208
the '13 Ktm Duke
very nice Tim!
Dan, you may have another customer here in a short few weeks (aka, as soon as someone buys my utec).
spazegun2213 is offline   Reply With Quote
Old 11-03-2006, 08:57 PM   #11
AcquaCow
Member#: 36838
2001 B50 RSTi
2011 DGM WRX hatch
No, we did that test already:
-- Dave
Old 11-03-2006, 09:23 PM   #12
Imprezive_04
Member#: 104591
06 STi
that test with the K&N is stock. The car in this post had the intake, DP, and AP and was 20 hp off and runnning way rich. How does the graph of a stock car say anything about if the K&N would have similar results or not.
Old 11-03-2006, 09:30 PM   #13
AcquaCow
Member#: 36838
2001 B50 RSTi
2011 DGM WRX hatch
It's the only one of those things that would affect the MAF?
Dan has seen Aaron's car several times.
Aaron is quite vocal about anything that would cause him issue.
If the K&N were ever an issue throughout his build, Aaron would have said something.
I have Aaron's K&N on my car now, I'll put a DP on and go dyno for you
-- Dave
Mach-ford Files: Case #206 Mach V Dan Engine Management & Tuning 1 08-27-2009 11:33 PM
Tuned by Precision Tuning by Cleo 06wrxlbart Proven Power Bragging 21 06-29-2008 09:31 PM
Mild tune by by John at Precision Tuning Zerogravity Proven Power Bragging 35 03-13-2008 02:24 AM
Get Tuned: Cobb Tuning Visits Mach V Motorsports Mach V Dan MAIC Vendor Classifieds 25 02-11-2007 12:50 AM
Tuning by Mach V Dan: Case #241 (graphs inside) Mach V Dan MAIC Vendor Classifieds 3 10-29-2006 09:10 AM
