09-12-2008, 08:19 AM | #51 |
Member#: 128747
Vehicle:05 STI / 08 STI 12 GMC HD |
godforbid67...thank you for the $10 offer. I might take you up on that I did some research and found that the closest other awd dyno is a few hours away, so it wont happen this year. Maybe next.
and its not "mind boggling"......its "mind bottling"
09-12-2008, 12:09 PM | #52 | |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
even people with the same intake like the 70mm APS unit will all have different loads. it depends on what injector latency, scalar, maf scale and afr targets they are using. I have plotted up 10-20 different 70mm MAF scales from different folks on nasioc and not one of them is the same. Even my car with the same 70mm had a different MAF scale from 2 different tuners. One had my injector scalar at 680, the other had it at 740. Both tunes had great AFR curves, but the MAF scale was way different to achieve it and the loads were different too. |
09-12-2008, 12:17 PM | #53 | |
Member#: 59322
Vehicle:2004 STi WRB,09 G8GT 08 G6, 06 CTS, 2010 Prius |
I didnt waste my time. From this point forward only Pure will be touching my car. Thanks for driving up and meeting me early Saturday. Let me know if you will be at Waterford anytime soon. |
09-12-2008, 01:12 PM | #54 |
Member#: 137168
South East
Vehicle:06 Built SGM WRX 35r, PPG, 280's, PSS9. |
true well the offers out there. and its "mind boggling" google it sir. although mind bottling is something too but im sure its, mind boggling---intellectually overwhelmed---
09-12-2008, 02:15 PM | #55 |
Member#: 128747
Oh my god you are funny! "Mind bottling" was a joke...a quote by will farrel from the movie "blades of glory". Its so funny how everyone becomes an expert at everything when they are behind a computer. Sorry, just a general forum comment.
MNO....good to hear, and no problem. We should plan a waterford hills trip next season. I will keep in touch. |
09-12-2008, 02:20 PM | #56 |
Member#: 36033
SCIC
I just want to make some points here.....you guys dont need to be arguing about this.
Dyno sheets like this are exactly why i started the Data Log Thread Any cars setup similarly are gonna make similar power. The problem comes in with the different dyno numbers, since dynos read so differently (which many people dont even know) the shops that have dynojets typically get recognized as "better" tuners because they produce the highest dyno numbers. You can take my car that made 375whp on a dyno dynamics, while the number isnt low its not as impressive as the 450whp it would make on a dynojet. The point of all this is for Tcal....if you just post 1 WOT log with boost, timing and AFR then no one can argue anymore. I dont care what what individual parts anyone has....if you are running the same turbo (vf39) as someone else and your boost, timing and AFR are all the same, then the car is making the same power. 20psi, 12* of timing and 11:1 AFR with a vf39 will make the same power on any STi (assuming compressions not down). One is not gonna magically make more power with the same air and fuel. The equation is fairly simple.....the more air(oxygen) you can get into the motor, then the more fuel you can burn, the more fuel you burn the more power you make. Turbos are rated by airflow in lb/min IE my Green is 49 lb/min. A good estimate for how much power a turbo can make is simply mulitplying the flow by 10, IE 490 hp and this is flyhweel horsepower, not whp. So since turbos are airflow limited by their compressors/turbines, that means they are power limited. They can only flow so much air, so they can only make so much power. And one tuner cant simply run more timing, more boost, or run leaner than any other tuner. People that really dont know how and what changes are being made in an ECU think that tuners have some special power, or that one tuner can be significantly better than another, which is simply just not true. If you truely believe that your car makes 50 ft*lbs more torque on pump gas, than other maxed out vf39's make on race gas then you know absolutely nothing about turbos, dynos, power and/or tuning. PS: My vf34 wrx made 375whp on XS egnineerings dyno back in 2002-2003 on 91 octane and 18-19psi, i then went to Easystreet a week or 2 after on the same tune and put down 205whp. Thats how different dynos can be. |
09-12-2008, 02:35 PM | #57 | |
Member#: 128747
Alright dick, youre the expert, you win.....my graph is a wrong. Even though another stock turbo under "proven power" just made 401tq, there is no possible way in hell I could have that much. I really regret posting here and have realized that I could care less what you guys have to say. Im out. |
09-12-2008, 03:26 PM | #58 | |
Member#: 36033
SCIC
^ Dude Im not trying to be a dick, im trying to help you understand. I was in the same boat 6 years ago when i dyno'd the 375whp at XS Engineering. It was a 2L WRX with VF34 on 91 octane. My Green'd STi barely makes that on a "normal" dyno on pump gas+ meth at 25-26psi.
When i did 375whp and started telling people i got the same response you are getting. Its just a fact that a vf34 will not flow enough to make that kind of power. So take a look at this dyno (a very high reading one)....and look at what this 415tq was achieved with.....26psi, 93 octane plus methanol, and a very high reading dyno. Im just saying you have to take the relativity into account......your car isnt making the same power as this one because you are on a lower octane therefore you simply cant run the same boost, timing and AFR as this car....its not dictated by the tuner, its dictated by the octane of the gasoline. Im just trying to help you out and explain how different dynos read and the effects of different octanes and whats possible with methanol. Do you really believe that your vf39 on pump gas at 22psi makes the same torque as WRC cars with $20,000 turbos on race gas? If you download enginuity and log you can use airboys spreadsheet to road dyno your car. The road dyno reads right on with dyno dynamics. You could run your car in that to look at the sheet RomRaider/Ecuflash getting started FAQ Here is airboys spreadsheet, It's called Log File Interpolation http://www.ken-gilbert.com/wrx/enginuity/ I think you will be surprised at the different readings you get, just a different way to look at things. Quote:
09-13-2008, 03:28 PM | #59 | |
Member#: 137168
South East
and phatron you sure are being a dick (sarcastic)...........his car is magical dont you understand that yet? you or pure tuning please explain why and how this car is making more tq then any other vf39 without it being maxed out. i mean do you really think your car is making that on a little 22 psi? go in a real 500 ft pound car and then youll feel the difference. i would be very skeptical if my car made that on my old vf39. i would even say its even mathematically impossible in your given situation. |
09-13-2008, 07:52 PM | #60 |
Member#: 128747
Covering myself up? from what? What pisses me off about you guys is not that you are "skeptical", I understand that...its that you say its impossible, or "magical". I have seen other STI's make tq close to mine, hell there is a thread here with one. Yes, its just a #, my measuring point for me to see change in MY car. And yes, maybe my tq reading is a little higher because a mustang dyno's rollers are loaded. Just because you didnt make the power with your vf39 doesnt mean that it cant be done!
09-13-2008, 08:21 PM | #61 |
Member#: 36033
SCIC
just log a 4th gear pull and use airboys road dyno and post that sheet up.
you're right its just a number, but we are trying to explain to you that 420 Ft*lbs is ASTRONOMICAL on PUMP gas. its not a mere 5-10-20 higher than the "average" its about 70 ft*lbs higher my vf39 did 380 ft*lbs on race gas and 26psi. |
09-13-2008, 09:03 PM | #62 |
Member#: 89752
SCIC
Vehicle:08 STI SWP |
I have to agree with Ron. It is a physical impossibility for a VF39 running 22 psi of boost to make 420+wtq on pump gas. Even if the car was far more knock resistant than most, there is no way to run enough timing to make that number on a correctly calibrated dyno. Mustang dynos need to be correctly setup to spit out accurate results. This one need to have its settings checked because the whp seems about right, but as others have said torque is out of whack. As an example, the Corvette shop next door to us dynoed a buddy's Z06 after he changed the oil with Eneos 5w40. He made 60whp more than he did last week. W00000t for oil that makes 60 whp Or perhaps the tech who ran the dyno didn't input the right settings (he normally doesn't run the dyno there).
09-13-2008, 09:26 PM | #63 |
Member#: 63179
BAIC
Vehicle:2006 Stock Turbo STi [email protected] VF39 |
damn this is getting funny
425wtq on pump gas... kinda crazy if you ask me when i had similar set up as you, 91 octane Pump gas, @ 20psi.. i only made 314wtq Last edited by downsti; 09-13-2008 at 09:49 PM. |
09-13-2008, 09:29 PM | #64 |
Member#: 137168
South East
your mad cuz we say its impossible..............i mean come on man IT IS impossible to make that much tq at only 22 psi!
i mean tell me what is so special about your car that it can make that much more power, then any other bolt on sti. |
stock sti turbo power... | thejackal0 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 02-03-2005 10:58 PM |
u think ur stock turbo made power, check out my dyno results | jdmej20 | Proven Power Bragging | 64 | 11-25-2003 02:08 PM |
does the sti intake manifold make any power with the stock turbo? | blackie | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 11-06-2003 12:33 AM |
Max power potential from stock turbo. | KillerRex | Proven Power Bragging | 14 | 07-13-2002 06:20 PM |
Top End Power mods W/stock turbo | FuZZyLoGiC | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 05-17-2002 08:41 PM |
