Welcome to the North American Subaru Impreza Owners Club Sunday July 22, 2018
Old 05-08-2012, 10:13 AM   #3351
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
Just to let people know, Sti of Japan has a safety notification for the Sti S203, 204 and Ra-R.
It has to do with the silicone red turbo inlet and a metal part rubbing against a fuel line.
The S202 is not affected and I think this may have to do with the routing of the fuel lines under the manifold, which is a bit different for V8, 9 vs V7.
Old 05-08-2012, 10:18 AM   #3352
04ImprezaWRX
Member#: 120237
2004 WRX
Hey guys I have some v7 ej207 heads getting some loving at headgames. I want to run the gsc 272 avcs cams. Does anyone know what standalones can run the avcs. I was hoping to spend 1,000 or less. I have heard of people modding their aem units to run the magnetic avcs but couldn't find a thread or information about this. My shortblock is a sleeved destroked ej257 giving me the reason to believe the stock ecu will hurt my motors potential. I do have a v8 JDM ecu as well as the correct utec. Thanks for the help!
04ImprezaWRX is offline   Reply With Quote
Old 05-08-2012, 12:25 PM   #3353
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
i dont think you will find any standalones for less than 1k that will control avcs, unless you find a good deal used.
Autronic SM4 is the only one that i'm aware of. I do recall talking to [email protected] that Hydra should be able to control it. The guys at AEM were useless and wouldnt even send me one for eval and R&D feedback for less than retail and could not confirm if it would work with the JDM avcs solenoids.
fastnoypi is offline   Reply With Quote
Old 05-08-2012, 12:39 PM   #3354
mike280
Member#: 161437
02 WRX Wagon
EJ207
JDM and USDM AVCS is different and you can't mix them. You need something that works with JDM cams...
If you are going to run USDM cams you need a US ecu.
mike280 is offline   Reply With Quote
Old 05-08-2012, 12:53 PM   #3355
04ImprezaWRX
Member#: 120237
2004 WRX
Yes I know this magnetic=JDM, hall-effect= USDM. I thought people were opening up the aem to make the JDM sensors work with it.
Old 05-09-2012, 08:25 PM   #3356
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
I need help with my Version 8 swap EJ207 people!
I recently logged AVCS advance and was seeing right around 70 degrees on both sides. After a bit of research, I found a thread that mentions the same problem and the solution being swapping the polarity of the wires in the AVCS sensor plugs. I went to do that and found my AVCS sensors unplugged. I cleaned and plugged them in to find a flashing CEL. I remembered hearing that this can be caused by the JDM IAT sensor being plugged in under the TB. I took off the TMIC and found mine plugged in, so I unplugged it.
Now is where it gets strange. I start the car and it idles fine, shows small AVCS changes with a blip of the throttle and IAM comes right back up to 8. However, once driving I logged massive AVCS advance on the right (up to 61 degrees) and only a small amount on the left (up to 5 degrees). Also, when depressing the clutch, the right side AVCS will hang causing the car to idle rough for a few seconds before it returns to zero. Does anyone have any idea what I should try next? And which side is which, right/left, drivers or passengers?
EDIT: Here is a log of what is happening. It looks like left side is frozen. If so, which side is left? Will the sides being out of phase cause the right to default to full advance? When you take the solenoids/OCVs out, how do you make sure they are functional?
Code:
Time	(rpm)	OCV Current Left	OCV Current RightOCV Duty Left	OCV Duty Right	VVT Advance Left	VVT Advance Right	Coolant Temperature (F)
0	696	0.06	0.06	9.41	9.41	0	0	194
0	708	0.09	0.06	9.41	9.41	0	0	194
0	704	0.09	0.06	9.41	9.41	0	0	194
16	704	0.09	0.06	9.41	9.41	0	0	194
47	706	0.09	0.06	9.41	9.41	0	0	194
94	693	0.09	0.06	9.41	9.41	0	0	194
141	686	0.09	0.06	9.41	9.41	0	0	194
187	686	0.09	0.06	9.41	9.41	0	0	194
219	689	0.06	0.06	9.41	9.41	0	0	194
265	700	0.06	0.06	9.41	9.41	0	0	194
312	700	0.06	0.06	9.41	9.41	0	0	194
359	699	0.09	0.06	9.41	9.41	0	0	194
390	693	0.09	0.06	9.41	9.41	0	0	194
390	699	0.09	0.06	9.41	9.41	0	0	194
437	700	0.06	0.06	9.41	9.41	0	0	194
484	700	0.06	0.06	9.41	9.41	0	0	194
531	701	0.09	0.09	9.41	9.41	0	0	194
577	701	0.09	0.09	9.41	9.41	0	0	194
609	710	0.06	0.06	9.41	9.41	0	0	194
655	710	0.06	0.06	9.41	9.41	0	0	194
702	714	0.06	0.06	9.41	9.41	0	0	194
765	706	0.06	0.06	9.41	9.41	0	0	194
796	708	0.06	0.06	9.41	9.41	0	0	194
843	708	0.06	0.06	9.41	9.41	0	0	194
889	715	0.06	0.06	9.41	9.41	0	0	194
936	713	0.09	0.09	9.41	9.41	0	0	194
1014	713	0.06	0.06	9.41	9.41	0	0	194
1014	713	0.09	0.09	9.41	9.41	0	0	194
1092	704	0.09	0.06	9.41	9.41	0	0	194
1092	713	0.06	0.06	9.41	9.41	0	0	194
1186	712	0.09	0.06	9.41	9.41	0	0	194
1201	718	0.06	0.06	9.41	9.41	0	0	194
1248	711	0.53	0.25	52.94	24.31	0	0	194
1248	718	0.06	0.06	9.41	24.31	0	0	194
1279	713	0.59	0.25	52.94	24.31	0	0	194
1326	713	0.59	0.25	52.94	24.31	0	0	194
1373	700	0.59	0.25	52.94	24.31	0	0	194
1420	700	0.59	0.25	52.94	24.31	0	0	194
1451	744	0.62	0.22	52.94	20.78	0	2	194
1498	744	0.62	0.22	52.94	19.61	0	2	194
1545	934	0.62	0.19	52.94	19.61	0	4	194
1576	1242	0.62	0.19	52.94	18.43	0	10	194
1623	1242	0.62	0.19	52.94	18.43	0	10	194
1669	1518	0.62	0.16	52.94	17.25	0	13	194
1701	1765	0.62	0.16	52.94	17.25	0	20	194
1716	1518	0.62	0.16	52.94	17.25	0	13	194
1872	1907	0.62	0.16	52.94	17.25	0	30	194
1872	1893	0.59	0.16	52.94	17.25	0	25	194
1872	1893	0.59	0.16	52.94	17.25	0	20	194
1903	1840	0.62	0.16	52.94	17.25	0	35	194
1950	1800	0.62	0.16	52.94	17.25	0	35	194
1981	1800	0.62	0.16	52.94	17.25	0	41	194
2028	1771	0.62	0.16	52.94	17.25	0	46	194
2075	1771	0.62	0.16	52.94	17.25	0	46	194
2122	1758	0.62	0.16	52.94	17.25	0	50	194
2153	1732	0.62	0.16	52.94	17.25	0	50	194
2200	1732	0.62	0.16	52.94	17.25	0	52	194
2247	1698	0.62	0.16	52.94	17.25	0	52	194
2278	1658	0.62	0.16	52.94	17.25	0	53	194
2278	1698	0.62	0.16	52.94	17.25	0	52	194
2387	1590	0.69	0.16	57.25	17.25	0	53	194
2403	1621	0.62	0.16	52.94	17.25	0	53	194
2403	1658	0.62	0.16	52.94	17.25	0	53	194
2605	1533	0.66	0.16	56.86	17.25	0	53	194
2605	1590	0.69	0.16	57.25	17.25	0	53	194
2637	1437	0.66	0.16	56.86	17.25	0	53	194
2637	1480	0.66	0.16	56.86	17.25	0	53	194
2683	1437	0.66	0.16	56.86	17.25	0	53	194
2715	1369	0.69	0.16	56.47	17.25	0	53	194
2730	1369	0.69	0.16	56.47	17.25	0	53	194
2761	1385	0.66	0.16	56.86	17.25	0	53	194
2808	1399	0.66	0.16	56.86	17.25	0	53	194
2855	1399	0.66	0.16	56.86	17.25	0	53	194
2886	1437	0.66	0.16	56.86	17.25	0	53	194
2949	1437	0.66	0.16	56.86	17.25	0	53	194
2980	1425	0.66	0.16	56.86	17.25	0	53	194
3027	1446	0.66	0.16	56.86	17.25	0	53	194
3058	1468	0.66	0.16	56.86	17.25	0	53	194
3058	1446	0.66	0.16	56.86	17.25	0	53	194
3198	1482	0.69	0.16	56.86	17.25	0	53	194
3198	1468	0.66	0.16	56.86	17.25	0	53	194
3229	1541	0.69	0.16	56.86	17.25	0	52	194
3261	1660	0.66	0.16	57.25	17.25	0	52	194
3292	1660	0.66	0.16	57.25	17.25	0	52	194
3307	1769	0.66	0.16	57.25	17.25	0	52	194
3432	1830	0.69	0.16	57.25	17.25	0	52	194
3432	1769	0.66	0.16	57.25	17.25	0	52	194
3479	1862	0.66	0.16	57.25	17.25	0	52	194
3526	1862	0.66	0.16	57.25	17.25	0	52	194
3557	1926	0.66	0.16	57.25	17.25	0	52	194
3604	1926	0.66	0.16	57.25	17.25	0	52	194
3651	2006	0.69	0.16	57.65	17.25	0	52	194
3682	2096	0.66	0.16	57.65	16.86	0	51	194
3682	2096	0.66	0.16	57.65	16.86	0	52	194
3807	2159	0.69	0.16	57.65	16.86	0	52	194
3838	2249	0.66	0.16	57.65	16.47	0	52	194
3853	2212	0.69	0.16	57.65	16.47	0	52	194
3853	2159	0.69	0.16	57.65	16.86	0	52	194
3885	2249	0.66	0.16	57.65	16.47	0	51	194
3931	2340	0.69	0.16	57.65	16.47	0	51	194
3963	2340	0.69	0.16	57.65	16.47	0	51	194
4009	2412	0.69	0.16	57.65	16.08	0	51	194
4056	2412	0.69	0.16	57.65	15.69	0	51	194
4087	2495	0.66	0.16	57.65	15.69	0	51	194
4134	2562	0.66	0.12	57.65	15.69	0	50	194
4181	2562	0.66	0.12	57.65	15.69	0	50	194
4212	2611	0.69	0.16	57.65	15.69	0	51	194
4259	2679	0.69	0.16	57.65	15.29	0	50	194
4259	2611	0.69	0.16	57.65	15.29	0	51	194
4368	2841	0.66	0.12	57.65	14.9	0	50	194
4384	2765	0.69	0.16	57.65	15.29	0	50	194
4493	2940	0.69	0.12	57.65	15.29	0	50	194
4493	2894	0.69	0.16	57.65	14.9	0	50	194
4493	2841	0.66	0.12	57.65	14.9	0	50	194
4540	2940	0.69	0.12	57.65	15.29	0	50	194
4587	2980	0.69	0.16	57.65	14.9	0	50	194
4618	2980	0.69	0.16	57.65	15.29	0	50	194
4665	3040	0.66	0.12	57.65	15.29	0	50	194
4711	3121	0.66	0.12	57.65	15.29	0	50	194
4758	3121	0.66	0.12	57.65	15.29	0	50	194
4821	3159	0.69	0.12	57.65	14.9	0	50	194
4867	3217	0.66	0.12	57.65	14.9	0	50	194
4914	3245	0.66	0.12	57.65	13.73	0	50	194
4961	3311	0.69	0.12	57.65	13.73	0	50	194
4961	3245	0.66	0.12	57.65	13.73	0	50	194
5070	3363	0.66	0.12	57.65	13.73	0	50	194
5086	3311	0.69	0.12	57.65	13.73	0	50	194
5211	3434	0.69	0.12	57.65	13.73	0	50	194
5211	3383	0.66	0.12	57.65	13.73	0	50	194
5257	3434	0.69	0.12	57.65	13.73	0	50	194
5257	3470	0.69	0.12	57.65	13.73	0	50	194
5289	3470	0.69	0.12	57.65	13.73	0	50	194
5335	3511	0.69	0.12	57.65	13.73	0	50	194
5367	3536	0.69	0.12	57.65	13.73	0	50	194
5413	3536	0.69	0.12	57.65	13.73	0	50	194
5445	3576	0.69	0.12	57.65	13.73	0	50	194
5491	3576	0.69	0.12	57.65	13.73	0	50	194
5538	3602	0.69	0.12	57.65	13.73	0	50	194
5585	3639	0.66	0.12	57.65	13.73	0	50	194
5616	3691	0.69	0.12	57.65	13.73	0	50	194
5616	3639	0.66	0.12	57.65	13.73	0	50	194
5741	3754	0.69	0.12	57.65	13.73	0	50	194
5741	3737	0.66	0.12	57.65	13.73	0	50	194
5741	3691	0.69	0.12	57.65	13.73	0	50	194
5788	3754	0.69	0.12	57.65	13.73	0	50	194
5835	3746	0.66	0.12	56.08	13.73	0	50	194
5866	3746	0.66	0.12	56.08	13.73	0	50	194
5913	3735	0.62	0.12	52.94	13.73	0	50	194
5959	3735	0.62	0.12	52.94	13.73	0	50	194
5975	3687	0.62	0.12	52.94	13.73	0	50	194
5991	3602	0.62	0.12	52.94	13.73	0	51	194
6115	3496	0.62	0.12	52.94	13.73	0	51	194
6115	3602	0.62	0.12	52.94	13.73	0	51	194
6162	3496	0.62	0.12	52.94	13.73	0	51	194
6209	3323	0.59	0.12	52.94	13.73	0	51	194
6209	3395	0.62	0.12	52.94	13.73	0	51	194
6240	3323	0.59	0.12	52.94	13.73	0	51	194
6287	3210	0.62	0.12	52.94	13.73	0	51	194
6334	3210	0.62	0.12	52.94	13.73	0	51	194
6381	3135	0.62	0.12	52.94	13.73	0	51	194
6427	3019	0.62	0.12	52.94	13.73	0	51	194
6505	3019	0.62	0.12	52.94	13.73	0	51	194
6552	2934	0.69	0.12	57.65	14.51	0	51	194
6599	2741	0.69	0.12	57.65	14.51	0	51	194
6599	2835	0.69	0.12	57.65	14.9	0	51	194
6646	2741	0.69	0.12	57.65	14.51	0	51	194
6677	2734	0.69	0.12	57.65	14.9	0	51	194
6724	2734	0.69	0.12	57.65	14.9	0	51	194
6771	2761	0.69	0.12	57.65	14.9	0	50	194
6817	2761	0.69	0.12	57.65	14.9	0	50	194
6849	2766	0.66	0.12	57.65	14.9	0	51	194
6911	2788	0.69	0.12	57.65	14.12	0	51	194
6958	2789	0.69	0.12	57.65	14.12	0	51	194
7005	2789	0.69	0.12	57.65	14.12	0	51	194
7036	2753	0.69	0.12	57.65	14.12	0	51	194
7036	2774	0.66	0.12	57.65	14.12	0	51	194
7161	2712	0.69	0.12	57.65	14.51	0	51	194
7161	2712	0.69	0.12	57.65	14.12	0	51	194
7161	2753	0.69	0.12	57.65	14.12	0	51	194
7285	2524	0.69	0.12	57.65	14.9	0	51	194
7285	2627	0.69	0.12	57.65	14.51	0	51	194
7410	2600	0.69	0.12	57.65	14.9	0	51	194
7410	2486	0.69	0.16	57.65	14.9	0	51	194
7410	2486	0.69	0.16	57.65	15.29	0	51	194
7457	2641	0.69	0.12	57.65	14.9	0	51	194
7488	2641	0.69	0.12	57.65	14.9	0	50	194
7519	2670	0.66	0.12	57.65	14.51	0	51	194
7535	2670	0.66	0.12	57.65	14.51	0	51	194
7660	2763	0.69	0.12	57.65	14.12	0	50	194
7707	2730	0.69	0.12	57.65	14.12	0	51	194
7738	2771	0.69	0.12	57.65	14.12	0	50	194
7800	2771	0.69	0.12	57.65	14.12	0	50	194
7831	2874	0.66	0.12	57.65	13.73	0	51	194
7847	2874	0.66	0.12	57.65	13.73	0	51	194
7878	2892	0.69	0.12	57.65	13.73	0	51	194
7925	2892	0.66	0.12	57.65	13.73	0	51	194
7972	2892	0.66	0.12	57.65	13.73	0	51	194
8019	2969	0.66	0.12	57.65	13.73	0	51	194
8050	2969	0.66	0.12	57.65	13.73	0	51	194
8097	3002	0.69	0.12	57.65	13.73	0	51	194
8128	3040	0.66	0.12	57.65	13.73	0	51	194
8143	3040	0.66	0.12	57.65	13.73	0	51	194
8299	3088	0.66	0.12	57.65	13.73	0	51	194
8331	3179	0.66	0.12	57.65	13.73	0	51	194
8346	3179	0.66	0.12	57.65	13.73	0	51	194
8346	3146	0.66	0.12	57.65	13.73	0	51	194
8377	3209	0.66	0.12	57.65	13.73	0	51	194
8424	3209	0.66	0.12	57.65	13.73	0	51	194
8440	3249	0.69	0.12	57.65	13.73	0	51	194
8502	3249	0.69	0.12	57.65	13.73	0	51	194
8549	3320	0.69	0.12	57.65	13.73	0	51	194
8580	3328	0.69	0.12	57.65	13.73	0	51	194
8596	3328	0.69	0.12	57.65	13.73	0	51	194
8721	3442	0.69	0.12	57.65	13.73	0	51	194
8721	3398	0.69	0.12	57.65	13.73	0	51	194
8845	3514	0.69	0.12	57.65	13.73	0	51	194
8845	3456	0.69	0.12	57.65	13.73	0	51	194
8877	3514	0.69	0.12	57.65	13.73	0	51	194
8923	3558	0.66	0.12	57.65	13.73	0	50	194
8970	3606	0.69	0.12	57.65	13.73	0	50	194
9001	3606	0.69	0.12	57.65	13.73	0	50	194
9048	3639	0.69	0.12	57.65	13.73	0	50	194
9079	3639	0.69	0.12	57.65	13.73	0	50	194
9095	3694	0.66	0.12	57.65	13.73	0	50	194
9220	3740	0.69	0.12	57.65	13.73	0	50	194
9251	3782	0.69	0.12	57.65	13.73	0	50	194
9313	3782	0.69	0.12	57.65	13.73	0	50	194
9376	3818	0.66	0.12	57.65	13.73	0	50	194
9391	3898	0.66	0.12	57.65	13.73	0	50	194
9501	3976	0.66	0.12	57.65	13.73	0	50	194
9501	3939	0.69	0.12	57.65	13.73	0	50	194
9547	3976	0.66	0.12	57.65	13.73	0	50	194
9579	4043	0.69	0.12	57.65	13.73	0	50	194
9625	4065	0.69	0.12	57.65	13.73	0	50	194
9672	4065	0.69	0.12	57.65	13.73	0	50	194
9703	4130	0.66	0.12	57.65	13.73	0	50	194
9750	4130	0.66	0.12	57.65	13.73	0	50	194
9813	4152	0.69	0.12	57.65	13.73	0	50	194
9844	4213	0.69	0.12	57.65	13.73	0	50	194
9891	4225	0.66	0.12	57.65	13.73	0	50	194
9937	4225	0.66	0.12	57.65	13.73	0	50	194
9984	4280	0.69	0.12	57.65	13.73	0	50	194
10015	4315	0.69	0.12	57.65	13.73	0	50	194
10078	4315	0.69	0.12	57.65	13.73	0	50	194
10125	4318	0.69	0.12	57.65	13.73	0	50	194
10156	4318	0.69	0.12	57.65	13.73	0	50	194
10218	4398	0.66	0.12	57.65	13.73	0	50	192
10218	4322	0.69	0.12	57.65	13.73	0	50	194
10249	4398	0.66	0.12	57.65	13.73	0	50	192
10296	4398	0.69	0.12	57.65	13.73	0	50	192
10327	4398	0.69	0.12	57.65	13.73	0	50	192
10374	4308	0.62	0.12	52.94	13.73	0	50	192
10421	4308	0.62	0.12	52.94	13.73	0	50	192
10452	4290	0.62	0.12	52.94	13.73	0	50	192
10499	4220	0.62	0.12	52.94	13.73	0	50	192
10546	4220	0.62	0.12	52.94	13.73	0	50	192
10577	4089	0.62	0.12	52.94	13.73	0	50	192
10655	3898	0.59	0.12	52.94	13.73	0	50	192
10671	4000	0.62	0.12	52.94	13.73	0	50	192
10717	3898	0.59	0.12	52.94	13.73	0	50	192
10764	3767	0.62	0.12	52.94	13.73	0	51	192
10795	3767	0.62	0.12	52.94	13.73	0	51	192
10858	3564	0.62	0.12	52.94	13.73	0	51	192
10858	3666	0.62	0.12	52.94	13.73	0	51	192
10889	3564	0.62	0.12	52.94	13.73	0	51	192
10936	3494	0.62	0.12	52.94	13.73	0	51	192
10967	3494	0.62	0.12	52.94	13.73	0	51	192
11029	3390	0.62	0.12	52.94	13.73	0	51	192
11061	3278	0.69	0.12	52.94	13.73	0	51	192
11107	3278	0.69	0.12	57.65	13.73	0	51	192
11154	3170	0.69	0.12	57.65	13.73	0	51	192
11185	3170	0.69	0.12	57.65	13.73	0	51	192
11232	3001	0.69	0.12	57.65	14.12	0	51	192
11263	3094	0.69	0.12	57.65	14.51	0	51	192
11263	3001	0.69	0.12	57.65	14.51	0	51	192
11388	3089	0.66	0.12	57.65	14.51	0	51	192
11388	3113	0.69	0.12	57.65	14.51	0	51	192
11497	3093	0.66	0.12	57.65	13.73	0	51	192
11497	3082	0.66	0.12	57.65	13.73	0	51	192
11513	3089	0.66	0.12	57.65	13.73	0	51	192
11622	3096	0.69	0.12	57.65	13.73	0	51	192
11622	3093	0.66	0.12	57.65	13.73	0	51	192
11731	3116	0.69	0.12	57.65	13.73	0	51	192
11747	3136	0.69	0.12	57.65	13.73	0	51	192
11856	3147	0.66	0.12	57.65	13.73	0	51	192
11856	3176	0.69	0.12	57.65	13.73	0	51	192
11981	3194	0.69	0.12	57.65	13.73	0	51	190
11981	3193	0.66	0.12	57.65	13.73	0	51	190
12012	3194	0.69	0.12	57.65	13.73	0	51	190
12059	3209	0.69	0.12	57.65	13.73	0	51	190
12090	3232	0.66	0.12	57.65	13.73	0	51	190
12106	3232	0.66	0.12	57.65	13.73	0	51	190
12246	3256	0.69	0.12	57.65	13.73	0	51	190
12277	3254	0.66	0.12	57.65	13.73	0	51	190
12293	3254	0.66	0.12	57.65	13.73	0	51	190
12293	3256	0.69	0.12	57.65	13.73	0	51	190
12480	3295	0.66	0.12	57.65	13.73	0	51	190
12480	3305	0.69	0.12	57.65	13.73	0	51	190
12527	3360	0.69	0.12	57.65	13.73	0	51	190
12527	3320	0.69	0.12	57.65	13.73	0	51	190
12589	3358	0.66	0.12	57.65	13.73	0	51	190
12621	3358	0.66	0.12	57.65	13.73	0	51	190
12636	3398	0.66	0.12	57.65	13.73	0	51	190
12652	3398	0.66	0.12	57.65	13.73	0	51	190
12777	3459	0.66	0.12	57.65	13.73	0	51	190
12777	3417	0.69	0.12	57.65	13.73	0	51	190
12901	3464	0.69	0.12	57.65	13.73	0	51	190
12901	3461	0.66	0.12	57.65	13.73	0	51	190
13026	3524	0.66	0.12	57.65	13.73	0	51	190
13026	3511	0.66	0.12	57.65	13.73	0	50	190
13026	3511	0.66	0.12	57.65	13.73	0	51	190
13135	3561	0.69	0.12	57.65	13.73	0	51	190
13135	3558	0.69	0.12	57.65	13.73	0	51	190
13135	3524	0.66	0.12	57.65	13.73	0	51	190
13260	3583	0.69	0.12	57.65	13.73	0	50	190
13260	3561	0.69	0.12	57.65	13.73	0	50	190
13307	3597	0.69	0.12	57.65	13.73	0	50	190
13338	3597	0.69	0.12	57.65	13.73	0	50	190
13369	3623	0.66	0.12	57.65	13.73	0	50	190
13385	3637	0.66	0.12	57.65	13.73	0	50	190
13510	3664	0.69	0.12	57.65	13.73	0	50	190
13510	3637	0.66	0.12	57.65	13.73	0	50	190
13541	3664	0.69	0.12	57.65	13.73	0	50	190
13588	3680	0.69	0.12	57.65	13.73	0	50	190
13635	3700	0.69	0.12	57.65	13.73	0	50	190
13666	3700	0.69	0.12	57.65	13.73	0	50	190
13728	3738	0.69	0.12	57.65	13.73	0	50	190
13759	3738	0.69	0.12	57.65	13.73	0	50	190
13791	3803	0.69	0.12	57.65	13.73	0	50	190
13791	3735	0.69	0.12	57.65	13.73	0	50	190
13915	3807	0.69	0.12	57.65	13.73	0	50	189
13915	3803	0.69	0.12	57.65	13.73	0	50	189
13962	3828	0.66	0.12	57.65	13.73	0	50	189
14009	3828	0.66	0.12	57.65	13.73	0	50	189
14025	3840	0.69	0.12	57.65	13.73	0	50	189
14040	3844	0.69	0.12	57.65	13.73	0	50	189
14165	3900	0.66	0.12	57.65	13.73	0	50	189
14165	3844	0.69	0.12	57.65	13.73	0	50	189
14212	3900	0.66	0.12	57.65	13.73	0	50	189
14243	3900	0.66	0.12	57.65	13.73	0	50	189
14290	3922	0.69	0.12	57.65	13.73	0	50	189
14337	3922	0.69	0.12	57.65	13.73	0	50	189
14368	3939	0.66	0.12	57.65	13.73	0	50	189
14415	3939	0.66	0.12	57.65	13.73	0	50	189
14446	3981	0.69	0.12	57.65	13.73	0	50	189
14446	3962	0.69	0.12	57.65	13.73	0	50	189
14571	3976	0.66	0.12	57.65	13.73	0	50	189
14571	3981	0.69	0.12	57.65	13.73	0	50	189
14680	4000	0.66	0.12	57.65	13.73	0	50	189
14695	4026	0.66	0.12	57.65	13.73	0	50	189
14805	4038	0.69	0.12	57.65	13.73	0	50	189
14805	4058	0.69	0.12	57.65	13.73	0	50	189
14851	4041	0.66	0.12	57.65	13.73	0	50	189
14898	4041	0.66	0.12	57.65	13.73	0	50	189
14929	4076	0.66	0.12	57.65	13.73	0	50	189
14976	4076	0.66	0.12	57.65	13.73	0	50	189
15023	4060	0.66	0.12	57.65	13.73	0	50	189
15054	4060	0.66	0.12	57.65	13.73	0	50	189
15101	4092	0.66	0.12	57.65	13.73	0	50	189
15148	4028	0.66	0.12	57.65	13.73	0	50	189
15179	4028	0.66	0.12	52.94	13.73	0	50	189
15241	4019	0.62	0.12	52.94	13.73	0	50	189
15273	4019	0.62	0.12	52.94	13.73	0	50	189
15319	3949	0.62	0.12	52.94	13.73	0	51	189
15351	3828	0.62	0.12	52.94	13.73	0	51	189
15397	3731	0.59	0.12	52.94	13.73	0	51	189
15444	3731	0.59	0.12	52.94	13.73	0	51	189
15475	3632	0.62	0.12	52.94	13.73	0	51	189
15522	3532	0.62	0.12	52.94	13.73	0	51	189
15553	3532	0.62	0.12	52.94	13.73	0	51	189
15585	3464	0.62	0.12	52.94	13.73	0	51	189
15600	3464	0.62	0.12	52.94	13.73	0	51	189
15725	3249	0.62	0.12	52.94	13.73	0	51	189
15725	3358	0.62	0.12	52.94	13.73	0	51	189
15772	3249	0.62	0.12	52.94	13.73	0	51	189
15819	3174	0.62	0.12	52.94	13.73	0	51	189
15834	3174	0.62	0.12	52.94	13.73	0	51	189
15881	3062	0.62	0.12	52.94	13.73	0	51	189
15928	2978	0.62	0.12	52.94	13.73	0	51	189
16037	2898	0.62	0.12	52.94	13.73	0	51	189
16053	2898	0.62	0.12	52.94	13.73	0	51	189
16099	2817	0.72	0.12	57.65	14.12	0	51	189
16131	2776	0.69	0.12	57.65	14.9	0	51	189
16131	2817	0.72	0.12	57.65	14.9	0	51	189
16162	2831	0.69	0.12	57.65	14.9	0	51	189
16209	2831	0.69	0.12	57.65	14.9	0	51	189
16255	2968	0.69	0.12	57.65	15.29	0	50	189
16302	2968	0.69	0.12	57.65	14.51	0	50	189
16333	3001	0.69	0.12	57.65	14.51	0	51	189
16380	2948	0.69	0.12	57.65	14.51	0	51	189
16411	2948	0.69	0.12	57.65	14.51	0	51	189
16458	2820	0.69	0.12	57.65	13.73	0	51	189
16505	2820	0.69	0.12	57.65	13.73	0	51	189
16536	2920	0.69	0.12	57.65	13.73	0	51	189
16583	2852	0.69	0.12	57.65	13.73	0	51	189
16630	2852	0.69	0.12	57.65	13.73	0	51	189
16661	2906	0.69	0.12	57.65	13.73	0	51	189
OppositeLock is offline   Reply With Quote
Old 05-09-2012, 09:31 PM   #3357
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
check the screen filters going into the solenoids to start. the one could be being starved for oil. as far as 61* that is nuts. you may also want to take the solenoids off themselves and make sure they have clean passage ways.
btw your td04 record was my ultimate goal. until i got into a crash now its 12.3 w/ the vf37 lol
WhiteBgeye02 is offline   Reply With Quote
Old 05-10-2012, 08:02 AM   #3358
WRick
Member#: 86107
We are assuming you have a v8?
WRick is offline   Reply With Quote
Old 05-10-2012, 11:01 AM   #3359
OppositeLock
Member#: 54060
Already checked to confirm that V8 does not have the screens. Also, I slid the solenoids/ocv's out without taking them all the way off. They looked okay (like parts bathed in oil), but after some additional work and logging, I suspect they may still actually be the problem. I will take them out tonight.
Thanks, wish I hadn't been so greedy with the td04 setup. If I hadn't added timing and boost over Junior's tune, I think it would have survived a bit longer and gone faster. I have/had plans to try to run in the 11's with this setup this summer, but this AVCS thing is holding those plans back.
Thanks, you are correct. Version 8 added to my post.
Old 05-10-2012, 11:10 AM   #3360
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Not nitpickin, but my 2003 JDM v8 had the screens in the solenoids.
n2xlr8n is offline   Reply With Quote
Old 05-10-2012, 11:21 AM   #3361
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
Screens = humphead banjo bolt.
No screens = flathead banjo bolt.
So the tuning of the 207 and the 12.3/ q mile was with no AVCS?
Old 05-10-2012, 11:26 AM   #3362
OppositeLock
Member#: 54060
Thanks for the info, wasn't aware that some v8's had the screens.
Again thanks, good to know about the shape of the bolt heads determining whether there are screens or not.
It appears that way, unless there is some way to have AVCS work with the rear sensors unplugged. Also, just confirmed by unplugging that they default to roughly 70 degrees, not zero, when unplugged.
Old 05-10-2012, 11:39 AM   #3363
WRick
Member#: 86107
I don't think 70 degrees is even mechanically possible !!! isn't the max around 30 ?
Old 05-10-2012, 01:53 PM   #3364
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
mine runs at 45 when i am getting into it and tapers off as rpm climbs. so i know 45 is possible. if it was at 60* it would be basically blowing a ton of exh gas into the intake so i think maybe the sensors are bad or something
Old 05-10-2012, 01:54 PM   #3365
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
how much of a hump are we talking? a mm higher or a few? i need to check my lines.... ughhh
Old 05-10-2012, 02:16 PM   #3366
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
From what I recall, the hump is roughly 2mm and slightly tapering. The hump does not extend to the whole area of the head, but confined to the middle, while the outside area is flat. It's quite noticeable.
The other way around you have a flat hexhead bolt.
Now, it's possible to have the hump bolts but someone have performed the TSB on those, in Japan.
45 degree AVCS is in the OEM AVCS map, for some JDM. It's achievable.
Unplugging the solenoid, or deactivating it, was said in the past to return that to a low number, not to max.
But it's position is reported by the sensor.
The sensor reading may default to max, when the sensor is unplugged, without the mechanical position to attain such an angle.
In fact the mechanical position may be zero or 2 degrees, I think that's what was said. I don't recall what it was on mine before activating the AVCS.
Opposite, do you have a diagram that you're checking the wiring against?
Old 05-10-2012, 02:33 PM   #3367
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
my avcs on my v8 was zero before the nps reverse. it would stay at 0 on both. sometimes might move 1-2* but that is prob cam rotation float or just a sensor misread by a frog hair.
Old 05-10-2012, 09:07 PM   #3368
candamo
Member#: 288732
2003 JDM STi
So far loving the EJ207, love it way more than the 257...
Dynoed 289AWHP on a mustang dyno with 98oct and like 100F ambient temp.
I've been getting some sort of limiter at revs much lower than my rev limit when pushed to hard. Did some logs and there was a bit of knock, and also my IDC where like 104%.
Just bought a Deatschwerks fuel pump and 750cc injectors to hopefully sort out the problems and gain a few more horses.
candamo is offline   Reply With Quote
Old 05-10-2012, 09:29 PM   #3369
OppositeLock
Member#: 54060
Added some logs and questions to my post above, please take a look and share any ideas.
Old 05-11-2012, 07:36 AM   #3370
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
I know you posted in the past, but can you update what year chassis it is and what solution you used for AVCS wiring.
Did the ECU part number match the engine, was it a V8? Also the ROM code is a V8?
In the factory repair manual for EJ207 there is not much about testing AVCS solenoids and sensors. I guess they would have the full procedure in an endwrench type publication.
I'll ask when I go to the dealer tomorrow what they use for the US AVCS.
Old 05-11-2012, 09:54 AM   #3371
OppositeLock
Member#: 54060
The ECU part number and ROM code match to a V8. The chassis is a 2004 WRX and the AVCS was wired by a local who has wired hundreds of swaps. I provided him with DS1's writeup in an email before we met and I believe he just added the necessary shielded wires. It would make sense that this is only what was done considering I found the plugs disconnected. I took out the drivers side AVCS solenoid last night and it was covered in clean oil and nothing was blocking the passageways. The spring action on the inside was functional and moved easily with a small screwdriver. However, I read in a thread here that they should spin? I'm not sure if that is the case though, as it did not seem possible for it to spin in any way. I guess I'll take out the passenger side tonight and make sure everything looks okay there as well. Thanks for your help.
Old 05-11-2012, 02:22 PM   #3372
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
avcs is easy to wire, i did the ds1 instructions and it worked fine. got to be something wrong with the sensor or solenoids are malfunctioning. i have read that they can easily get damaged in transit from being on the outside edges of the engine. get bumped by other things in the trailers/cargo containers.
Old 05-11-2012, 04:28 PM   #3373
OppositeLock
Member#: 54060
This is my thought as well after the logs seem to show a stuck left side, which is why I went forward an began to pull the solenoids. Once it was out i realized that I may not know what it should look like or how it should function, which is why I asked if it should spin somehow. Also, does anyone know which side is left?
Old 05-11-2012, 06:49 PM   #3374
azscooby
Member#: 115297
2002 ej207 vf34
Left should be driver side.
As if you were sitting in drivers seat.
azscooby is offline   Reply With Quote
Old 05-11-2012, 07:10 PM   #3375
ssssly
Member#: 268627
05 SpecC/FFR818
Everything labled left or right side in the service manual etc... is as if you are sitting in the drivers seat.
From my experience dealing with AVCS issues it is normally one of two things.
A clogged oil line filter. The fix being to pull the banjo bolts, remove the filter, put it back together and it works like a champ.
Or the ECU freaking out for no reason. The fix being to warm up the car to operating temps, reset the ECU, then turn the car on and immediately floor it in first before the AF learning kicks in. Don't know why but it seems to fix a lot of issues with AVCS codes and such. For whatever reason the V8 and 9 ECUs have a tendency to kick out AVCS and AF codes for no reason if the sit for a lengthly period of time without use.
ssssly is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
