Welcome to the North American Subaru Impreza Owners Club Wednesday August 15, 2018
Old 11-14-2011, 09:19 AM   #2026
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
My recollection was wrong, I was reading 100 lb heavier in older threads.
Was never specified dry or not.
It makes up a part of the weight difference between the WRX and the Sti.
Old 11-14-2011, 09:41 AM   #2027
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
The overall drivetrain makes up the weight difference, R180 and Brembos are significantly heavier.
fastnoypi is offline   Reply With Quote
Old 11-14-2011, 10:45 AM   #2028
slickonice
Member#: 241812
2002 Ej207 Sedan 30r
Anyone know if the v7 Sti radiator is more efficient at cooling than the Wrx radiator? I had a v7 laying in my garage and decided to put it in for the hell of it.
slickonice is offline   Reply With Quote
Old 11-15-2011, 06:03 PM   #2029
lil'redwagon
Member#: 10854
2002 WRX Sedan ej207
2008 Infiniti G37 S/C'd
in my experience, the stock radiators cool well, but they blow out the plastic endtanks. so if the v7 has plastic endtanks, it'll be the same.
lil'redwagon is offline   Reply With Quote
Old 11-15-2011, 06:46 PM   #2030
candamo
Member#: 288732
2003 JDM STi
Just bought a car with an ej207 engine. Its an 03' JDM Ver8 STi converted to LHD, came stock plus cusco 2 way rear diff (clunks like a b*tch).
Already got a perrin turbo inlet hose, whiteline steering rack bushings and a full TBE. By the end of the month I'll install them and take it to the dyno for a reflash.Also the car is electronically limited to 180 km/h, i guess the reflash will take care of that.
candamo is offline   Reply With Quote
Old 11-15-2011, 10:20 PM   #2031
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Is it true ngk one step colder iridium plugs are no good for my v7 motor?
mrxr250rider is offline   Reply With Quote
Old 11-16-2011, 07:53 AM   #2032
slickonice
Member#: 241812
Hope that's not true because that's what I use in mine! I have an atpgt3076 setup.
Old 11-16-2011, 08:43 AM   #2033
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
Unless you know the model number of the plugs you plan to use, you won't know what they're colder than by one step.
Once you know the model number of what you're planning to use, go back in this tread, read and you'll find the answer.
Old 11-16-2011, 02:14 PM   #2034
WOnToNx77
Member#: 86656
05 WRX SQC228
San Remo Red
Hey everyone,
I've been looking to do a v7 swap and found a spec c clip however it has over 85 thousand miles on it (converted from km). Does that seem a little high, would it be worth getting?
WOnToNx77 is offline   Reply With Quote
Old 11-16-2011, 05:38 PM   #2035
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
That's what the previous owner told me he said they burn up within two weeks.but the car seems to be running fine and no different with those plugs and I've had them in for atleast a month
Old 11-17-2011, 05:49 AM   #2036
i2cou4u2
Member#: 246455
2004 WRX Wagon
I am running NGK BKR7EIX plugs in my V8 swap with great success. It is tuned for California 91 octane pump gas and put down 280 horse and 276 ft-lbs of torque at 19lbs of boost. The only things I have done to the engine is a 3" Catless TBE, K&N typhoon intake, and a new MAF sensor.
i2cou4u2 is offline   Reply With Quote
Old 11-17-2011, 10:53 PM   #2037
K.Linchpin
Member#: 97984
2015 2.5i Foz w/6pd
How do you get away with that in CA?
PLus a Tune I would imagine
K.Linchpin is offline   Reply With Quote
Old 11-18-2011, 07:16 AM   #2038
i2cou4u2
Member#: 246455
2004 WRX Wagon
My car is registered in a different state that doesn't require emissions testing. I have not had any problems so far.
Old 11-21-2011, 02:00 AM   #2039
i2cou4u2
Member#: 246455
2004 WRX Wagon
I was wondering if anyone here knows of a good tuner in washington state that has knowledge and experience with JDM EJ207's? I am moving there and I am hoping to get tuned for 92 octane instead of the Cali 91.
Thanks for the help.
Tom
Old 11-24-2011, 05:47 PM   #2040
Rykenma
Member#: 179845
.... Hello?
Yes, this is dog.
I have read quite a bit through this thread, but I didn't find any info on where to get replacement engine internals. I'm buying a V8 EJ207 complete engine soon, but it needs rebuilt. I don't know too much about what's compatible. What's a good site I can get rebuild components for the block? I'm almost 100% sure the heads are fine. So I just wanted to get the block rebuilt and running strong for the long-run. Thanks!
Oh, and would I be able to get an e-tune for it? Say, from Clark Tuner? I don't own an AP. My tune on my car right now is an opensource map from XPT Tuning. Closest tuner to me is P&L Motorsports in the Chicago area and it's still quite a drive.
Rykenma is offline   Reply With Quote
Old 11-24-2011, 08:41 PM   #2041
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
eBay racing edition!
I can't comment on the replacement internals, but STIMikey does etunes and tuned my EJ207 for pump an E85 along with many others.
IMPREZive 02 WRX is offline   Reply With Quote
Old 11-24-2011, 09:08 PM   #2042
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
My friend got his car road tuned By him as well. I was thinking about taking my car for a better dyno tune at efi logics in ct.
Old 11-24-2011, 09:08 PM   #2043
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
My friend got his car road tuned By him as well. I was thinking about taking my car for a dyno tune at efi logics in ct.
Old 11-28-2011, 10:18 PM   #2044
uberspeed
Member#: 87871
I just finished everything on my V7 EJ207 swap in an '02 WRX. I used the IAG AVCS wiring harness and a V7 ECU. I went to fire it up for the first time and it cranks but doesn't start. I don't hear the fuel pump priming in the on position. Did I get a bum ECU?
uberspeed is offline   Reply With Quote
Old 11-28-2011, 10:24 PM   #2045
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
Tom
I just got my Ver. 8 swap completed by MPS in Marysville. Call them up. I'm getting retuned for some additional mods december 19th. Dom put the group N rom on the ecu so I have launch control via the rear defrost button
Dave and Dom are both very familiar with my car and a couple other EJ207 swaps they've done. I'd just give them a call and see what they say.
blakjak00 is offline   Reply With Quote
Old 11-29-2011, 01:10 PM   #2046
uberspeed
Member#: 87871
Ok, I was getting no CEL with the key in the "on" position and the fuel pump wasn't priming. I swapped the US ECU back in and the pump primed, it started, but died without giving it a little gas.
So 2 questions:
1. What's the best source for a V7 ECU? Looks like I got a bad one.
2. Is it normal that the US '02 WRX ECU won't allow the V7 STI motor to even idle?
Old 11-29-2011, 02:49 PM   #2047
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
12.8 @ 112, '09 spec.B
I am not sure if anyone is interested... but I am selling my fully built EJ207 as we speak. PM/email me if interested.
[email protected]
Thanks
Doug
dug-e-fresh is offline   Reply With Quote
Old 11-29-2011, 05:43 PM   #2048
Kris.is.awesome
Member#: 256840
2000 BMW ///Mcoupe
Silverrrrrrr
So 2 questions:
My 207 ran on a us WRX ecu. My 207 also ran with it's ecu.
Kris.is.awesome is offline   Reply With Quote
Old 11-29-2011, 06:58 PM   #2049
uberspeed
Member#: 87871
Cool. So I am guessing I have a vacuum leak. The ECU my V7 shipped with turned out to be a V9.
V7 ECU is on it's way and I need to fix the vacuum leak.
Old 11-29-2011, 09:39 PM   #2050
RexWagonWA
Member#: 221945
Default Ej207
I too would recommend Maxwell Power in Marysville, WA north of Seattle up I-5. They have the experience, plus you can get a Dom tune!
RexWagonWA is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
