#1 |
Vendor Sales Rating: (59)
Member#: 183645
TXIC
Vehicle:2007 STi & 09 SpecB www.awdtuning.com |
![]() For those of you who don't know, in addition to installation, repair, engine building and tuning services we also offer maintenance. We have always provided factory-like service; however we are Amsoil dealers and carry their products in house. This makes taking the best care of your vehicle even more convenient!
Below is a list of typical maintenance schedules along with standard and performance service packages. Note: that every car has various maintenance requirements due to use, mileage, and wear of components from abuse. Oil is typically changed in smaller intervals, but often is needed around the same time other maintenance is performed. If there are some items not needed or additional items needed at the time of service please let us know in advance. Subaru Scheduled Maintenance Packages Every 30,000 miles: Oil Change Service – AMSOIL SAE 10W-40 Synthetic Premium Protection Motor Oil / WIX High Performance Filter Spark Plugs – NGK One-Step Colder plugs Transmission / Differential Fluid Change – Amsoil 75w90 Brake and Clutch Fluid Flush – Amsoil DOT 4 Brake Fluid Coolant flush Detailed Inspection of: – Tires/Rotation – Timing and Drive Belts – Coolant and Hoses – Fuel System – Brake Pads and Rotors – Steering and Suspension Components – CV Joints, Axles, Half Shafts, Bearings Total cost $755* Every 60,000 miles: Oil Change Service – AMSOIL SAE 10W-40 Synthetic Premium Protection Motor Oil / WIX High Performance Filter Spark Plugs – NGK plugs choice Transmission / Differential Fluid Change – Amsoil 75w90 Brake and Clutch Fluid Flush – Amsoil DOT 4 Brake Fluid Coolant flush Replace accessory belts – AC, Power steering/Alternator Replace Upper and Lower radiator hoses Detailed Inspection of: – Tires/Rotation – Timing Belt – Fuel System – Brake Pads and Rotors – Steering and Suspension Components – CV Joints, Axles, Half Shafts, Bearings Total cost $955* *Cost may be reduced depending on extent of service desired. Every 90,000 miles: Oil Change Service – AMSOIL SAE 10W-40 Synthetic Premium Protection Motor Oil / WIX High Performance Filter Spark Plugs – NGK plugs choice Transmission / Differential Fluid Change – Amsoil or Redline 75w90 Brake and Clutch Fluid Flush – DOT 4 Brake Fluid Coolant flush Replace accessory belts – AC, Power steering/Alternator Replace Upper and Lower radiator hoses Replace Timing Belt and Tensioner and Water Pump Detailed Inspection of: – Tires/Rotation – Timing Belt related components such as water pump, idler pulleys, cam seals, etc. – Fuel System – Brake Pads and Rotors – Steering and Suspension Components – CV Joints, Axles, Half Shafts, Bearings Total cost $1675* *Cost may be reduced depending on extent of service desired. Give us a call at 469-277-3001 to schedule an appt! |
#2 |
Member#: 42362
TXIC
Vehicle:2016 WRX Premium Crystal Black Silica |
![]() AWD Tuning has been my go-to for "boring" normal service and repairs on my son's Legacy GT and later Mazdaspeed 3 and my wife's "also boring" '06 Legacy.
Now that I have re-entered the Subaru World with the purchase of my '16 WRX, I'll be counting on them to look after it, also. I think enough of the folks and their work to make the trek from Forney to Flower Mound when I need service. Highly recommended! |
#4 |
Member Sales Rating: (1)
Member#: 293006
SCIC
Vehicle:2015 Subaru WRX WR Blue |
![]() I usually perform all maintenance myself but since moving to Texas, I have no place to work on my car. Been going to AWD Tuning for a year now and wouldn't go anywhere else. Folks at awd tuning are always nice and provide top notch service with competitive pricing. Can't wait to have them tune my 2015 Wrx. Highly recommended
