Welcome to the North American Subaru Impreza Owners Club Monday February 10, 2025
Old 12-09-2024, 05:32 PM   #26
JCG66
Member#: 537594
2014 WRX hatch
No compressor required, no need to clock the motor for each cylinder, just a key and a spark plug hole...
Sometimes I have to remind myself that most people don't have a full shop with a compressor, specialty tools and a 5000lb lift in their backyard. Most just have a garage they park their car in and many not even that. Also, for many, if you tell somebody to find top dead center on each cylinder it rapidly exceeds their abilities.
JCG66 is online now   Reply With Quote
Old 12-10-2024, 08:21 AM   #27
rtv900
Member#: 428511
2016 STI
I can't imagine a person who would be considering doing a leakdown test that doesn't understand what TDC is.
Old 12-10-2024, 10:52 PM   #28
JCG66
Member#: 537594
2014 WRX hatch
Precisely stated! If you don't know what TDC is then a leak down test is out of your wheelhouse, therefore, making a compression test the easier test for leaks. ...all of which require a teardown.
Old 12-11-2024, 09:50 AM   #29
rtv900
Member#: 428511
2016 STI
I can't imagine a person who doesn't know what TDC is even considering doing a compression test regardless of needing to have the piston at TDC to do it.
Old 12-11-2024, 07:12 PM   #30
JCG66
Member#: 537594
2014 WRX hatch
I can. Way back when, I knew how to do a compression test but lacked the tools and knowhow to do a leak down. There you go, real life proof! You don't have to imagine anymore.
Old 12-11-2024, 07:17 PM   #31
rtv900
Member#: 428511
2016 STI
I can. Way back when, I knew how to do a compression test, but lacked the tools and knowhow to do a leak down. There you go, real life proof! You don't have to imagine anymore.
well case closed
Old Yesterday, 12:35 AM   #32
gus_274
Member#: 484892
The issue has been resolved! I edited my first post with the finding and resolution to hopefully help others who have a similar issue.
gus_274 is offline   Reply With Quote
