Welcome to the North American Subaru Impreza Owners Club Friday February 14, 2025
Old 01-24-2001, 01:40 AM   #1
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post Stock oil pressure enough?
For those of you people with turbos, is the stock oil pressure enought to circulate to the turbo and back to the engine?
WRXwannbe is offline   Reply With Quote
Old 01-24-2001, 01:53 AM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Post
yes... If not, I don't think they make a High pressure Oil pump for our cars!
Eric
Eric SS is offline   Reply With Quote
Old 01-24-2001, 02:00 AM   #3
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
hehe thats what I was afraid of. OK, that makes me happy.
Old 01-24-2001, 02:06 AM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Post
That would be a nice mod though!
Eric
Old 01-24-2001, 02:19 AM   #5
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
as long as the pump doesn't exceed 25 psi the turbo would love the added pressure. I just wasn't sure our US-spec imprezas had the uhmph in their oil lines.
Old 01-24-2001, 02:24 AM   #6
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Post
I think I would rather have a high Volume pump than high pressure pump but either would be nice... I don't think it is needed though.
Eric
Old 01-24-2001, 02:28 AM   #7
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Post
You can increase the oil pressure by installing a restrictor in one of the oil passages. IIRC, thats what Group N cars' drivers do, since you are not allowed to change the oilpump. It works, hehe. If I would do it, I would also try to get/make a larger capacity oil pan to increase the amount of oil in the system.
Imprezer is offline   Reply With Quote
Old 01-24-2001, 07:12 AM   #8
SteveS
Member#: 6
2013 BMW M3 Coupe
Interlagos Blue
Post
Yes, the stock oil pressure is enough. According to Turbonetics, the Garrett T03/T4 was originally designed for low oil pressure deisel applications. As a matter of fact, I just changed the oil feed line from AN -4 to AN -3 to help cut down on the oil supply to the turbo so as not to cause blow-by. It seemed to be OK with the -4, but RalliSpec suggested -3 after speaking with Turbonetics.
Steve
http://www.lagging.com/
SteveS is offline   Reply With Quote
Old 01-24-2001, 08:36 AM   #9
25psi
Member#: 3086
2001 2.5 RS
Post
According to my Oil Pressure gauge you will have just under 25PSI at idle. And just over 75PSi under load.
That is very enough unless u run some kind of very tricky setup.
Eugene
25psi is offline   Reply With Quote
Old 01-24-2001, 09:16 AM   #10
Jay_UK
Member#: 296
Post
Howdy..
That sounds about the same as the WRX/STI Turbo cars.. I think they all use the same pump.
When I rebuild engines I tend to increase the pressure by an extra bar.. to take them upto 7bar... this is used by the GrpN rally teams.. (as Alex mentioned)
You shim the pressure relief valve piston..or fit a stronger spring.. simple
J.
Jay_UK is offline   Reply With Quote
Old 01-24-2001, 06:20 PM   #11
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
thank you for all the answers. Thats one less thing to worry about
Couple of questions about the stock oil pressure sender... Impreza Rider Normally Aspirated with bolt-on Forced Induction Powertrain 6 06-26-2003 08:43 PM
Stock Oil Pressures for 02 WRX Malico Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-04-2003 03:33 PM
What's the Stock Oil Pressure on a 02 WRX? blindclown New England Impreza Club Forum -- NESIC 7 12-23-2002 09:47 PM
Stock Oil Pressure Sender: BSPT or NPT? Austin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-05-2001 02:55 AM
Stock oil pressure for 00 RS? IMPBOY Technical Forum Archive 2 10-19-2000 06:24 AM
