Welcome to the North American Subaru Impreza Owners Club Sunday September 22, 2019
Old 05-23-2013, 09:06 AM   #26
wrxadam05
Member#: 84070
2015 Fiesta ST - E30
500whp GRB STI
Updated - Before installing make sure that everything is tightened down PRETTY tight and use sealant on the hex nut on the center of the pump and torque down TIGHT!.
Also, I would recommend throwing in an OEM crank seal. I always feel comfortable with OEM seals over aftermarket.
(Thanks to [email protected] for the heads up on this)
wrxadam05 is offline   Reply With Quote
Old 06-03-2013, 04:29 PM   #27
weps
Member#: 183495
I'm guessing this would be overkill for us non-avcs folks?
weps is offline   Reply With Quote
Old 06-07-2013, 11:07 PM   #28
sidewayz
Member#: 5810
2001 S366 2.5RS
Since using a few of these, no issues yet. Pretty happy so far
sidewayz is offline   Reply With Quote
Old 06-10-2013, 02:14 PM   #29
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
Yeah I just talked to Larry Berger over there and I'm going to order a couple, one for myself
Flat 4 Motorsport is offline   Reply With Quote
Old 06-11-2013, 05:12 PM   #30
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I posted this in another thread, but since it's relevant here....
Not to pollute your thread too much, but we've been doing some pump comparisons over here. Some things to note...
The ACL pump uses a cast aluminum back plate not steel like OEM. It is thinner by 2mm to accommodate the thicker rotors. It's also a bit thinner around the c'sinks. I have strength and pressure retention concerns with this vs the thicker steel version.
The ACL housing is obviously a knock-off as EVERY casting mark is the same, minus the date, lot and QC codes you'd get on a genuine part. The product reflects it's price.
I hope to have actual flow pressure data vs the OEM 12mm within the next 3-4 months. I won't run one until we test it off the car. I REALLY hope ACL did actual in-house testing as it often doesn't bode well for products that use their markets to test products.
From Left to right: OEM JDM12mm, Cosworth, OEM USDM 10mm, ACL
Here's how ACL fit the 12mm rotors, by using a 10mm housing. The JDM OEM 12mm pump actually uses a thicker housing to match the thicker rotors. The ACL pump does have better milling going into the outlet port.
And here's how they make it fit, bore 2mm out of the back plate. Not the OEM 10mm steel back plate in the background. ACL version is cast aluminum and thinner at the rotors.
Here's a shot showing how the ACL c'sinks are deeper, thinning the material around it.
For those who have not seen a Cosworth (sorry for the crappy pics), this is what you're paying for with 'porting'. The areas of the casting I like to 'clean up' aren't touched and very little material is removed. It looks more like a 3 minute job with a small wire wheel. I was disappointed the first time I opened one up and there were definitely no ooohhh ahhhh moments.
More to come at a later date.
KillerBMotorsport is offline   Reply With Quote
Old 06-18-2013, 03:27 PM   #31
wrxadam05
Member#: 84070
500whp GRB STI
Thanks for the contribution. I'm going to be doing a volume measurement on the ACL versus 11mm, just to have the data.
Old 06-18-2013, 07:07 PM   #32
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
No problem. The ACL rotors are the same as the JDM 12mm. Since the rotors determine flow capacity, see JDM pump specs for flow/pressure data. Going off ACLs 'fluffy marketing specs' and lack of having actual flow data, I expect a pseudo copy/paste from JDM specs is where their info comes from
Old 06-19-2013, 06:44 PM   #33
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Yea, only difference is it appears they applied some DFL coating to the inside of the gears. Doubt that makes any difference.
Crystal_Imprezav is offline   Reply With Quote
Old 07-03-2013, 12:22 AM   #34
flath4
Member#: 331643
so anyone have any issues with the ACL pump at all? from the looks of it, seems to be a knock off of the JDM 12mm oil pump.
flath4 is offline   Reply With Quote
Old 07-03-2013, 11:03 AM   #35
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
So far so good. It is not a knock off of the JDM pump, it is a knockoff of the Cosworth High Volume pump. 10mm pump with a 12mm gear.
Old 07-03-2013, 11:41 AM   #36
flath4
Member#: 331643
so in your honest opinion would you recommend it to anyone?
Old 07-04-2013, 09:03 AM   #37
VTsuby
Member#: 81369
2007 STI
I'm surprised moroso or mellings hasn't jumped into this market before acl. I was just thinking about the recirculation with the larger pumps. Would it be possible to build a valve to remotely bypass the excess volume/pressure way downstream in the oil system and simply block of the bypass in the pump?
VTsuby is offline   Reply With Quote
Old 07-04-2013, 09:06 AM   #38
mboulton
Member#: 174433
Bingo. I was wondering the same.
mboulton is offline   Reply With Quote
Old 07-04-2013, 12:59 PM   #39
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
Already have it
Old 07-04-2013, 01:30 PM   #40
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
So which one is the best to run with then?
Tyrial is offline   Reply With Quote
Old 07-04-2013, 01:57 PM   #41
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
There is no real answer for that question without knowing build tolerances and specs and target rpm.
Bearing clearances?
AVCS? Dual AVCS? No AVCS?
Piston oil squirters?
Target rpm?
Custom or modified crank?
Old 07-04-2013, 03:42 PM   #42
VTsuby
Member#: 81369
2007 STI
something like this?
Old 07-04-2013, 03:45 PM   #43
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Yes. Plug the OEM bypass because it sucks. Adjustable pressure bypass routed back into the sump. I don't know who would be doing it this way
Old 07-04-2013, 03:48 PM   #44
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Almost. Design and build it into the unused pumps output port so you're only adding one line, not 3.
Old 07-04-2013, 03:56 PM   #45
VTsuby
Member#: 81369
2007 STI
I smell what your stepping in, your pan has a nice extra bung on it that would be good for this
Old 07-08-2013, 09:25 PM   #46
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Going to make something for us KB?
Old 07-08-2013, 09:33 PM   #47
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I know he is because he's been hinting at this for quite some time. Knowing him it's gonna be pretty trick too. The question is WHEN?
Old 07-09-2013, 12:42 AM   #48
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
/waiting
Old 09-23-2013, 10:24 AM   #49
brianglawson
Member#: 229468
2004 Impreza WRX STI
waiting for some more review results
brianglawson is offline   Reply With Quote
Old 09-23-2013, 10:34 AM   #50
wrxadam05
Member#: 84070
500whp GRB STI
I ended up getting into a rush to get my car together so I could sell it. Everything is together and working well. Great pressure and so far no issues.
