Welcome to the North American Subaru Impreza Owners Club Wednesday September 23, 2020
Old 08-05-2013, 09:37 AM   #176
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Either way it's a lot of fun! I think it's probably down 300lbs from a GR STI so 300WHP feels more like 340WHP in the STI.
xluben is offline   Reply With Quote
Old 08-05-2013, 10:15 AM   #177
1wrxtra
Member#: 316364
2012 WRX
I'll bet it is! Can't wait to see how your build progresses
1wrxtra is offline   Reply With Quote
Old 08-05-2013, 11:22 AM   #178
dodis
Member#: 223729
2003 WRX LO-N-SLO
Great thread so far! Definitely helping me with inspiration for a vf39...
What did you use to plug up the holes in your trunk when you took the wing off? Did you find color matched vinyl?
dodis is offline   Reply With Quote
Old 08-05-2013, 12:16 PM   #179
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Right now I have pieces of bright green masking tape. Haha. I still need to find a better solution.
Old 08-05-2013, 01:13 PM   #180
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
For a quick fix I would see if you can find some 3M Scotch-35 electrical tape, they make it in a grey color so it would be closer color wise. Put it both inside and out I did this on my forester hatch (but black) when I pulled off the spoiler for rack clearance one summer.
I also did badge deletes on my Forester a couple years ago and the 2.5xt badge left 2 holes. I know they are small holes but what I did for those was, I used black 3M silicone and applied a small dab to both sides of the holes. Then I wet my finger with mineral spirits and carefully removed as much excess of the silicone as I could from the outside and left a little button of it on the outside. I let it harden an hour or so then smoothed it a bit more same technique with the mineral spirits. It's held for 2+ years now. It might work if you can find a closer color match in silicone caulk. Or custom paint some smooth buttons.
Old 08-05-2013, 01:42 PM   #181
georgia-wrx
Member#: 353039
2013 WRX
Very nice!!!!
georgia-wrx is offline   Reply With Quote
Old 08-05-2013, 01:59 PM   #182
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks! I think I might have to try some grey electrical tape. There is some rust around the holes so they are going to take some additional work long-term, but I think tape will be fine for now.
Originally Posted by georgia-wrx View Post
Very nice!!!!
Thanks!
Old 08-05-2013, 02:35 PM   #183
funnky
Member#: 330236
2002 wrx
blue and black
awesome to see a bugeye with those miles still tearing it up.
funnky is offline   Reply With Quote
Old 08-06-2013, 02:21 PM   #184
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP 2016 Sienna
this should be good
Celery GT-5 is offline   Reply With Quote
Old 08-06-2013, 02:50 PM   #185
dIrTy-StI
Member#: 322280
2002 Subaru WRX
What are you using to tune your car? I have a 2002 bugeye and have a vf23 i plan on putting in, i just ran into some issues with cash and dont have enough for a pro-tune. Do you happen to have any suggestions?
dIrTy-StI is offline   Reply With Quote
Old 08-06-2013, 10:22 PM   #186
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Nuke at NF Performance is doing custom open source tunes (pro tunes) on it.
Old 08-08-2013, 01:31 PM   #187
sexyyrex
Member#: 128022
2015 Mustang GT
Followed your GR WRX real close. Love what you're doing with this. Seeing your previous build, i'm sure you have big plans, however, that E85 early torque is going to murder that clutch, and transmission if its stock. Some VF cars can do close to 400wtq with the 2.5 on that VF series turbo on E85, i'm sure the 2 liter is less, but probably not too far off.
The only thing in that clutch and tran's favor is that the VF series turbo does in fact spool later in the RPM band on the 2.0L. Just a little heads up if you were hoping to save that trans.
sexyyrex is offline   Reply With Quote
Old 08-08-2013, 02:19 PM   #188
subezero
Member#: 207614
2008 WRX Hatch VF52d
SSM
^If I had to guess, he has zero ****s for the transmission.
subezero is offline   Reply With Quote
Old 08-08-2013, 04:01 PM   #189
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
The VF on the 2.0L spools much later than the 2.5L and should be easier on things to some extent because of that. It's likely not doing anywhere near 400WTQ either. The shortblock and tranny are both stock with 185k miles. The clutch was supposedly replaced this spring with an OEM (or OEM style) clutch.
I took it out for a couple sessions on the road course last night at NF Performance's track event. It was a lot of fun and the car is still in one piece. The 5 speed + 2.0L + VF powerband wasn't the best for some of the tight sections, but it was still a good time. And the motor/tranny/clutch did make it back home without blowing up!
Old 08-08-2013, 06:03 PM   #190
czum09
Member#: 336078
The 5 spd won't just blow up at a 350wtq power level. It all comes down to the driver. A guy locally ran ~500whp/tq, daily driver, without an issue for years. He made over 100 passes on that trans at the track and it held till 600hp lol. Point is, shock load and the driver can prolong the life of the 5spd.
But, I'm sure a 6 spd is in the near future for Ben.
czum09 is offline   Reply With Quote
Old 08-09-2013, 01:02 AM   #191
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Haha. I bought this car to drive it, not to baby it.
Old 08-09-2013, 01:35 AM   #192
brett192
Member#: 274252
2002 WRX Sedan PSM
EJ207 & 6 speed
No kidding! Kill the 5 speed, then swap and be done! I'm glad I did..
Does your stock transmission have the narrow or wide gearset?
brett192 is offline   Reply With Quote
Old 08-09-2013, 08:39 AM   #193
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Since it is an 02 I would assume it's the narrow gears.
Old 08-09-2013, 09:11 AM   #194
sexyyrex
Member#: 128022
2015 Mustang GT
Narrow and wide should be relative when discussing bug-eye transmissions.
Old 08-09-2013, 10:02 AM   #195
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
True. I'm sure I could break it very quickly with a few FFS's. I thought all the 02's had the narrower gears anyways.
Old 08-14-2013, 08:52 AM   #196
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Helped a friend work on this one last weekend:
Old 08-15-2013, 12:51 AM   #197
CarverSnell
Member#: 256218
'08 WRB Forester
'04 PSM WRX built 380 whp
Paint those side skirts! Easy 30 dollar afternoon project.
And damnnnnnn that was quick 40-60.
CarverSnell is offline   Reply With Quote
Old 08-15-2013, 07:54 AM   #198
96accord
Member#: 145105
2015 Honda Accord
What was wrong with it?
96accord is offline   Reply With Quote
Old 08-15-2013, 11:50 AM   #199
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Maybe. Someday I wouldn't mind getting the whole car sprayed, so I might just wait for that.
Hopefully it will be quick from more than 40-60 one of these days...
Nothing. Just decided the rotated GTX30R on E98 wasn't fast enough
Old 08-15-2013, 01:43 PM   #200
enjoilife1991
Member#: 322400
03 WRX 360whp
yea... that whole "not fast enough" thing seems to be a common problem...
enjoilife1991 is offline   Reply With Quote
