Welcome to the North American Subaru Impreza Owners Club Sunday September 22, 2019
Old 08-07-2016, 02:32 PM   #1
Chewybuilt
Member#: 444084
Default Cp Pistons oil ring
Should I be following the fsm for the ring placement? I see numerous threads that the ring with the tab goes on top of the expander ring with the tab on that one slot.
If I follow the fsm, it says that the tabbed ring goes on the bottom of the expander with the tab pointing down on one of the tabs.
Need help. Which is it 😔? Thanks
This is an ej247 with 99.75 mm cp Pistons. I've emailed cp, but it's the weekend.
Chewybuilt is offline   Reply With Quote
Old 08-11-2019, 06:58 PM   #2
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Dusty
Graveyard bump. Did you get an answer or can anyone else chime in? It seems that cp doesn’t tell you anywhere I can find online.
subydude is offline   Reply With Quote
