Welcome to the North American Subaru Impreza Owners Club Sunday June 26, 2022
Old 08-16-2017, 10:27 AM   #1251
Web Foot STi
Member#: 39086
2004 STi
Originally Posted by Notbrick View Post
Thanks Web. Did you completely disassemble the assembly or just lift the boot and apply?
I didn't even jack up the car. Remember the struts are inverted and it's easy slide up the boot and slather the shaft with ~1/2 golf ball sized blob.
If I ever get my struts rebuilt/re-valved I will definitely spring for the few extra dollars to have the Zerk fittings installed, but at this point I just don't see it worth the work to disassemble the struts just to grease the shafts.
Web Foot STi is offline   Reply With Quote
Old 01-06-2022, 04:29 PM   #1252
S2000_Europe
Member#: 297373
2018 STI Type RA
Sorry to revive this, I have a Type RA and every time I pass over a speed bump I can hear a "Clung". The struts are different from my previous MY17, but is the same problem?
S2000_Europe is offline   Reply With Quote
Old 01-07-2022, 09:07 AM   #1253
Randog77
Member#: 37272
2004 WRX STi
WR Blue
Default Try itÖ
I would say you should just try putting some grease on the strut and see if it helps? If it goes away ( for a while ) itís the same problem.
Randog77 is offline   Reply With Quote
Old 01-07-2022, 09:53 AM   #1254
S2000_Europe
Member#: 297373
2018 STI Type RA
Is weird, different shock manufacter and same problem?
I will check again the grease
Old 01-07-2022, 03:32 PM   #1255
Web Foot STi
Member#: 39086
2004 STi
It's a little messy, but as I said it is easy and I have only had to do it once in ~90,000 miles now and owned the car since the end of May 2003.
Old 01-19-2022, 08:48 PM   #1256
S2000_Europe
Member#: 297373
2018 STI Type RA
The problem was the rear sway bar and the bushings. The dealer is going to replace the rear sway bar, bushings and bushings "retainers" (forgot the name in English)
Only one rear suspension clunks ST3 Brakes, Steering & Suspension 1 05-16-2006 01:31 AM
05 Sti rear suspension clunking? jmanSTI Brakes, Steering & Suspension 7 03-09-2006 11:11 AM
STI rear suspension clunking scubi Brakes, Steering & Suspension 0 11-11-2005 01:58 AM
MI: STi rear suspension clunk fixes Smittys_STi Mid West Subaru Owners Club Forum -- MWSOC 24 06-29-2005 08:38 AM
Rear suspension clunk when left/right load is not balanced?? wayoutwest Brakes, Steering & Suspension 10 07-30-2004 12:35 PM
