Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2022
Old 11-24-2007, 08:15 PM   #1
IAMREX
Member#: 137568
2007 WReX
Default decent speakers for stock head unit?
Hi,
As many of you have no doubt realized, the stock WRX speakers are basically trash, and I'm looking to get something that sounds better.
What I'm hoping to find is a set of decent 2 or 3 way 6.5's for the front that will sound good when driven off the factory head unit, but that if I decide to add a mild system, will be ok up to at least 60-75 watts RMS, and have good sound quality.
I had been looking at the Polk db series 6.5" shallow mounts. Has anyone tried these, and/or are there some others that I should be considering? Also, with an 07 WRX, do you still need an adapeter to mount 6.5's?
Thanks!
IAMREX is offline   Reply With Quote
Old 11-24-2007, 08:51 PM   #2
Daishi00
Member#: 78952
2005 WRX
CGM
The best speakers for the stock HU are the stock speakers. The sensitivity is quite high and can play ok with the extremely low power output from the HU.
Changing out to aftermarket ones won't get you a huge increase in performance, and depending on what ones you get might sound worse.
Daishi00 is offline   Reply With Quote
Old 11-24-2007, 10:27 PM   #3
Warguy
Member#: 149110
2006 WRX TR
+1 plus the stock HU is garbage anyway, i installed a pioneer the day i bought the car, im a car audio installer, get a new deck first. Pioneer or alpine in my opinion, if you talk on the phone alot get the pioneer 7900 its awsome and it has bluetooth built in, there really popular right now and there great for the new law thats going in to effect
Warguy is offline   Reply With Quote
Old 11-25-2007, 02:55 PM   #4
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Senor Daishi is right. A new head unit on stock speakers would make more of a difference than stock head unit to aftermarket speakers. If you do change them, I recommend ones like the Kicker KS, they are very efficient and louder for the power than any speakers in my experience. Expect to give up a little bit of bass, but gain a decent amount of midrange and highs.
-Brandon
Audiosavvy is offline   Reply With Quote
Old 11-25-2007, 02:57 PM   #5
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I'd say infinity front speaker would be a fair speaker. As higher end speakers you start to loose bass in a big way. Forget the rear as I found it's not exactly needed as that's just fill sound. If you upgrade to new rears you might run into volume issues.
Old 11-25-2007, 08:25 PM   #6
IAMREX
Member#: 137568
2007 WReX
Right on... sounds like everyone is pretty much in agreement here... I guess maybe I'll just suck it up and deal with the stockers until they blow, or I decide to kick down some cash for a decent system. Thanks for the tips guys.
Old 11-25-2007, 09:02 PM   #7
jakeachy
Member#: 162893
00 STM GC8
you have more of a chance burning stuff out with a stock unit compared to a larger amp/unit.
jakeachy is offline   Reply With Quote
Old 11-25-2007, 09:08 PM   #8
Daishi00
Member#: 78952
2005 WRX
CGM
Even if the stock HU was put into a clipping state the total output (as what CAN damage a speaker when clipped...not the actual signal) would most likely not exceed the max handling capabilities of the stock drivers.
Old 11-25-2007, 10:54 PM   #9
zsimpreza
Member#: 157079
2007 Impreza 2.5i
Obsidian Black Pearl
Thumbs up
I just put in some Infinity Reference 5.25 component speakers up front. I'm actually impressed how they sound with the factory HU.
zsimpreza is offline   Reply With Quote
Old 11-26-2007, 05:02 PM   #10
Uncanny
Member#: 133012
2015 STi
Lightning Red
why would you put a 5.25 up front?
Uncanny is offline   Reply With Quote
Old 11-26-2007, 05:35 PM   #11
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
6.5 in speakers can be installed with adaptors. Yet some speakers rub causing damage to the speaker. Unless 06+ door cards are used. With newer door cards it's big enough to hold the bigger speaker with no problems. So 5.25 are safe in pre 06 cars.
Old 11-26-2007, 06:23 PM   #12
Daishi00
Member#: 78952
2005 WRX
CGM
Small clarification... 05+ door cards, not 06+ and ljb2105 was asking why someone would want to run a smaller driver up front when it's easy to fit 6.5" even in pre 05 cars
Old 11-26-2007, 06:33 PM   #13
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
yes but some 6.5 speakers can be damaged using pre 05 door cards. I had it happen twice.
Old 11-26-2007, 07:07 PM   #14
Daishi00
Member#: 78952
2005 WRX
CGM
Which is why you run extension pins and your problems are solved . It also has nothing to do with the width of the driver, just the depth. You can find 6.5" drivers that are more shallow than many 5.25" drivers.
I do know where you're coming from don't get me wrong, it just takes a bit more work to get them to function just as well in 04- doors.
Old 11-26-2007, 10:47 PM   #15
zsimpreza
Member#: 157079
2007 Impreza 2.5i
Because they were on sale for $89 (reg. $189) and I knew they'd sound better than factory.
Old 11-27-2007, 11:01 AM   #16
Uncanny
Member#: 133012
2015 STi
Lightning Red
its pretty simple to get a 6.5 to work on a pre-05 door card. simply space it out properly, use an extended door pin, and trim the ring on the inner door card that most usually causes that "buzzing" sound. simple as that. no damage to the speaker, no buzzing sound, no magnet hitting the window.
Replacement speakers for STOCK head-unit Obsessive Car Audio, Video & Security 35 02-20-2008 08:54 AM
looking for stock head unit... skakid619 Car Audio, Video & Security 4 06-08-2006 08:24 AM
Aux input for stock head unit? irmiger Car Audio, Video & Security 2 02-03-2004 10:39 PM
Speakers and Stock Head Unit AdmireWantWillLove Car Audio, Video & Security 6 03-10-2003 11:52 AM
XM radio upgrade for stock head unit nicktckhoo Car Audio, Video & Security 4 03-29-2002 01:39 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
