#1 |
Member#: 503560
![]() A while ago I started hearing very loud snapping noises when turning coming from the mid/front of the car. It is worst when tight turning under power. I hoped it might be my CV axles but I replaced them with no change. I suspect my front differential or transmission has failed. My transmission also doesn't like going to first unless I am going dead slow, and pops out and grinds in reverse. Am I correct in thinking it might be differential? And is it possible to fix or replace the differential without dropping out or swapping the whole transmission?
07 turbo 2.5L wrx. Thanks!
#2 |
👏 Big Ron 👏
Moderator Member#: 18062
![]() Step zero should be a fluid swap. Drain. Fill with 100% Redline Lightweight Shockproof. If you want to save some pennies, do 2 qts then fill with cheap non-synthetic fluid. You should then be able to downshift into first at 100 MPH. If the other noise does not magically get fixed, the cheap fix is likely a new center differential. They are cheap used and can be swapped out without dropping the trans. Front diff issues are a drama festival and you are better off swapping out the whole trans as the front requires a rebuild.
#3 |
Member#: 503560
![]() thanks for the advice. I never did a fluid swap because the fluid looked brand new, turns out it was awful and all the junk goop had settled to the bottom, but unfortunately the problem is still there. I actually noticed that on sharp turns the car feels like its braking and the wheels are skidding a little bit.
#4 |
👏 Big Ron 👏
![]() Read my post again. It is not a fluid swap. It is a SPECIFIC fluid swap. Use that fluid.
#5 |
Member#: 530241
![]() I've recently gotten ahold of a 09' Impreza 2.5i. I am new to Subaru so this may be an over thought concern/question. Is steady 3500 RPM in 4th gear at 60 MPH normal? and if so, should I go into 5th to cruise at that speed? the car seems to want to cruise at or around that rpm. something in me just feels that is too high.
#6 |
👏 Big Ron 👏
![]() 5th is ALWAYS your cruising gear at highways speeds.
