#1 |
Member#: 528561
W. Canada
Vehicle:2011 STi Hatch |
![]() I'm putting my car back together and I came to the point where I realized that the OEM bypass valve on the TMIC has a nipple for a vacuum line that goes off to the passenger side. The problem is I have no idea where the other end of that hose is supposed to connect to.
Everything I've seen online just has that hose already connected on the engine side. I couldn't find a routing diagram for this in the FSM either. Really at a loss here. It's the small hose on the BPV that points to the right then curves back towards the left: ![]() In the parts diagram, it is the hose with part number 1AB14: ![]() The problem is that on my car there is no nipple on the manifold like that diagram has for the vacuum hose to connect to. Any help would be appreciated ![]() EDIT: This is for a GR STI. I've found a bunch of resources for WRXs and other STIs that involve a tee of some sort, but mine didn't have such a thing when I removed it.
#2 |
Member#: 491095
SWIC
Vehicle:2009 STi Blue Blue |
![]() iirc its below the throttle body...
#3 |
Member#: 528561
W. Canada
#4 |
Member#: 528561
W. Canada
![]() Found it - it was indeed underneath the throttle body. Fairly easy access with the TMIC off.
