#1 |
Member#: 485402
![]() Part 1 of 3, you can find the other 2 videos in my content!
Part 3 of 3
#2 |
Member#: 515308
![]() I have a jdm 2.0 I’m my 2011wrx. Even ran on the stock rom, tho I did write a rom for it. Use the wrx intake, inj and such.
#3 |
Member#: 485402
![]() I was able to use the tunes from the accessport and it runs great. Fueling is on point and no knock
#4 |
Member#: 485402
![]() Did have a weird issue with the avcs. LH was stuck at 5 degrees and RH was stuck at 12 degrees. I ended up replacing the LH OVC solenoid and that cured the problem. I though it was pretty strange that one solenoid would render the whole operation useless, but the avcs system is pretty complex so i suppose i shouldnt be that surprised.
Other than that the whole setup is running great! I ended getting a pro tune even though the stock tune was pretty good because my friend bought the car from me and i wanted to make sure it was 100% before it left my hands. Any questions feel free to ask! |
#5 |
Member#: 485402
#6 |
Member#: 515308
![]() Have a copy of the tune? Where are the ex cams set? Stock?
#7 |
Member#: 485402
![]() I do, however its never a good idea to run someone elses tune. Given the variety of changes that occur with different cars-different atmosphere ect. You could run it as a base map and tune from there, but i wouldnt advise sending it wot on someone elses tune.
#8 |
Member#: 515308
![]() I have already written a tune for the 2.0, was just to compare. It ran surprisingly well on the ej255 tune, -25 trims and all
