Welcome to the North American Subaru Impreza Owners Club Saturday July 20, 2019
Old 11-01-2016, 05:51 PM   #26
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
I have no opinion as I have never used it; I would run a Google search first, then ask in the transmission forum.
mrsaturn7085 is offline   Reply With Quote
Old 11-01-2016, 05:58 PM   #27
Motown65
Member#: 313291
Default Rebuilding the R180
Sorry posted in the wrong thread..
Motown65 is offline   Reply With Quote
Old 11-05-2016, 08:18 PM   #28
Motown65
Member#: 313291
Any tips on removing the outer bearing area on the side plate?
Old 11-06-2016, 01:35 PM   #29
mrsaturn7085
Member#: 375462
WR Blue
You mean removing the bearing itself? You either need a press or you need to cut it off (carefully). It's not an easy task.
Old 11-08-2016, 11:31 PM   #30
Motown65
Member#: 313291
I meant the outer race in the side plates. Here's a trick some guys my buddy knows did to get them out.
Also before you do the figure 8s is initial torque stupid high?
Old 11-09-2016, 12:47 AM   #31
mrsaturn7085
Member#: 375462
WR Blue
Buy a Harbor Freight bearing pulling/pushing kit - $60-100 and it'll be the only one you need that isn't a press.
What do you mean "is initial torque stupid high"?
Old 11-09-2016, 10:53 AM   #32
Motown65
Member#: 313291
So I get the rear diff in the car last night and go to do the lift right rear test and it's not breaking loose.
When I screwed the lsd back down the top spring plate just caught the case. It didn't seem like it was too tight or anything.
Also this is with no oil besides what I rubbed on the plates during assembly.
Old 11-09-2016, 12:39 PM   #33
mrsaturn7085
Member#: 375462
WR Blue
Did you measure the entire plate stack-up as described in the instructions? The stack-up will protrude above the case lip - screwing the end plate down will compress the stack.
How high does your torque wrench go? The break-free torque should be 80+ ft-lbs.
Old 11-09-2016, 12:43 PM   #34
Motown65
Member#: 313291
It wasn't breaking at 150 and I didn't technically measure the thickness of the stack just everything separately
I didn't know if it was going to be crazy high until you drove and broke it in.
Edit 1
-according to my measurements I had the very minimal amount of clearance (.06mm). I could not get it to break until after the 30min break in and then I could only barely move it with all my weight on it (130 lbs lol). I'm guessing it's around 200ft lbs Break away. This is with all 1.7 plates. Since the clearance is .06 to .24 mm I'm thinking I just filled the clearance and the case is holding it down as well as the spring plates. I'm going to rip the rear end back out and swap two 1.7 plates for two 1.6 plates hopefully making it identical to Mrsaturns.
Edit 2
-I believe I made the assumption that the plates were dead on there numbers when all 6 could be as much as .3mm over or under. This makes measuring the assembled stack without spring plates necessary.
Old 03-14-2017, 12:41 AM   #35
penderperson
Member#: 172370
2006 STI
Pm'd you.
penderperson is offline   Reply With Quote
Old 03-14-2017, 01:07 PM   #36
mrsaturn7085
Member#: 375462
WR Blue
Did you lubricate all plates/discs during assembly? You NEED to completely cover them in 90PA (or your desired rear diff. oil).
Also, from your PM:
Here are my numbers: A=88.37 B=2.5 C=.5 D=65.7 E=1.5 F=86.37
E = 1.85 mm (always); this is the thickness of the bellevelle washers included in the kit (part no. 5). Because you used a value of 1.5, you over-compensated on the stack height causing extremely high break-away torque.
You didn't reuse the old 1.5 mm bellevelle spring did you?
If you have your ramp assembly height (mine was 65.99 mm), I can give you the proper thicknesses to use. Assuming the same ramp assembly height as me, you should have used 2x 1.6 mm discs and 1x 1.7 mm discs per side.
Old 03-15-2017, 05:51 PM   #37
mrsaturn7085
Member#: 375462
WR Blue
Based on your ramp assembly thickness (via PM) of 65.70 mm, the correct thickness selection is:
4 x 1.6 mm and 2 x 1.8 mm
-or-
2 x 1.6 mm and 4 x 1.7 mm (my preference)
You should definitely be using the new 1.85 mm bellevelle washers. The original discs/plates *might* be worn-out, but the original 1.5 mm bellevelle washer will DEFINITELY be worn-out.
Old 11-09-2017, 10:47 PM   #38
Auval
Member#: 350880
2000 FORESTER S
Silver on black
Given that the 60 degree ramps are discontinued and impossible to find, has anyone considered having a machine shop machine down the 45 degree ramps to make them out to 60 degrees?
Auval is offline   Reply With Quote
Old 03-05-2019, 06:21 AM   #39
Alburg
Member#: 469860
sry posted in wrong thread
Alburg is offline   Reply With Quote
Old 03-27-2019, 02:01 PM   #40
mrsaturn7085
Member#: 375462
WR Blue
You would want to make sure the shop was familiar with the heat treatment needed after the machine work; otherwise the ramps will not live very long.
Old 05-31-2019, 04:20 PM   #41
JarHarms
Member#: 138994
06 WRX Ltd
Originally Posted by mrsaturn7085 View Post
...One thing that the 60 deg diff ramp kit modifies in the instructions (not shown) is the order of plates and disks. The OEM and rebuilt kit order places a friction disk directly against a ramp and has two friction plates against each other. This causes the diff ramp to wear, and you likely achieve a marginally lower initial torque as you are basically getting 3.5 points of frictional contact rather than the full 4 (per side)...
Any reason this FD/FP order change (from STI 65deg ramp instructions) would not work on the original 45deg ramps? Of course with proper thickness selections being made. Once I start tearing into the diff it might be more obvious.
[OEM] pressure ring | 1.7 FD_it | 1.6 FP_et | 1.7 FD_it | 1.6 FP_et | 1.6 FP_et | 1.5 SP_et | case
[rebuild kit] pressure ring | 1.7 FD_it | 1.6 FP_et | 1.7 FD_it | 1.6 FP_et | 1.6 FP_et | 1.85 SP_et | case
[60deg + rebuild kit] pressure ring | 1.6 FP_et | 1.7 FD_it | 1.7 FP_et | 1.7 FD_it | 1.7 FP_et | 1.85 SP_et | case
[add NISMO to OEM] pressure ring | 1.7 FD_it | 1.6 FP_et | 1.9 NISMO FD_it | 1.6 FP_et | 1.65 NISMO SD_it | 1.5 SP_et | case
[NISMO + rebuild kit] pressure ring | 1.7 FD_it | 1.6 FP_et | 1.9 NISMO FD_it | 1.6 FP_et | 1.65 NISMO SD_it | 1.85 SP_et | case
et = external tab
it = internal tab
Old 06-09-2019, 03:17 PM   #42
mrsaturn7085
Member#: 375462
WR Blue
The 45 and 60 degree ramps are machined to the same thickness so you just take your measurements as usual and rebuild to spec. 60 deg ramps just make the diff. work faster since it has less ramp incline to fight against.
