Welcome to the North American Subaru Impreza Owners Club Thursday March 21, 2019
Old 12-06-2017, 02:02 PM   #126
PizzaBoyX
Member#: 474796
2016 WRX
Originally Posted by Jesone View Post
So you recently was having my car tuned and while on the dyno a seal blew or a head. Black smoke came out of the exhaust (passenger side). So all mods were put back to stock and my question is will they be able to see that it was modded before from the ecu?? It has been flashed back to normal with AP V3 but did die trying to get it home. Which it was towed to my house. I知 trying to get info as to what to be aware of. I知 under 60k so the power train is covered but I知 sketchy on the ecu part... please advise!!!
first; this is in the wrong section.
second; yes they can tell as I believe the ignition count resets to 0 when you flash the ECU. It's also the first thing they will check being that it's an engine failure.
third; even if they somehow miss that it was flashed, any competent tech can tell when bolts are removed/replaced for the most common mods. they'll see the nicks from the socket, or if you put new ones on, they'll see that they're too new for the age of the car.
bring it in, and see what happens; don't offer anymore information than they ask you.
PizzaBoyX is offline   Reply With Quote
Old 12-07-2017, 08:23 AM   #127
RobM
Member#: 177056
2015 WRX - CVT
2009 Forester XT
Or you can pretend to be responsible, and own up to what you did.
RobM is offline   Reply With Quote
Old 12-09-2017, 11:48 AM   #128
Knotsure
Member#: 41730
1415 Legacy/Forester
D.Grey/White
Not 都ketchy on the ECU part. Just SKETCHY
Knotsure is offline   Reply With Quote
Old 12-29-2017, 12:00 AM   #129
Alexisti
Member#: 469528
I have this problem with my sti 2011, the light you see in the picture is show up for couple minute or I can turn off the car and turn back on and the light stay off so I dont why they turn on randomly or what can cause the problem
Alexisti is offline   Reply With Quote
Old 01-01-2018, 09:13 AM   #130
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Originally Posted by Alexisti View Post
I have this problem with my sti 2011, the light you see in the picture is show up for couple minute or I can turn off the car and turn back on and the light stay off so I dont why they turn on randomly or what can cause the problem?
Wrong thread, should be in electrical since you don't appear to have a warranty denial.
Old 01-01-2018, 11:05 PM   #131
Alexisti
Member#: 469528
Old 09-04-2018, 09:23 PM   #132
Optimus_Cr1m35
Member#: 488180
2017 WRX
WR Blue
Make: 2017 Subaru WRX
Mileage:18000
Time Out Of Use:5 days
Problem And Likely Cause:AC compressor failure, no cause given
Modifications:All cosmetic at this point, Nameless Axle Back.
Submitted For Warranty Work (Yes/No):Yes
Reason Given For Denial:None
Your Story: Bought the car in July. About 2 weeks ago, the AC stopped getting cold. Cooled intermittently. Scheduled service, dropped it off Friday. I asked for a loaner if the repairs were going to take a while. Service manager walked out, started it, ran the AC, said "You're getting a loaner".
Since it was the Friday before a holiday, they couldn't order anything until today. I'm expecting the car back on Thursday/Friday.
They gave me no issue at all with the warranty. Said "Don't worry about it, it's all covered. Now try to sell your wife this new Outback when you get home..."
The last Dealer I spoke to wasn't so decent. Seemed pretty shady. Talked about co-pays, tried to get me to trade in a car I just bought, etc. And I was just picking up clips I ordered from SOA.
Optimus_Cr1m35 is offline   Reply With Quote
Old 09-19-2018, 05:48 AM   #133
FlySense88
Member#: 327665
Make: 2019 Subaru STI limited
Mileage: 269
Time Out Of Use: 6 days and counting
Problem And Likely Cause: presumed to be a fried ECM, no cause given
Modifications: Tints
Reason Given For Denial: Appeared to be tampered with, ECM doesn't fry on it own
Your Story: I get in my car (after letting it sit for 6 days), and attempt to go to work. I noticed all the lights on the dash are on, blinking, and something isn't right. I turn it off, thinking it needed to be reset, I unplug the battery, and the car hasn't cut back on since. I get it towed to the dealer. They said its a hole in the firewall grommet, and 3 copper strands in the fuse box under the hood. The dealer say it appears as the car's electrical systems have been tampered with, there for it will not be covered. I am blown.
FlySense88 is offline   Reply With Quote
Old 09-20-2018, 05:23 PM   #134
vlad11591
Member#: 295970
2018 WRX
ISM
That's ridiculous.
I would go to another dealership or try SOA.
vlad11591 is offline   Reply With Quote
Old 01-14-2019, 02:25 PM   #135
zaggy07
Member#: 420235
2015 WRX
WR Blue
Default Had to Replace BCM
Originally Posted by JRim View Post
Yes, it is common for LED bulbs to damage BCMs. Not just on Subarus either. Google it. Subaru put it out in a TechTips newsletter to look out for BCM failures related to aftermarket LED bulb installations. Doesn't seem like a big deal but it is and the repair is not cheap.
Subaru needs to start using LEDs or warn customers about doing this. I had to replace my BCM after installing LEDs (interior, trunk and license plate lights). It was so easy finding replacement LEDs on a variety of websites but no warnings about the damage it can cause.
zaggy07 is offline   Reply With Quote
Trouble/Warranty Denial Report Thread: Body/Exterior of Vehicle North Ursalia Warranty Issues & SOA Problems 146 03-02-2019 12:31 PM
Trouble/Warranty Denial Report Thread: Drivetrain (Engine, Tranny, Diff, Etc.) North Ursalia Warranty Issues & SOA Problems 3148 12-19-2018 11:21 AM
Trouble/Warranty Denial Report Thread: Interior North Ursalia Warranty Issues & SOA Problems 71 11-14-2018 08:18 AM
Trouble/Warranty Denial Report Thread: Suspension North Ursalia Warranty Issues & SOA Problems 56 03-21-2018 11:09 PM
Trouble/Warranty Denial Report Thread: Braking System North Ursalia Warranty Issues & SOA Problems 94 11-23-2016 05:27 PM
