Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2019
Old 02-15-2019, 09:11 AM   #1
SubeN'Siren
Member#: 151171
02 Subaru WRX
Default Target boost vs Manifold relative pressure discrepancies
02 wrx logging with tactrix.
Logging target boost (psi relative to sea level) and Manifold Relative Pressure (psi relative to sea level).
There is a large discrepancy at vacuum, for example:.
target at idle log is -.93
Manifold log reads -6.79 to -7.79
Is this indicating a problem, or am I not quite understanding this?
SubeN'Siren is offline   Reply With Quote
Old 02-16-2019, 01:56 AM   #2
JSR84
Member#: 469585
Vacuum results from the mechanical principles of the engine and atmosphere pressure, its not controlled by the ECU such as boost. No issues there, other than your vacuum may be low, depending on where you live and whats done to the engine.
JSR84 is offline   Reply With Quote
