Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2019
Old 02-02-2019, 04:30 PM   #1
fg2drummr
Member#: 440466
2015 STi Limited
Default 2015 Sti popping and hopping when turning
Hello everyone,
I have a 2015 Sti with 57k miles on it and I seem to be in a need of help as my Subaru dealership is confused on what is going on with my car.
The symptoms are usually when I first drive my car and turn the wheel left or right and start to move forward or backward, I will hear a loud pop sound. Then intermittently the car will hop around as if you are driving on 4low in a 4x4.
Subaru has had my car for about 3 weeks coming on 4 weeks now.
They have replaced both front axles, top hats on my struts, and I even got a brand new transmission.
The car is still making the noise and I want to see if anyone else has dealt with this.
Thank you for anyone who can help.
fg2drummr is offline   Reply With Quote
Old 02-02-2019, 04:55 PM   #2
Blktrax
Member#: 220971
2002 WRX 223K Mi.
If you put the DCCD into “Lock” it will do exactly what you’re explaining.
Blktrax is offline   Reply With Quote
Old 02-02-2019, 05:09 PM   #3
fg2drummr
Member#: 440466
2015 STi Limited
I've checked the DCCD as well and it's set to auto. The only time I touch it is to go auto + in the slippery weather and auto - in the summer.
Old 02-03-2019, 12:20 PM   #4
fg2drummr
Member#: 440466
2015 STi Limited
Hoping to see if anyone else has dealt with this.
Old 02-04-2019, 01:12 PM   #5
fg2drummr
Member#: 440466
2015 STi Limited
Monday bump
Old 02-16-2019, 02:06 PM   #6
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
You've ruled out front axles/front diff.
Suspect drive shaft joints or rear differential.
That model has a Torsen rear diff and it is possible you have an issue/failure in the diff gear cluster. I would drain the rear diff and see if you have gear teeth in the oil.
Old 02-16-2019, 07:33 PM   #7
AZP Installs
Member#: 40160
At the Track
I would agree or it could be an electronic issue with the DCCD.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
AZP Website | Like us on Facebook! | E-mail: [email protected] | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971)
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 02-17-2019, 10:05 PM   #8
fg2drummr
Member#: 440466
2015 STi Limited
-Mike Paisan
Rear diff and driveshaft were all inspected and fluid changed on the rear diff showed no containment. How would one test the DCCD?
