Welcome to the North American Subaru Impreza Owners Club Friday March 22, 2019
Old 03-30-2009, 09:22 PM   #26
STi-MAN
Member#: 70252
05 STI
blue
maybe people will shoot me i use the heavier castrol gtx. and do oil changes around 2500.
10w40
STi-MAN is offline   Reply With Quote
Old 05-29-2009, 04:44 PM   #27
generalee69
Member#: 106470
2004 GT-1 ICSCC #9
www.ClintonRacing.com
Just to bump this up... I wanted to see if other people using Rotella 15W40 (non-synthetic) at the track were having the same experience I am.
I have been changing the oil between every other event. Towards the end of the second day I noticed that the oil seems to degrade a bit. In a 30 min race, at about the 20 or 25 min mark I notice that the oil pressure will start to drop (from 75psi down to about 65psi WOT throttle). Then when I change it, it visually looks like it is time for a change.
I am getting about 250 miles in 2 race weekends between changes.
I'm thinking about switching to the Mobil1 15w50 or the Valvoline VR1 20W50 to see if I get the same results. I'm really not interested in forking out the $8-$10 per quart for Amsoil or Redline (flame suit on!).
generalee69 is offline   Reply With Quote
Old 05-29-2009, 05:53 PM   #28
[email protected]
Member#: 188533
97 civic
black
In cars I have built, I have run into more problems with mobil 1 than any other oil. The best oils I have used are Redline 5-40 (but does have a tendancy to blow-by) on high boost motors or AMSOIL 10-40 for street apps. and the new AMSOIL Dominator 15-50 for race and/or track day apps...
I have had more success with AMSOIL (reliability) in Subies, Evos, BMW, and Honda..
scott@GBR is offline   Reply With Quote
Old 05-29-2009, 06:57 PM   #29
MasterKwan
Member#: 98961
2003 WRX
I've switched to the Mobil1 15w50. I can't measure the pressure the way you do though so, I can't be more specific. It seems to flow better cold than the 0w-40 Mobil 1 I had been using. My car doesn't consume the 15w-50. It used to eat some of the 0w-40 though. The 15w-50's extended service oil for some of the euro cars that have 15K mile oil change intervals. I change mine every other track day or before 2 day events.
Old 05-30-2009, 01:03 AM   #30
.one lane
Member#: 114528
2002 Space Shuttle
Discovery
amsoil 10w40 is what i use. haven't had any oil consumption issues yet. *knock on wood*
.one lane is offline   Reply With Quote
Old 05-30-2009, 01:26 PM   #31
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
We use Motul 300V Competition 15w50 in built motors on track and Castrol or Shell 5w40 on non built motors. Seems to work very well.
Tony
Old 06-01-2009, 09:43 AM   #32
generalee69
Member#: 106470
2004 GT-1 ICSCC #9
I picked up some 20w50 "Not street legal" Valvoline this weekend. At about $5 a quart it seemed worth a try. Supposed to have elevated levels of ZDDP (1200ppm). If I can get through 2 weekends without the pressure dropping during a 30min race, I'll call it a success.
Thanks for the advice again everybody.
Old 03-26-2010, 10:34 AM   #33
Fred
Member#: 3560
00 2.5RS, 06STi
06FXT, 95rallyimpreza
Bumping this because I just acquired an 06 STi, and the dealer put 5W20 Amsoil in it. Autox school this weekend, I'm instructing and doing some "getting used to the car" runs in it. Which is pretty much WFO and see what it does when I _____. Is this oil too thin, or ok? I'll change it tonight if it's not appropriate for tomorrow's use.
Also, there's 5 quarts in it. Appropriate level, or adjust? Has Fumoto valve, so I can drain some easily if needed.
The car is stock except for a Scoobysport muffler, and I'll be burning up some RE070's.
Thanks!
Fred is offline   Reply With Quote
Old 03-26-2010, 10:40 AM   #34
STi-MAN
Member#: 70252
05 STI
blue
whoops
Old 03-26-2010, 10:52 AM   #35
MasterKwan
Member#: 98961
2003 WRX
Look at the owners manual. Severe service = thicker oil.
Old 03-26-2010, 10:40 PM   #36
JMS Landshark
Member#: 48773
2004 TiC WRX
also '99 BMW M Roadster
When someone is asking that question for a OEM motor or a straight forward built motor that started from a street car, I agree.
If the motor is being designed from the ground up, it can be designed to run with thin oil and significantly reduce windage losses. An example is that NASCAR engines run different oils for different situations, but one of the oils is 5W-20. In drag racing, you can see race engines running 0W-8. Obviously, it drives up engine cost, and has many other implications such as oil change intervals and rebuild intervals.
JMS Landshark is offline   Reply With Quote
Old 03-27-2010, 05:36 AM   #37
Fred
Member#: 3560
00 2.5RS, 06STi
So I changed the oil last night. Shell Rotella T 5w40.
Old 03-28-2010, 01:30 AM   #38
Bark3rd
Member#: 205531
15 Jeep GC Diesel
thats what Im running now in my stage 2 09 WRX, engine runs strong and cool but still getting some blow-by, about 1/2 qt every 500 mi. Easy tho casue I use the same oil in my car as all my 2 stroke dirt bikes!
Bark3rd is offline   Reply With Quote
Old 04-26-2010, 05:32 PM   #39
Zoinks
Member#: 35924
Bump-a-dump.
What's the "german" or "european" castrol people are talking about? Picked up the following and I wanted to see if it was good or bad:
Castrol Syntec 5w-40
Front says "Specifically formulated to meet the needs of BMW, Mercedes, Volkswagen"
Back says "Offers full synthetic performance, engineered specifically to meet Volkswagen engine service requirements" and later on "Superior European formula now blended in the U.S.A. Made in U.S.A. from domestic and imported components."
API Service SL, SJ, CF
Carries a number of manufacturer specific certifications for GM/VW/Porsche/MB/BMW
So what did I buy? I was just looking for synthetic 5w-40. So did I get something better than I expected to find or is some sort of strange VW voodoo that's going to kill my engine when I do a track day?
Zoinks is offline   Reply With Quote
Old 04-26-2010, 06:08 PM   #40
Zoinks
Member#: 35924
Upon further review it looks like the "German" Castrol is specifically the 0w30.
http://www.bobistheoilguy.com/forums...Number=1757753
http://www.bobistheoilguy.com/forums...&Number=782392
So as long as this oil is SL/SJ compliant and the right viscosity, am I good to go anyway? Anyone used this before?
Old 04-26-2010, 09:30 PM   #41
Butt Dyno
Street's closed, pizza boy
Member#: 17301
2016 FoST ST3
2006 Evo #17 STU
I've heard nothing but good things about the GC 0W30, IIRC it's supposed to be more like a 40. No idea how it holds up on track though.
BTW... Mark sighting!
Old 04-26-2010, 11:54 PM   #42
Zoinks
Member#: 35924
Hey man, you still in the area/doing WDCR events? Hoping to finally get back out there this summer and have the SM guys beat me up.
I feel like even the best 30 should be too light for track/autox duty - even if GC is more like a 40 it's still less than a 40, and 40 seems like it would be the minimum for hard driving. Flip side, of course, is that I'm reading that a lot of the actual labeled 40s shear down to lower viscosities rather quickly. Very confusing. What a pain in the ass.
Old 04-27-2010, 06:13 AM   #43
vicious_fishes
Member#: 158864
2003 SOHC destroker
castrol edge 0-40 is where it's at.
vicious_fishes is offline   Reply With Quote
Old 04-27-2010, 07:22 AM   #44
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Still running Mobil 1 15W-50 after many years. No problems at all.
Old 04-27-2010, 08:10 AM   #45
Rokkit
Member#: 84181
NASA #530 GTS2
Valvoline Racing 20w50 here.
Rokkit is offline   Reply With Quote
Old 04-28-2010, 05:37 PM   #46
elberoth
Member#: 242877
blue
Motul 300v 15w-50 here.
elberoth is offline   Reply With Quote
Old 04-29-2010, 04:34 PM   #47
Feffman
Member#: 39669
We run Total synthetics from the Performance Oil Store (www.PerformanceOilStore.com). True PAO synthetic.
Feff
Feffman is offline   Reply With Quote
Old 04-30-2010, 05:50 AM   #48
bluesubie
Member#: 767
04 FXT
Originally Posted by Zoinks View Post
Bump-a-dump.
Just don't run it very long, IMO. It usually shears to a lower viscosity than GC does after some heavy use.
Unfortunately, it's not available in N. America.
-Dennis
Old 04-30-2010, 05:08 PM   #49
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
i ran ELF full syn 5w30, 5w40, 10w50 and TOTAL in similar grades..
recently switched to ELF 0w30 for a track day.. love it..
haven't notice any oil consumption at all since i bought the car 8 years ago..
KIMUTAKU is offline   Reply With Quote
Old 04-30-2010, 08:47 PM   #50
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Mobil1 15w50 on a built motor here.
bhhamblin is offline   Reply With Quote
AutoX/Track Day Oil Level 68Cadillac Motorsports 7 02-06-2008 08:49 PM
Track day oil temp data, N/A Subie Patrick Olsen Motorsports 8 04-29-2006 04:30 PM
Recommendations for swaybar setting at track day MattSTi Motorsports 25 09-08-2005 02:17 PM
STI track day recommendations?. WRX 2002 STi Forum Archive 5 08-07-2003 09:16 PM
Track Day Tires-recommendations please. SFsube Technical Forum Archive 16 08-09-2000 05:55 PM
