Welcome to the North American Subaru Impreza Owners Club Tuesday March 26, 2019
Old 05-03-2010, 07:53 PM   #51
pete_falcone
Member#: 123330
16 ZoomZoom CeX-3
15 ZoomZoom3-Regina
Amsoil 5w30 or Rotella 5w40. I use the former while I was in Tri-State and switched to the latter after moving to SoCal. Temps can go well over the 100 mark here at Willow Springs during the summer and I'm glad the Rotella has been doing a good job for my engine.
pete_falcone is offline   Reply With Quote
Old 03-10-2011, 06:38 PM   #52
DutchOven
Member#: 220629
2010 White WRX Hatch
2015 White WRX Limited
Just switched to Pennzoil Synthetic 5w30 from Mobil1 0w40. It was recommended by bob the oil guy, so I wanted to try it out.
I will be getting oil analyses from now on, it seems most recommendations are not backed by data and testing but only by how it "feels."
bump.
DutchOven is offline   Reply With Quote
Old 03-10-2011, 06:45 PM   #53
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Keep in mind that the consumer-orientated UOAs, such as those recommended by all the guys over at Bob's, can't actually tell you if one oil is working better than another oil. A lot of the idiots over there think that you can tell that from a UOA. You can't. There's even pages of information over there telling you WHY you can't use a UOA to figure out if one oil is protecting better than another yet the idiots still think it works that way.
UOAs tell you if your oil change interval is reasonable for the oil you're using and they can tell you if your engine suddenly does something new (new is bad). That's it. Nothing more.
The Pennzoil Platnium you're using now has a low-ish HTHS of 3.0cP. I wouldn't be comfortable running that oil in a track-driven turbo EJ-series engine. The 0w40 M1 you were using before was actually a better choice because of it's higher (3.7cP) HTHS. A 0.7cP change in HTHS is a BIG change in HTHS. If you wanted to get a high HTHS in a thinner oil (which is a good idea), Redline 5w30 has an HTHS of 3.8 even though it's only a 5w30. That would be an even better choice.
Old 03-10-2011, 07:08 PM   #54
DutchOven
Member#: 220629
Very interesting. I'm still an oil noob and that was very helpful. Thanks!
I'll probably switch out my oil before the next track day. I am a little bit bummed now, because for a second I thought I could get away with using a low-cost oil on the track
Pennzoil Platinum 5w30: $20 (5qt bottle)
Mobil1 0w40: $8/qt x 5 = $40. (can't seem to find a 5qt bottle)
Redline 5w30: ~$8.75-$10 /qt (initial search failed to find any local vendor that stocks it)
I wish racing was cheaper
Old 03-10-2011, 07:11 PM   #55
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yeah, it's not cheap, but it's a hell of a lot cheaper than new parts. For your application, I'd be absolutely looking for an oil with an HTHS over 3.5 and then the lowest kinematic viscosity at 100C that I could find. The ones that are hard to beat for that are Redline and Motul 300V. Some of the ELF oils are very good as well. Any of the "American" oils (Pennzoil, Castrol (except GC), Valvoline, etc) can't even come close.
Old 03-10-2011, 07:39 PM   #56
DutchOven
Member#: 220629
Where would I be able to find these things about oils?
I read here that Motul 300V isn't very good for a car that sees many cold starts
http://www.mazda3forums.com/index.php?topic=160869.0
Agreed. The 300V is most definitely NOT suitable for extended street use. It's a "no holds barred" oil designed to be used for a weekend race... the additives aren't designed to hold up to multiple cold starts
Your thoughts? My car is a daily driver with a track day every 2-3 months. Motor internals are stock, with full exhaust, intake and a pro-tune.
EDIT:
Found spec sheet for 5w30 Motul 300v
http://www.opieoils.co.uk/pdfs/MOTUL...5-%28GB%29.pdf
AND:
Motul 8100 X-Lite 0W-30
100 Vis - 11.9
40 Vis - 66.5
VI - 177
TBN - 11.2
Flash - 232
Motul 8100 Eco-Clean 5W-30
100 Vis - 10.1
40 Vis - 56.7
VI - 167
TBN - 4.2
Flash - 232
Motul 8100 X-Max 5W-30
100 Vis - 12
40 Vis - 73
VI - 161
TBN - 10.9
Flash - 232
Motul 8100 Eco-Energy 5W-30
100 Vis - 9.9
40 Vis - 57.7
VI - 159
TBN - 10.3
Flash - 226
Motul 300V 5W-30
100 Vis - 11
40 Vis - 65
VI - 162
TBN - 11.3
Flash - 218
HTHS - 3.61
Old 03-10-2011, 08:09 PM   #57
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
If you're changing your oil ever 3,000mi, the 300V would be just fine, although quite expensive. The cold starts aren't so much the issue as extended drain intervals. You have to keep in mind that the rest of the world considers 10,000mi to be a reasonable oil change interval for a typical car. Some are less, some are more, but basically nowhere else in the world is a 3kmi oil change seen as a sane thing to do. So when something like the 300V says "not for extended drain intervals", there's a good chance that it actually would be just fine with an American oil change schedule.
The most important specs from those are the HTHS (which you want to be high) and the Kinematic Vis at 100C (which you want to be low).
Old 03-10-2011, 10:00 PM   #58
jaegmeister
Member#: 236092
2004 wrx full exhaus
vf48 aps big tmic nstuff
Is is recommended to change the oil after any track day event, or say an autocross event? I'm running rotella synthetic. sorry for the hi jack...
jaegmeister is offline   Reply With Quote
Old 03-10-2011, 11:07 PM   #59
DisoDisp
Member#: 187648
2007 WRX
I don't agree with that assesment.
I've been running Motul 300V 5w-40 for 3 years every day, Summer and Winter, i.e. really cold starts. -30C etc.
No problems at all, and the oil change interval is about 10k miles. Oil looks just fine coming out.
DisoDisp is offline   Reply With Quote
Old 03-10-2011, 11:22 PM   #60
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Looks don't mean jack ****. You need to get a UOA to look at viscosity, flashpoint, dilution, and TBN to see how the oil is doing.
Old 03-10-2011, 11:32 PM   #61
jaegmeister
Member#: 236092
10k miles? Only people in Europe do that...
Old 03-11-2011, 05:08 PM   #62
Johnny Butane
Member#: 95618
'05 Evo8, S2K, Z06
Black - Black
I've had success with Brad Penn and Redline. Here is a good read from FP.
http://store.forcedperformance.net/m...otor%20Oil.pdf
jeff
Johnny Butane is offline   Reply With Quote
Old 03-11-2011, 05:17 PM   #63
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
jeff
See, that goes back to what I said before, people are getting one result and drawing the wrong conclusions from it. That FP blurb gives a lot of bad advice.
The real difference, that they don't even talk about, between the M1 10w40 and the BP 20w50 is the fact that the BP oil has a MUCH better HTHS and a higher zinc and phosphorous content. The actual weight of the oil means nothing in their comparison. It's like saying a Mustang is faster than an Impreza because the Mustang has 2 more cylinders than the Impreza while totally ignoring the fact that the Impreza was a 1.8L while the Mustang was a 5.0L with a blower and a 200-shot.
Old 04-03-2011, 08:07 AM   #64
DutchOven
Member#: 220629
Subaru recommends that you use oils that only have the GF-4 or GL-3 rating on it. Does it matter if we use an oil that does not have one of the above (or something similar if I'm mistaken)?
And is it bad to stray away from the factory recommended '5w30' oil? I've noticed no difference but I'm curious if it really does any harm.
Old 04-06-2011, 02:24 AM   #65
DutchOven
Member#: 220629
Nvm, just read this entire thread, was extremely helpful:
http://forums.nasioc.com/forums/show....php?t=1259545
Old 04-06-2011, 05:27 PM   #66
bluesubie
Member#: 767
04 FXT
A uoa and voa will show you that Red Line and 300V both have enough detergents for street use and enough "additives" for multiple cold starts.
If you use a robust 30 grade (high HTHS, nice additive pack), there's no need to bump up to a 40 IMO.
-Dennis
Old 04-09-2011, 10:11 AM   #67
Swine
Member#: 16197
07 GX470 PearWhite
09 VMAX, 02 BMW R1150r
So does anyone have a general consensous on the Shell Rotella oils? Are these indeed a good/better Oil to use then say mobil 1 5w30?
Swine is offline   Reply With Quote
Old 04-09-2011, 12:52 PM   #68
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
Yes. And yes.
/thread.
JamesWilson2 is offline   Reply With Quote
Old 09-04-2015, 06:28 AM   #69
niko493
Member#: 400018
It also greatly depends on the oil temperatures you see during track events. If you are at 100 i'd use sae 40, 105-120 i'd use sae 50. Make sure to change before and after as others said.
niko493 is offline   Reply With Quote
Old 01-28-2019, 06:54 PM   #70
Chocolaterain72
Member#: 497077
2005 STI
Ebony black pearl
Has anyone used the Amsoil 0w40 Iím their car for track days at all? I daily my car and track it 3 to 4 times a year with an oil change every 3k. Any thoughts?
Chocolaterain72 is offline   Reply With Quote
Old 01-30-2019, 12:30 PM   #71
kwiksti
Member#: 480195
2014 STI Hatch
Originally Posted by Chocolaterain72 View Post
Has anyone used the Amsoil 0w40 I’m their car for track days at all? I daily my car and track it 3 to 4 times a year with an oil change every 3k. Any thoughts?
A 5w-40 is all you need. Unless your motor is built. Stay away from all the energy conserving oils on the market. Basically anything that has the API symbol. Now they will all work great in daily drivers, but for any type of tracking where your gonna push your car engine to the limits. They will not protect and break down as well as those 3 mentioned.
I was enlightened by my tuner during my Protune. This guy and his shop are legit. They build, race, and prep track cars for a living.
With that info. I was told best oils are Millers Oils, Motul 300V, and Driven in that order. They will protect your EJ or any other motor better than any oil on the market. I myself will be using Driven 5w40 and changing every 3000 mi unless there is an event coming up. I'll change it early.
kwiksti is offline   Reply With Quote
Old 01-30-2019, 12:35 PM   #72
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
I use 300v in my Subaru and have seen/heard good things about Millers oil as well. Motul's 8100 series is also good as is a few others. I like the 8100 series since I can leave it in the car to DD while also doing an odd track day or what not. I would change after 2-3 track days though on just about any oil assuming it's a warm day.
subydude is offline   Reply With Quote
Old 01-30-2019, 12:44 PM   #73
subydude
Member#: 80649
This is an interesting article to read, and the ratings about a quarter of the way down the page give some good info. Another oil I forgot above is redline. In general, it really comes down to wear, usage, temp range, etc.
https://540ratblog.wordpress.com/201...-test-ranking/
Old 02-12-2019, 08:26 PM   #74
AZP Installs
Member#: 40160
We've done plenty of track events, races and even some enduros. You will want to run an oil cooler regardless of which subie you track. We use Motul 8100 5w30 X-clean and 5w40 X-cess and alternate that with 300V 5w30 in our track only cars. We skip the 300V on our dual purpose cars. After 4-5K miles and 2 track weekends we get back UOAs with excellent results.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: [email protected] | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971)
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
AutoX/Track Day Oil Level 68Cadillac Motorsports 7 02-06-2008 08:49 PM
Track day oil temp data, N/A Subie Patrick Olsen Motorsports 8 04-29-2006 04:30 PM
Recommendations for swaybar setting at track day MattSTi Motorsports 25 09-08-2005 02:17 PM
STI track day recommendations?. WRX 2002 STi Forum Archive 5 08-07-2003 09:16 PM
Track Day Tires-recommendations please. SFsube Technical Forum Archive 16 08-09-2000 05:55 PM
