Welcome to the North American Subaru Impreza Owners Club Tuesday March 26, 2019
Alaskan Impreza Club
Old 12-03-2014, 12:47 AM   #951
novarocker247
Member#: 407707
Default 2.5 Hybrid misfire.
Originally Posted by P3Auto View Post
Open thread to discuss tunes, answer questions, and advise.... Anyone?
Bring it on...
I bought a 2005 wrx wagon with a hybrid (2008 sti ej257 and 05 heads). I have thick cosworth head gaskets on it but just about everything is stock. Im having a misfire at idle and apprently one once it warms up but you really cant tell. The misfire reads in all cylinders. I know that it is running lean. The timing is on mark as far a I know. Could a tune be the problem?
novarocker247 is offline   Reply With Quote
Old 12-07-2014, 07:14 PM   #952
Jeffsgota66
Member#: 407797
Does upgrading the fuel pump and hardwiring it require a tune? I am also upgrading from side feed to top feed with bigger injectors and I know that requires a tune. But can I do the fuel pump separately or should I complete both jobs at the same time?
Also...after said upgrades above is it safe to granny the vehicle for a few days until the tune or should it be towed to the tuner/dyno after the upgrades are completed.
Thanks and sorry if this has already been answered....cheers.
Jeff
Jeffsgota66 is offline   Reply With Quote
Old 01-10-2015, 12:44 AM   #953
gnarwhal
Member#: 406592
2005 Impreza WRX
So I have an 05 wrx and my friend has an 04 wrx which he is planning on selling. He has a v3 accessport with an element auto tune and I have a v2 with a P3 tune, would it be possible to swap the tunes and APs in the cars so I can buy his and he sells his car with mine?
gnarwhal is offline   Reply With Quote
Old 01-10-2015, 10:24 PM   #954
exogen
Member#: 355393
03 wrx 4eat
psm
Looking at upgrading.
currently have
07 sti fuel pump
catless uppipe
catless downpipe
cobb rep catback
cobb 3port ebcs
On Order
cobb SR intake
vf48
550cc injectors
cobb v3 ap
This will be going on my stock 03 wrx. Besides a tune with the AP is there anything else I should be concerned with? My wrx is a 4eat (stock) will be looking at a conserv tune main goal is between 250-300whp-ish.
exogen is offline   Reply With Quote
Old 02-19-2015, 09:04 PM   #955
darkshizuma
Member#: 413960
2000 Outback
Teal?
Default new to north pole/ alaska
hey guys! I'm relatively new to Alaska/ north pole, and picked up a 2000 outback that needs some work (Shop said i "threw a rod"). Dose anyone know where i can pick up a 2.5, 3.0, 3.6 motor for a reasonable cost? Theres a guy in Wasilla thats asking $2,500 for a motor and labor to install it (id rather chew my own foot off). and it seems that everything on craigslist is junk or grabbed up super quick.
my full intention is doing a 6 speed 3.0 or 3.6 swap... but i just need some wheels for right now, so I'm totally cool with rebuilding mine if thats an option.
also, recommendations on shops that are good or tuner friendly would be appreciated!
darkshizuma is offline   Reply With Quote
Old 02-19-2015, 09:12 PM   #956
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Even if you found a 3.0 or 3.6 it would not be cheap to make it all work, wiring, ecu, etc.
Any 2.5 bottom end will work for the case halves. If you intend to build it yourself you can source parts pretty cheap. I'm assuming there is a hole in your block or is it just a bad rod bearing?
TurboSetch is offline   Reply With Quote
Old 02-21-2015, 02:39 PM   #957
darkshizuma
Member#: 413960
2000 Outback
Teal?
I haven't gotten a chance to open the the block myself, but a bearing would be my assumption.
If that were the case; new bearing, rod, piston and valves on that cylinder?
And the cost really isn't an issue (not that I'm made of money) Since the cost of all these things jump around so much.. ($500 wrecked car on Craig's list vs the 2.5 with 100xxx miles that they want 2 grand for (smh)) so there is no "cheap way" as far as I'm seeing, even rebuilding the block could get hella expensive..
I just wanna drive... Lol, know what I mean?
Old 02-21-2015, 06:19 PM   #958
darkshizuma
Member#: 413960
2000 Outback
Teal?
Drained the oil Today and it Looked fine/ no chunks of anything. There was, if you looked really close some super fine metallic "dust," but it wasn't enough to say "OMG!" or think it really out of the ordinary.
Old 02-25-2015, 01:51 PM   #959
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Subaru bearings (rod bearings) have zero forgiveness. Any metal in the oil that appears to be bearing material basically means avoid it. To see the chunks you need to pull the pan. If you hear slight knock or any bottom end noise it wont be long before complete failure follows.
Old 06-06-2015, 02:34 PM   #960
OchoPinocho
Member#: 351221
2009 WRX STI Hatch
Just moved to fairbanks, do you guys use octane booster or just got tuned for the gas?
OchoPinocho is offline   Reply With Quote
Old 07-23-2015, 02:22 AM   #961
Cissac
Member#: 292642
2004 impreza wrx
world rally blue
Hello my name is Issac and I have been wanting to ask you a few questions, first do you carry oil Lines and oil restrictors, second what would you recommend for an oil change in a 04 sti transmission and r180 differential, lastly what would you recommend I use to clean my intercooler out?
Cissac is offline   Reply With Quote
Old 10-04-2015, 01:27 PM   #962
T_woot
Member#: 321665
2006 WRX VF39 Swap
WRX Blue
I have a 06 wrx wagon. I have install a vf39, process west tmic cobb cai, grimmspeed ebcs, turbo back with hf catted dp. Car is Protuned with ap. I blew a headgasket and decided to build the motor with all forged internals and sti crank, arp head studs and oem gasket kit. Valves adjusted bigger oil pan, all maintenance done. I just finished breaking in the motor as per the builders instructions. Should I get the car retuned for the new motor? The main monitors cobb instructs you to log / check are within recommendation. I don't know much about tuning... the tuner does a lot of work where I am, pretty well respected.
Sent from my SAMSUNG-SM-N900A using NASIOC mobile app
T_woot is offline   Reply With Quote
Old 12-23-2015, 01:08 AM   #963
Marko11
Member#: 436644
Default Running lean no check engine light
Hi im new here, i just bought a 2004 hybrid set up for my impreza, previous owner installed new sti block oem and the rest stock wrx, the engine has been running fine, but the previous owner told me that the its running lean and he suggested to me to put high flow rate injectors, should i replace the injector and what kind? Or just go to a tuning shop first . thank please advise
Marko11 is offline   Reply With Quote
Old 01-13-2016, 10:59 PM   #964
Frostydawg05
Member#: 358842
2006 STI
Default Re: Marko11
In my opinion, I would take it to P3 importautowerks in Wasilla. They're advice is great and are always willing to help out with any problem. They're the ones to trust in AK. I just got an $80 inspection done by them and It was well worth it. Seth and all his staff are definitely in the business of helping subaru enthusiasts.
Frostydawg05 is offline   Reply With Quote
Old 01-27-2016, 12:45 AM   #965
azak907
Member#: 432487
2013 WRX STI Hatch
Do any of you guys know of a WRX project I could buy? Been looking for one here in ak and can't seen to find one.
azak907 is offline   Reply With Quote
Old 01-30-2016, 07:07 PM   #966
azak907
Member#: 432487
2013 WRX STI Hatch
Hey NASIOC! I was wondering if anyone knows or any WRX or xt or GT Subaru project cars in Alaska. I've been trying to find one and can't seem to. Please text me at 1(907)433-96four7 if you know of any. Thanks!
Old 02-01-2016, 10:58 PM   #967
TWEAK4480
Member#: 330649
2013 STI Hatch
Hello everyone, I have an 07 a/t outback that needs a motor and I found one out of an 06 m/t Impreza and I was wondering if anyone knows if that will be a clean swap? Any help would be greatly appreciated
TWEAK4480 is offline   Reply With Quote
Old 03-21-2017, 10:31 PM   #968
Hooligan907
Member#: 464862
2004 WRX
Rally Blue
Thumbs up
Just wanted to say my experiences with P3 have been awesome! Only auto shop I'll ever take my subie to. I definitely recommend them for any import owner.
Hooligan907 is offline   Reply With Quote
Old 04-07-2017, 09:26 AM   #969
458socom
Member#: 465564
2002 wrx
blue
Looking for a tuner near Mississippi, Have AP so tune via email/logging would be fine with me.
458socom is offline   Reply With Quote
Old 06-25-2017, 12:50 PM   #970
brisketrobot
Member#: 444985
2016 STi
Pearl White
Default Tech Help
Hey Subie fam,
I finally got a chance to take my STi to the track yesterday. After about 3 to 4 laps, at WOT in 4th I started to get fuel cut off. I checked my AP and the stock boost gauge and noticed overboost with the stock boost gauge reading 24psi. Target boost pressures on the tune were 19.5psi in S#. Checked vacuum lines (visible ones) and no leaks.
2016 STi
Engine mods are as follows:
Cobb AP
Cobb SF Intake and Box
Nameless Performance Turboback exhaust - thermal wrapped
Grimmspeed EBCS
NGK Iridium One Step Colder Spark Plugs
Cobb Flex Fuel Kit
1100cc FIC Injectors
AEM Fuel Pump
IAG AOS
Protuned on e85
I did data log the runs I just need to upload them to see what's going on. Can anybody help point me in the right direction about what could be failing? I was thinking maybe having to change my turbo inlet piping and intercooler piping so that I'm not running crazy A/F ratios.
Any other ideas would be a ton of help!
brisketrobot is offline   Reply With Quote
Old 08-13-2017, 11:25 AM   #971
cuztomimportz
Member#: 97904
World Rally Blue
Default Ask a tuner...
Originally Posted by brisketrobot View Post
Hey Subie fam,
2016 STi
Cobb AP
Grimmspeed EBCS
Cobb Flex Fuel Kit
AEM Fuel Pump
IAG AOS
Protuned on e85
You can check your wastegate spring pressure. Bypass your ebcs and run a small hose from nipple on front of turbo directly to wastegate actuator nipple. Should hit and hold 10psi of boost. My tuner had me do this. If it does then it's prob ok. I just had to do this as well. I also used a good electrical contact cleaner and sprayed the ports out just to make sure everything is good with ebcs, their (GrimmSpeed) recommendation.
Hope this helps your diagnostics.
cuztomimportz is offline   Reply With Quote
Old 09-27-2017, 04:52 PM   #972
ds02
Member#: 467602
2002 WRX Wagon
Edit, fixed my issue
ds02 is offline   Reply With Quote
Old 11-09-2017, 07:45 PM   #973
Jtrav98
Member#: 460510
Hi everyone.. I am having a fkl issue I am getting between 1.4 and 2.4 fk detection around 3000 rpm and like 10-15% throttle in all gears the biggest I've gotten was 2.8 I'm wondering why it would be doing this. I sent the logs to my tuner but so far no response
Mod list:
2017 sti
18k
Invidia catless downpipe
Invidia headers
Ets extreme catback
1100cc injectors
IAG Air oil seperator street series
Dw300 fuel pump
Cobb sf intake w/airbox
Protune
Jtrav98 is offline   Reply With Quote
Old 11-09-2017, 10:47 PM   #974
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
What you have described is actually not an issue and is quite common. On a perfectly stock car with a stock tune you would actually see even more knock retard and learned values at low rpm low load situations.
So the short answer is that at low engine loads and low rpm some knock is ok and is basically harmless. The car will learn to adjust it our automatically.
If it really bothers you your tuner could pull the timing out manually in the tables but generally this is just not really required.
If you see feed back and learned knock under high load conditions particularly wide open throttle then you may want to consider some adjustments. That being said the occasional -1.4 or even -2.8 may still happen and is not always considered dangerous or a problem. CONSISTENT high load knock and knock that lowers the dynamic advance multiplier is something to be concerned with.
Always check the basics first, vac/boost leaks, fueling problems, etc before going after a tune especially if the tune was fine before. Tunes don't change over time, everything else might though.
Mod list:
2017 sti
18k
Invidia headers
Ets extreme catback
1100cc injectors
Dw300 fuel pump
Protune
Old 12-23-2017, 03:23 AM   #975
Ieatjimmysbutt
Member#: 479577
Jimmy s can eat my butt eat my butt all day long
Ieatjimmysbutt is offline   Reply With Quote
Tuner FAQ: How to pick one, what to ask of them, and how to prepare for a tune Unabomber Engine Management & Tuning 23 04-29-2018 01:17 PM
Bend, Oregon Tuners Carartist North West Impreza Club Forum -- NWIC 52 10-05-2010 10:07 PM
Tuner is asking me what compression I am using. Ryan314 Built Motor Discussion 7 04-24-2010 05:44 PM
('93-'01) sorry to ask if asked, how do u search ? christurismohk Impreza Forum 1 06-07-2001 10:11 PM
