Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2019
Old 09-15-2011, 04:22 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default dumb question on welding
Are you supposed to see anything but the bead? I have a cheap HF helmet and can't see the line/cut i'm trying to follow. Is it a helmet issue or is it normal and I need more practice?
Bad Noodle is offline   Reply With Quote
Old 09-15-2011, 05:31 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
you should be able to see everything important, I can't explain much better than that.
If you are serious you can get a nice speedglas
eg33GC is offline   Reply With Quote
Old 09-15-2011, 10:29 PM   #3
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I can see literally 1mm in front of the bread. Because of this, I tend to go off course a lot. So do I need more practice in going straight or better equipment.
Old 09-15-2011, 11:01 PM   #4
AREA1320
Member#: 112508
Better equipment.
I use an Optrel Satellite and love it.
AREA1320 is offline   Reply With Quote
Old 09-15-2011, 11:03 PM   #5
eg33GC
Member#: 206851
56 Belair
Pro Street
you might have the wrong shade by some chance?
Old 09-16-2011, 01:30 AM   #6
TIGWERKS
Member#: 256615
Originally Posted by AREA1320 View Post
Better equipment.
Im thinking of getting another helmet and probably gonna get an optrel e680 in snow white because im such a princess
TIGWERKS is offline   Reply With Quote
Old 09-16-2011, 02:01 AM   #7
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
HF helmet has a really dark #11 if i remember right. Find a #9 or #10 shade and it will make a world of a difference. Or a good helmet with variable shades.
UK-Wagon is offline   Reply With Quote
Old 09-16-2011, 11:21 PM   #8
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Thanks for the advice guys, had it on 10, changed it to 9 and it helped a bit. I read that you should have it set to an 8 for mig welding, but the HF helmet only goes to a 9... any thoughts on the lowes kobalt helment? Not going pro any time soon, just wanna get through this project
Old 10-06-2011, 05:20 PM   #9
Daboro's Rex
Member#: 55915
04 WRX stage 1/2
Wr blue pearl
#8 shade is really light. I normally weld on a #10 if you go real light you are going to burn your eyes. Are you Mig welding or Tig, Also what are you welding. that will help on trying to figure out what you should be using. it takes a little bit of time to get used to it.
Daboro's Rex is offline   Reply With Quote
Old 10-07-2011, 07:19 AM   #10
quazimoto
Member#: 70395
Get an auto dimming helmet. Unless your work area is lit up very,very well it makes things 10x easier. I'm like you,a hobbyist,but the money was well worth it as it makes things much easier and less mistakes.
quazimoto is offline   Reply With Quote
Old 10-07-2011, 03:23 PM   #11
O.C.D.
Member#: 19640
2003 WRX Sedan
I have a HF #11 auto-dimmer and I can see everything. Not MIG/TIG though. So far only arc-fed.
$.02
O.C.D. is offline   Reply With Quote
Old 10-07-2011, 06:56 PM   #12
albersondh
Member#: 196882
08 WRX
Better equipment.
X2 for Optrel Satelite. Had mine since 05 with heavy use and still working great.
albersondh is offline   Reply With Quote
Old 10-11-2011, 10:55 PM   #13
veloandy
Member#: 297556
+1 on the $50 adjustable HF auto-dimming helmet. I've used mine for both arc & mig. Works great and was a night-and-day (sorry about the pun) improvement over blind pecking a welding rod with my dark welding goggles.
I'm a complete cheap-o...and even I think it was DEFINITELY money well spent.
veloandy is offline   Reply With Quote
Old 10-11-2011, 11:08 PM   #14
bmw325ix
Member#: 204652
try leaving a strong flash light pointed at your work if your having a hard time seeing, that's what I did before upgrading my mask to one that is variable
bmw325ix is offline   Reply With Quote
Old 11-02-2011, 05:44 PM   #15
hagens96
Member#: 274239
2004 sti
white
i recomend a snap on or miller helmet, a bit higher priced than some but if you think you might weld more than say.... ONCE spend the money its worth it!
hagens96 is offline   Reply With Quote
Old 10-12-2017, 04:10 PM   #16
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
OK, older thread, but......
Shop I work PT at just bought an inexpensive MIG unit. I have an older "buzz box" stick welder to use (free).
Also do some gas welding, cutting and grinding.
This is all occasional use, not full time, willing to upgrade down the road if use gets higher.
Just bought this......https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1.... any comments on the range it covers? Likely better than what I use, lower price point so not out a lot of cash.
I have only ever used goggles (gas weld and cut) or fixed tint lens helmet for stick welding.
Old 10-16-2017, 07:35 AM   #17
rtv900
Member#: 428511
2016 STI
well the tint range is 9-13, so 'technically' it will cover anything.
I weld aluminum regularly up to 280 amp alternating frequency, which is about as hot as it gets and I never go over 11.
Nobody uses 13 anymore unless you are stick welding a submarine hull.
I said 'technically' above because $45 is darn cheap for an auto darkening helmet. My experience with cheap ones is that they suck and don't darken properly. Now this is cheap ones from a decade ago, so maybe they've gotten better but personally I don't trust the cheap ones.
rtv900 is offline   Reply With Quote
Old 10-16-2017, 09:36 AM   #18
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Thanks for the reply. Yes, electronics have come down in price over the years, but this is also short term use, I can always get better if I do a lot more welding.
Should be here before lunch, so it will get tried soon.
Old 10-20-2017, 11:21 AM   #19
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Quick "auto darkening" question, is it light intensity that triggers the darkening or high UV (like arc welding vs. gas welding)?
This helmet does have a "grinding" setting, but have not seen a spec on what type of light causes the darkening.
Old 10-28-2017, 01:15 PM   #20
blubug_768
Member#: 324962
02 WRX
light triggers them. the grind setting doesnt darken, its just whatever the undarkened shade is (probably #4).
And I'm just going to throw this out there, used to have a nice auto darken helmet but one day it just quit so I got a gold plated #10 fixed shade lense and threw it in their, and while it sucks for tacking its so much nicer while welding.
I'd much rather have a nice fixed shade than a cheap auto darken.
blubug_768 is offline   Reply With Quote
Old 10-30-2017, 03:34 PM   #21
rtv900
Member#: 428511
2016 STI
I've never actually used the grind setting, but my understanding was that it actually disables the light sensor so that it does NOT darken when you grind.
There have been a few times I do a quick grind with my helmet on if it's just for a second, and its annoying as hell because the sparks trigger the sensor and then the lens darkens making it impossible to see at all.
So like the other guy said, it seems it just basically turns it off all together.
Any type of light will trigger it. Even if you look up at a metal halide or something it will trigger. There's a sensitivity dial too for that if it's triggering too much on you.
Old 06-21-2018, 02:12 PM   #22
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Cool
OK, for various reasons, I have yet to try out my helmet.
But, some time ago, I did an Internet search on "auto darkening" and found this.... http://weldingweb.com/showthread.php...ng-lenses-work
I just...can't.....wrap....my...head.....around Bill and his replies......
Old 06-22-2018, 04:28 PM   #23
rtv900
Member#: 428511
2016 STI
I just got the 'new' type of helmet that is the 'natural light' type.
Miller makes them. A solid $300 but worth it.
No more of that green tint to everything. It really looks like you are just looking through a clear lens.
No clue how the auto darkening feature actually works, but I know you sure get what you pay for. My last helmet would flash me every once in a while ONLY during aluminum welding, never mig and never steel tig. Totally bizarre but man that hurts like hell when your running 250 amps AC. Like a shot to the brain.
Old 08-13-2018, 03:17 PM   #24
David Medina
Member#: 37721
2003 WRX sedan
pearl blue
usually the arc is so bright you should be able to see everything. Its a trained eye type deal. my early days in welding school i couldnt see crap but the single bright circle. Eventually its like driving a car, there is a general direction you're wanting to look, but you also look everywhere else at times. Just like staring down the road, also looking for cops, looking for other drivers, looking for unexpected whatever. In the bead, your watching the front, all the way to how the bead looks as its cooling behind you.
some tips as other have said are to use a light shade. If your just mig tacking and doing small welds you should be ok with a light shade. If applicable, you can make a 1/16 gap between the pieces. Sometimes the gap makes it easier to see the line or the bead will follow the line easier. You can use a light behind you, that may help, or even scribe a line with some soap stone.
The auto darken works by light detection. Try welding outside and the cheaper helmets will drive you nuts. Also welding around corners and such. My current helmet is a miller elite, I bought it for the cool looks, but also has 4 sensors on top and bottom to help with getting flashed when welding in awkward positions or outside.
You may try some magnifying lenses as well to see better, or maybe your lenses are dirty. wash them with water and a rag.
David Medina is offline   Reply With Quote
Old 09-01-2018, 03:55 PM   #25
blaze15301
Member#: 450854
2004 sti
black
you should see the bead ark and a little bit out. i have used the hf hoods. you can pick up a cheap fixed leans for like 30 bucks. i weld from a shade 9 to 13 just depends on what im doing.
blaze15301 is offline   Reply With Quote
dumb question on the scooby921 strut spacer califesaver Newbies & FAQs 2 01-09-2009 01:48 PM
dumb question about driving on the highway Vampyr General Community 18 01-29-2006 04:37 PM
dumb questions, needles on startup jandree22 General Community 20 01-26-2006 05:38 PM
dumb question, but how do you remove the rear bumper on wrx? M32WRXin3seconds Newbies & FAQs 3 08-14-2003 03:37 AM
kinda a dumb question on turbo parts. =/ Solomon Normally Aspirated with bolt-on Forced Induction Powertrain 2 08-05-2003 12:20 PM
