Welcome to the North American Subaru Impreza Owners Club Wednesday March 20, 2019
Old 04-24-2018, 07:20 PM   #51
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
Originally Posted by dickydck View Post
I see this thread is everyone trying to verify if any of the scanners can read an ABS code, and actuate the ABS pump, but has anyone or can anyone confirm that any of the scanners can clear the ABS codes? I have a 2009 Subaru Impreza 2.5 I, and I can’t find this diagnostic connector under the dash to save my life
Your 2009 does not have the ABS diagnostic connector. You access your VDC system through the DLC connector. You need Subaru SSMIII or SSM4, or one of the higher functioning aftermarket scan tools like some of the Matco or Snap-On units.
I am guessing you don't know your code? When you replaced your hubs did you break the wheel speed sensors? I have seen bits of metal get stuck to the magnets in the reluctor (part of the back of the wheel bearing) and give bad speed sensor waveforms.
Elbert Bass is offline   Reply With Quote
Old 04-24-2018, 10:25 PM   #52
dickydck
Member#: 485066
I have 3 codes, c0029, c0074, and c0057.
I don't believe I've done any damage to the wheel speed sensors. I have since yesterday, take the wheels off and removed the wheel speed sensors from the knuckle and inspected them both, and can see no visible damage to them. However that doesn't necessarily mean they are not damaged internally, since I did not remove them from the knuckle when I was beating the old hubs off. Perhaps the heavy impact vibrated some damage into them, I have 2 new sensors arriving Friday and will replace them.
Another test i did just a little while ago was, start the car and just let it run idling without moving, and the lights never came on. This leads me to believe it is not recognizing an error while the wheels are not rotating. Unless someone else who knows subies better than I can correct my theory here?
dickydck is offline   Reply With Quote
Old 05-22-2018, 07:23 AM   #53
dankcincy
Member#: 472574
I tried the Autel MaxiCOM MK808 and while it will clear the ABS codes on my 06' WRX it will not cycle the ABS. Its actually extremely limited on what it will do on my subie. Its going back.
I'm going to try the Autel MaxiCheck Pro. Ill report back.
Autel MaxiCheck Pro Vehicle Coverage:
For ABS/SRS :
GM, CHRYSLER, FORD, AUDI, ABARTH, ALFA,
BENZ, BMW, BENTLEY, BUGATTI, CITROEN, DACIA, EU
FORD, FIAT, JAGUAR, LANDROVER, LANCIA, MINI,
MAYBACH, OPEL, PEUGEOT, PORSCHE, RENAULT, SAAB,
SMART, SEAT, SKODA, SPRINTER, VW, VAUXHALL, VOLVO,
AU FORD, HOLDEN, ACURA, DAEWOO, HONDA, HYUNDAI,
ISUZU, INFINITI, KIA, LEXUS, MAZDA, MITSUBISHI, NISSAN,
SCION, SUBARU, SUZUKI, TOYOTA
dankcincy is offline   Reply With Quote
Old 05-23-2018, 04:16 PM   #54
dankcincy
Member#: 472574
Success!!!!
The Autel MaxiCheck Pro will actuate the ABS on an 06' WRX. I have it in my hand doing it as we speak.
I'll check a few more years and models of subie and report back.
https://www.auteltech.com/Specialty%...ucts/546.jhtml
Old 06-05-2018, 06:15 PM   #55
Subie_Joe
Member#: 373366
Originally Posted by dankcincy View Post
Success!!!!
https://youtu.be/MgHqzotc9yU
https://www.auteltech.com/Specialty%20Products/546.jhtml
Any chance you can confirm it will read abs and srs codes as well?
Subie_Joe is offline   Reply With Quote
Old 06-06-2018, 02:04 PM   #56
dankcincy
Member#: 472574
Ill take a look this evening.
Old 06-06-2018, 04:28 PM   #57
Subie_Joe
Member#: 373366
Much apreciated. I ordered an iCarsoft 903 which claimed to be able to read abs and srs codes. Turns out they lied so I'm probably going to wind up with the Maxicheck pro after I send this one back.
Old 06-07-2018, 08:38 AM   #58
dankcincy
Member#: 472574
I got caught up with some other stuff last night. Ill try again this evening.
Old 06-07-2018, 08:14 PM   #59
dankcincy
Member#: 472574
Old 06-07-2018, 09:24 PM   #60
Subie_Joe
Member#: 373366
Affirmative. Autel MaxiCheck Pro will read/delete codes and read live data on my 06'WRX.
Checking ABS/SRS Systems Using Autel MaxiCheck Pro 06' Subaru WRX - YouTube
Thank you so much. I'll be ordering one of these tonight.
Old 06-15-2018, 05:43 PM   #61
ricoc
Member#: 487257
I might have to do this soon. thanks
ricoc is offline   Reply With Quote
Old 06-15-2018, 05:45 PM   #62
ricoc
Member#: 487257
Will Maxicheck pro read ABS for 2002 legacy gt? Anyone knows?
Old 06-18-2018, 02:20 PM   #63
dankcincy
Member#: 472574
You could order one off of Amazon and find out. Worse case you have to send it back for free. You're out nothing.
Old 02-11-2019, 08:04 PM   #64
gjpd602
Member#: 420962
2015 WRX Limited
For those of you that may be interested and have 2015 to 2017 wrx's, you can activate the ABS solenoids. I just recently purchase one and have tried it.
However if you purchase one, it ships with old software for both the scanner as well as the pc/mac software.Mine scanner was made in August of 2018 but it has the old software.
You will need to update both; then scroll through and select all of the available Subaru updates to the SD card that is supplied with the scanner.
Note you must use an SD reader that runs off your computer as you can't directly download to the scanner with the supplied USB cable.
Once you do both and insert the updated SD card into the device it will function.
For those with an 2015 - 2017 STI, there isn't a separate listing but since the abs system would be the same it should work.
For all the other model subaru's it covers from 1998 on.
gjpd602 is offline   Reply With Quote
