Welcome to the North American Subaru Impreza Owners Club Saturday March 23, 2019
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 07-19-2014, 03:39 PM   #1
Kevint143
Member#: 332258
1979 BRAT
alpine green/black
Default 1979 Subaru Brat swap
Hey So I had some friends convince me that I should make a build thread here on NASIOC. So about 2 years ago I picked up a 1979 Subaru BRAT in Portland, Or and decided to make a fun little project out of it.
1979 Subaru Brat by Kevin Talley, on Flickr
Drove the BRAT home and it would barely hit 40mph so i figured it needed a little love and started to dive into the essentials to make it run better.
I went in and changed all the fluids, most of the gaskets, motor/trans mounts, put some new hoses on and got her running well enough as a running project.
Once I got it running well enough I started to focus on getting it one solid color. So I went the cheap route and Plastidipped the car at around $70.
DSC03890 by Kevin Talley, on Flickr
DSC03891 by Kevin Talley, on Flickr
then Out of nowhere I had a massive vacuum leak I could not figure out for the life of me and after having a buddy check it out it turns out the stock carb needed a rebuild. We rebuilt the Carb and then that solved the problem for a while until I could afford a Weber 32/36 carb. Once I put that carb on it was a whole new car! Every problem I was having went away and gave it a little bit more power. I mean I could get this car up and over 85mph now!
After a while I saw some threads on various forums about lowering a first gen brat and someone mentioned it was not possible...so I thought challenge accepted. After doing some research and finding other various suspension parts that would bolt on and make it lower I made it happen. I also got tired of the black so actually Painted the car Green.
Untitled by Kevin Talley, on Flickr
Once we lowered it I had to make a new exhaust manifold because the stock one was too low so we had to make one that tucked up against the body a little better.
This was just a temp set up until we could have a custom set fabricated.
here is a video to a sound clip.
Then about 2 or 3 months ago my head gaskets blew and I fixed them but then decided to do an EJ swap. SO I looked around for a EJ22 and found a 93 Legacy for $700. SO I drove and picked it up and brought it home.
Now the Brat Sits in the garage with everything pulled out and waiting for the EJ22 to be thrown in. Last night we pulled the EJ22 and trans to start getting things fitted so from here on out will be progress.
Kevint143 is offline   Reply With Quote
Old 07-19-2014, 04:09 PM   #2
Kevint143
Member#: 332258
1979 BRAT
alpine green/black
EJ22 motor and trans are out as of last night!
Old 07-19-2014, 11:59 PM   #3
crazzysandman
Member#: 325139
2004 STi
Sick bro
04 STi
crazzysandman is offline   Reply With Quote
Old 07-23-2014, 02:02 PM   #4
Kevint143
Member#: 332258
1979 BRAT
alpine green/black
10500399_580481402060408_3703403529187747795_n by Kevin Talley, on Flickr
Test fitted the EJ22/trans last night. Gonna have to do some cutting!
Old 07-29-2014, 02:31 PM   #5
subyrally
Member#: 52662
2009 WRX. 06 Baja
17 Crosstrek 85 brat
cant wait to see this done
subyrally is offline   Reply With Quote
Old 07-29-2014, 03:42 PM   #6
Kevint143
Member#: 332258
1979 BRAT
alpine green/black
Same here!
Old 07-31-2014, 09:43 PM   #7
eddiexxxxxg
Member#: 306301
05 wrx
white
Hell yeah
eddiexxxxxg is offline   Reply With Quote
Old 08-03-2014, 08:13 PM   #8
Kevint143
Member#: 332258
1979 BRAT
alpine green/black
So we did another test fitting last night and got the motor sitting pretty close to where we need it. It's tight gonna notch the frame rails take a few ore measurements mod the cross members for the motor and trans mounts. Progress is coming along
Old 08-05-2014, 09:37 AM   #9
swansburg
Member#: 395873
2002 wrx wagon
wrb
haha this is awesome cant wait to see it done
swansburg is offline   Reply With Quote
Old 08-07-2014, 02:14 PM   #10
warpwar
Member#: 398404
I had dreams of doing an engine swap in my 84 Brat, so good luck!
warpwar is offline   Reply With Quote
Old 08-07-2014, 02:23 PM   #11
Kevint143
Member#: 332258
1979 BRAT
alpine green/black
It's almost a nightmare ha
Old 06-18-2018, 12:48 AM   #12
rjvos
Member#: 487107
1980 brat
sun baked
Default awesome
are you gonna re do the rear end or how much are you doing there?
rjvos is offline   Reply With Quote
Old 01-26-2019, 10:59 PM   #13
Francescarynne
Member#: 496958
Looks like this is a few years old. Do you have any updated photos?
Francescarynne is offline   Reply With Quote
Old 02-25-2019, 02:24 AM   #14
nimblemotorsports
Member#: 498225
1978 BRAT
Any update on the swap? I have a 78 and thinking of engine swap
nimblemotorsports is offline   Reply With Quote
